What parts to replace in AC system on a '90 LS400?
Old 10-23-07, 07:24 PM
ttyR2
ttyR2's Avatar
Default What parts to replace in AC system on a '90 LS400?
The AC compressor in my LS400 is locked up solid. I've been talking to a local AC specialist who does auto's but has never worked on a Lexus (they aren't common in these parts). He's coming up with a total of $1700 including labor to replace the AC compressor, parts he usually replaces during the job, and AC refill. Is that a crazy price? Exactly what parts are usually changed along with the compressor? Is the "speed sensor" on the compressor something that can be swapped to the new compressor instead of buying a new one?
Old 10-23-07, 10:13 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you're getting raped, go find a new mech/tech.
Old 10-24-07, 06:11 AM
fst4dr91
fst4dr91's Avatar
New Compressior If Yours Is Fubar
Ac Dryer -$80 Maybe
Thats About It Theres One More Valve But I Would Pay More Than $1k Installed
Compressor Is $400-500 Depending On Which One Even Cheap If You Get A Remaned Unit
Evac The System And Refill $100-150
So About $500-700 In Parts And $200 In Labor Which Bring You Around $900
Does The A/c Botton On The Climate Control Have A Flashing Green Light While Its Turned On ?
Old 10-24-07, 07:48 AM
ttyR2
ttyR2's Avatar
The AC light did blink and looking at the compressor with the engine running shows the compressor itself isn't spinning even though the clutch is engaged. After it cooled off (yes...I was dumb enough to touch the clutch after it slipped, with the engine off) the pump felt completely locked up and wouldn't spin at all.
I unplugged the AC compressor power connection so the clutch didn't burn up further, and to keep from damaging the drive belt.
So I should count on the compressor itself and the dryer. The other valves and such should be fine?
Old 10-24-07, 08:20 AM
fst4dr91
fst4dr91's Avatar
I READ IN THE OWNERS MANUAL OF MY 1991 LEXUS THAT IF THE A/C BOTTON ON THE CLIMATE CONTROL PANEL FLASHES THAN THERE IS A PROBLEM WITH THE A/C COMPRESSOR
THE ONE ON MY CAR STAYS ON CONSTANT SO I HOPE I CAN JUST GET AWAY WITH A RECHARGE OR REPLCEMENT FROM ONE OF THE HOSES
IN ANY EVENT IS SOUNDS LIKE YOUR COMPRESSOR HAS HAD IS EXPECIALY IF YOU HAVE OVER 300k ON YOUR CAR
THE MAIN THINGS THAT NEED TO BE REPLACED ARE THE
COMPRESSOR
THE A/C DRYER
AND MAYBE VALVE DON'T KNOW ON THIS LEXUS JUST BOUGHT MINE RECENTLY
Old 10-24-07, 06:39 PM
ttyR2
ttyR2's Avatar
Are all of the Denso 10PA20C compressors identical? I'm seeing them on Amazon brand new, not rebuilt, for $300. The local Toyota shop wanted to charge $750 for the compressor plus $250 for the clutch.
So...a compressor and dryer are the only components I should have to worry about? Need to know before dropping the cabbage.
Old 11-08-07, 08:46 PM
Bill Dowd
Bill Dowd's Avatar
I Would Follow Ttyr2 Advice And Get The Parts Off Amazon And Get Some One To Put In The Car. You Will Probably Need A New Dryer Check Around With Different Ac Shops And Get Different Estimates And They Will Recommend The New Freon R134 If You Can Find A Place That Has R12 The Old Stuff It Works Better And Get Much Colder .shop Around And Tell Each Shop The Last Shop Would Do It For This Amount They Will Usually Come Down To That Price Just Keep Droping The Price Till They Say Uncle.
rxiong918
Performance & Maintenance
08-19-14 02:37 PM
hazepurple
11-27-11 07:48 PM
scrim67
Maintenance
10-02-10 08:51 AM
1LS400Lexus1
04-13-03 04:58 PM
Mreald
SC- 1st Gen (1992-2000)
08-26-02 06:39 PM
Quick Reply: What parts to replace in AC system on a '90 LS400?
