License Plate Lights 1992 LS
Old 04-03-07, 11:04 PM
lexls40092
lexls40092's Avatar
Default License Plate Lights 1992 LS
Hey all, I want to replace my license plate 168 oem bulbs with some white light or xenon bulbs...has anyone done this? Should I go with a specific bulb so I don't burn out the wiring?
..also, I tried to remove the plastic covering today to examine the bulb, but when I took the 2 screws out I still couldnt get the plastic covering off. Is there a trick to this, or something I'm missing??
Thanks
Old 04-03-07, 11:24 PM
Spyder78
Spyder78's Avatar
most likely there is rubber around the cover and since your car is a 92 you just got to pull a lil harder.
Old 04-03-07, 11:42 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
id reco polarg M4's for the license plates.
Old 04-10-07, 02:36 AM
DTR_Projek
DTR_Projek's Avatar
i did mine a few months ago. U have to go through the inside of the trunk, and remove the liner covering the backside of the lid. Hope this helps...good luck!
Old 04-10-07, 02:49 AM
PureDrifter
BahHumBug
i just did mine 2 days ago, took <5mins, used a philips scredriver to take the 4 screws out, then a flathead to GENTLEY pry the plastic lenses off the surface of the light. they were stuck on a bit because of the foam gasket but they werent attached/glued on
Old 04-11-07, 06:46 AM
LILEVO
LILEVO's Avatar
http://www.wikked.com/lilevo/lex-led.jpg
Supernova LED's from autolumination
LexATL404
ES - 5th Gen (2007-2012)
01-20-15 08:51 PM
shantm8980
06-23-13 03:47 PM
ekaiman341
11-04-12 06:44 PM
dysLEXic
03-23-08 01:25 AM
Quick Reply: License Plate Lights 1992 LS
