Loose shifter 93
Loose shifter 93
My problem is my shifter is kind of loose; I can move it to the left or right.
I already did a search on this matter and one member mentioned about the shift bushing. anybody has a step by step or a diagram to show how to correct this. Much appreciated if you could offer some guidance. Thank you.
Might have just come a lil loose over time. This may help,,,,http://www.lexls.com/tutorials/body/shifter.html
Lots of DIY info here on this site.
yeah I saw that before but it has something to do with the top portion of the shifter but I think my problem is in the bottom portion of the shifter. Thank you for your help though.
I doubt the actual shifter itself is broken. I've checked it out, it's in there tight and less likely to move, unless you knocked it with a sledgehammer.
The black shift cover portion is not loose; there is something loose underneath the black cover that is holding the base of the shifter. The part (?) that is securing the base of the shifter is worn or something I guess. BTW, thanks for your response.
Hello, lexis, i am having the same issue with the shifter on a 90' LS400. Did you ever correct this problem? If so, How did you get to the bushing? I got the part from the dealer and would like to replace it.
