Rust!! only one spot. how bad?
Old 06-25-07, 08:42 AM
jcolegrove
jcolegrove's Avatar
Default Rust!! only one spot. how bad?
hi all,
my otherwise pristine 92 ls has shown it's first sign of rust on the DS rear wheel lip. slight bulge below paint and you can feel it under the lip, too. only place on the whole car. i go thru the underbody every year and retouch w/ undercoat, etc... it was a mainland FL car for 10 yrs, but now OH salt apparently got to it.
should i fix? is there any other way besides body shop, etc..?
thanks.
jc
Old 06-25-07, 09:37 AM
etex
etex's Avatar
No other way I know of, unless you have body shop experience. Sorry.
Old 06-25-07, 09:49 AM
pito
pito's Avatar
Well rust is cancer for cars so go from there.
I say get it fixed before it becomes worse which it will
Old 06-25-07, 01:01 PM
nthach
nthach's Avatar
Only way to totally cure it is by cutting out the rusted area, MIG weld in a patch, grind it and do some body filler work and paint it.
Old 06-25-07, 02:17 PM
turbosix
turbosix's Avatar
surface rust wont need to be cut out..
Old 06-25-07, 07:25 PM
avalon42
avalon42's Avatar
There is some rust sealer that you can spray over the affected area, and seals it in without it continuing to rust. Unfortunately, its only a temporary fix. It needs to be grinded out.
Old 06-26-07, 01:05 AM
nthach
nthach's Avatar
You can also use POR-15 - it can be had at an Goodguys show or a auto body supply shop. But it does need to be coated over with an epoxy sealer like PPG's DP40LF primer and then refinished like usual.
Old 06-26-07, 06:50 AM
fencera
fencera's Avatar
About how much does this normally run?
To get it properly repaired (ie: cut out) not just covered up...
Old 06-26-07, 06:57 AM
jcolegrove
jcolegrove's Avatar
i'm going to my trusted body shop today...
Old 06-27-07, 06:12 AM
jcolegrove
jcolegrove's Avatar
got estimate for $350-$400 WITHOUT taking off bumper. thi is to cut it out, weld in, paint/clear it. to take off bumper- another $100 or so.
also, very interesting--- they said to take off the lower wheel well guards- that's probably what caused salty dirt/mud/water to be held up in there to rust in the first place. i took them off this morn, and they were filled w/ dirt/crud. they DO protect against stone chips, but if you undercoat the bottom of the well and check every year, you'll be fine. mine are off for good. looks cleaner, too. said honda's/toyotas are known for causing rust in these.
dyongg
09-18-15 08:21 AM
9relude8
NELOC
12-10-09 06:14 AM
AndrewG13
05-16-04 01:15 AM
r4z0r3ck
03-17-04 10:13 AM
Quick Reply: Rust!! only one spot. how bad?
