UCF20/21 front brake caliper into UCF10/11?? (The Mother thread)
Old 05-24-07, 12:24 AM
Suneet
Suneet's Avatar
Originally Posted by ctscna1
Here is the picture for binding
I can't see the pics for some reason.
Old 05-24-07, 06:36 PM
mobilyte
mobilyte's Avatar
i had no tie rod end bolt clearance issues with fitting 2nd gen LS calipers onto my 90 LS. but, i do recall reading somewhere that the 95-97 and 98-00 LS calipers are not identical. the mounting tabs (somebody called them rabbit ears) are alleged to be slightly different and make one set appear to mount in a more upright position, i cannot verify though.
Old 05-26-07, 09:10 AM
avalon42
avalon42's Avatar
The set you got, what year was it from?
Old 05-26-07, 11:54 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
as far as i know the toyota/lexus part no.s for the front brake calipers on the 95-00 are the same and are interchangeable between the years. when i had compare my 95 repair manual to my ''99 the calipers look identical.
Old 05-26-07, 01:16 PM
avalon42
avalon42's Avatar
BTW, the pics are way too big. Hey ctscna1, can you resize them please?
Old 05-26-07, 02:14 PM
mobilyte
mobilyte's Avatar
my previous set was from a 98 LS. like i said, somebody claimed that the ucf 20 & 21 had slightly different mounting tabs on the calipers, but i cant find a link to where i had read that. i do know that the 2nd gen GS has this clearance issue with the tie rod end, this is the first time i've heard a 1st gen LS or SC owner having this problem.
i've worked with many sets of 2nd gen LS calipers, but i didnt have the opportunity to compare ones off the ucf 20 & 21 side by side. when i went to my local dealership to order a fit kit (to replace a missing wire spring for the pad retainer pins), the parts guy insisted that he needed the specific year because they had different part #'s between 95 and 00.
maybe we can elaborate further when cts reposts the missing pictures...
Old 05-26-07, 03:42 PM
PureDrifter
BahHumBug
i can see the pics fine
Old 05-26-07, 06:22 PM
Thermactor
Thermactor's Avatar
Fixed the f-ed up formatting
Old 05-26-07, 11:40 PM
mobilyte
mobilyte's Avatar
thanks for getting the photos working. judging from the 2nd photo, it appears that the caliper might be installed on the wrong side. i'm not 100% certain on that, since i dont see the bleeder valve anywhere in the last photo. another forum member had the same problem with his SC:
https://www.clublexus.com/forums/sho...d.php?t=258604
Old 06-24-07, 04:27 PM
mobilyte
mobilyte's Avatar
i test fitted a passenger side front caliper from a 95 LS on my car today and can confirm clearance issues with the tie rod end. will try to get another caliper from a ucf21 (98-00) to test fit because i'm curious as to why my last set of calipers had no problem fitting.
Old 06-27-07, 10:34 PM
ctscna1
ctscna1's Avatar
Once the ball joint change to 95+, it was fit perfect. But the toe was out of spec.
Old 12-03-11, 09:35 PM
ocr
ocr's Avatar
Question UCF20 caliper to UCF10 question
maby i havent looked long enough but, does the ucf20 front brake calipers fit the ucf10?
if so im buying some and swapping mine out.
4 piston brakes / 1 piston brakes
Old 12-03-11, 09:59 PM
sdls
sdls's Avatar
yeah you'll need ball joints and wheels that fit too
Old 12-03-11, 10:42 PM
ocr
ocr's Avatar
what ball joints would i need? the ones for the ucf10 or the ucf20? i already know i would need wheels that'll clear the calipers, im getting the XXR 522 18's.
Old 12-03-11, 10:50 PM
RA40
Super Moderator
RA40's Avatar
These threads:
http://www.lextreme.com/lsbrake.html
http://www.lextreme.com/suprabrakeupgrade.html
https://www.clublexus.com/forums/ls4...into-91-a.html
Quick Reply: UCF20/21 front brake caliper into UCF10/11?? (The Mother thread)
