Seized pulley -- need replacement pn
Old 01-16-08, 11:33 AM
MadMaxxNA
MadMaxxNA's Avatar
Default Seized pulley -- need replacement pn
My father's LS400 has eaten a serpentine belt due to one of the pulley's seizing up. It's the one right above the water pump, a groved pully that doesn't seem to serve any function other than for belt routing (just a threaded bolt holding it on). The bearings on it are toast, so the belt just shredded against it right as he pulled in the driveway.
Can anyone get me a PN for replacement? Or, does this pully also exist on any of the 2JZ motors? If so I'll yank one off my spares.
Thanks!
Old 01-16-08, 11:46 AM
Suneet
Suneet's Avatar
What year LS400? You forgot to mention that.
Old 01-16-08, 12:03 PM
LiCelsior
Retired
LiCelsior's Avatar
i think its a 90 based on his sig.
Old 01-16-08, 12:23 PM
omarg
omarg's Avatar
http://www.trademotion.com/partlocat...model=LS%20400
just type in pully in the search its called "serpentine idler pulley"
top one for 55
mine went bad along with my fan bracket back in early november. Only mech problem my car has ever had
Old 01-16-08, 12:57 PM
damon
damon's Avatar
Is this Dayco part# 89026?
Old 01-18-08, 03:11 PM
mobilyte
mobilyte's Avatar
you can replace just the bearing in the pulley you are describing, i posted the bearing size in this thread:
https://www.clublexus.com/forums/sho...d.php?t=269851
flpgbc
10-13-15 12:50 PM
smrtsmart
02-12-13 10:26 AM
JDMCelsior
10-08-10 11:59 AM
deanbrown
10-25-08 06:06 PM
brit_lex
12-02-04 12:32 AM
Quick Reply: Seized pulley -- need replacement pn
