Help need a favour:headlight
could someone with a 1990 or similar LS that uses a 9004 headlight take a picture of this connector and note where which wire (color) goes into to each socket. For both left and right headlights. There should be three at the back. Pictures would be great. Thanks.
Might I suggest picking up an el-cheapo multimeter at Canadian Tire (or similar)...then you can determine in like 20 seconds which wire is ground, low beam positive and high beam positive.
Are you planning to switch to later year 9003's or JDM H4's?
Jurassic
23
07-17-17 04:18 AM
