HELP! newbeeie seeking wisdom!
Old 02-05-07, 01:01 AM
JJN LS-400
JJN LS-400's Avatar
Unhappy HELP! newbeeie seeking wisdom!
hey guys ! first time lexus owner here, with a problum! i recently bought a mint 1990 LS-400 with with low miles for cheap! it was parked a few years ago and never driven since! older couples car that needs sum TLC! so far nothing but a tune up and a altenator and new rubber! I am loving it ! well I noticed recently checking the power steering fluid that, foamy bubbles were in the P.S. resivior and a little low ! i top'd off with dextron-III and few days later i hear a whinning from the p.s. pump! checked it out and level was fine and no leaks but that foamy froth in the resiviour! now its a super loud whine when i turn the wheel and starting to leak out of the cap very little! i researched this car alot b-4 i bought it and i am aware of the P.S. problums with 1st gen. LS-400! but i am hoping that it is sumthing small i can fix before i end up replacing the P.S. pump and another altenator! can sum one plz help! thnks so much!
Old 02-05-07, 06:22 AM
Gunnut
Gunnut's Avatar
I'd try cleaning the screen and doing a flush. Bubbles would mean there is air in the system somewhere. Make sure to keep it topped off and keep checking for leaks.
Old 02-05-07, 01:20 PM
JJN LS-400
JJN LS-400's Avatar
Unhappy
I went today 2 my local machanic 2 have him take a look and give me an opion. he told me he would say it was a bad pump itself ! so i am really confused now! if it wasnt for the 30 below wind chill and a lack of a garage i would of dived rite into this head first! so i just wana try 2 stop the lil prob. b-4 the big 1 ****! and buying another altenator again! so n-e-one by chance have step/step info. on exsactly how to do this procedure and the does and dont's? i would very much appriciate n-e-help! stay tuned!
Old 02-05-07, 01:41 PM
Och
Och's Avatar
Check out lexls.com, it may have a tutorial. Also, check the sticky threads in this forum.
Old 02-07-07, 03:19 PM
RA0806232
RA0806232's Avatar
Had the same problem with my 91. Took it to my local mechanic and they used a special machine they have to siphon and clean the pump and the whole steering system while the car is running. They then replace the old fluid with a synthetic oil. The pump was super quite after this but because of the idle control valve being bad it sucks some of the oil out. I top it up with Dexron III which is compatible with the synthetic but now that I am getting more Dexron in there the pump is again starting to make a small amount of noise when it is cold but only for a few seconds after the car is started. The mechanic told me there was a lot of "debris" in the old oil they sucked out.
rGavint
09-09-15 07:10 PM
cmanns
11-29-14 11:28 PM
ALBATROS
12
09-07-12 09:12 AM
BradleyS
02-05-12 06:45 PM
billj747
16
01-21-08 10:53 AM
Quick Reply: HELP! newbeeie seeking wisdom!
