Excessive body roll
Old 10-12-06, 09:46 AM
LeXuSrAcIn
LeXuSrAcIn's Avatar
Default Excessive body roll
The car has about 110k miles. On turns I feel like I have zero control. Car is quite scary to drive. Maybe because I'm used to driving my SC which has Tein coilovers and a bunch of other suspension upgrades. Anyways I think the shocks have gone bad which is why I find myself bouncing all over the place. This car is the daily and I dont want to lower it... just get a good ride and less body roll. What do you guys suggest? KYB GR-2s?
Old 10-12-06, 09:48 AM
LeXuSrAcIn
LeXuSrAcIn's Avatar
Also, wheres the cheapest place to buy the KYBs from?
Old 10-12-06, 04:01 PM
sami
sami's Avatar
here you go start with this
http://www.luxurymods.com/ProductDet...D=790&fid=1019
Old 10-12-06, 05:23 PM
Och
Och's Avatar
Dude, unless you are exaggerating, then there is something seriously wrong with your suspension. I own a GS430, and my LS400 is my daily driver, and before the LS my daily driver was a Honda Civic with Integra Type-R suspension, which could out-handle most cars out there. But now that I have the LS it isn’t that bad. Yeah, you get body roll, but it’s not anywhere near the point that it would be scary or feel out of control. In fact it’s pretty darn sure footed, and although the steering is very numb and has little feedback, once you get used to it, you can actually throw it around quick corners and it won’t let you down. I think you should check your suspension for problems before you go ahead and ruin your ride with aftermarket crap. First thing to do is to check your tires pressure and condition, check your wheels, check your sway bars, shocks and springs.
Another thing to keep in mind is we have annoying spring seats in our first generation LS400’s, and because of them you may feel more body roll than there actually is.
Old 10-12-06, 09:12 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I would get some Bilsten shocks. But prepare for a harsher ride.
Old 10-12-06, 10:07 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
sounds like ur old shocks are blown. new shocks would definitely improve ur handling, even softie OEM ones.
Old 10-13-06, 06:25 AM
pito
pito's Avatar
I must agree. My LS I only put on new Falken Ziex's with factory 16's.
I surprise alot of people with the speeds I can take curves and turns. I was able to hang on a curve with my friend who has an 06 civic si doing over 80mph. Yes it does has body roll but it felt planted on that curve. Better than my Q45 did thats for sure.
Old 10-13-06, 07:00 AM
NewLSlover
NewLSlover's Avatar
2 TON cars tend to have some body roll...but yea, you definitely should look into some new shocks.
Old 10-13-06, 08:54 AM
persian451
persian451's Avatar
urethane bushings, and kyb gr-2 and eibach drop is what I have. HUGE difference. If you can go with Bilsteins, then do it. Personally I would have gone with Tein coilovers or JIC, but they were too costly. You can put on a Strut Tower Bar from a 93-98 supra TT as well, which you can pick one up from eBay for about 30 bucks or less.
Old 10-13-06, 09:54 AM
PureDrifter
BahHumBug
Originally Posted by persian451
urethane bushings, and kyb gr-2 and eibach drop is what I have. HUGE difference. If you can go with Bilsteins, then do it. Personally I would have gone with Tein coilovers or JIC, but they were too costly. You can put on a sway bar from a 93-98 supra TT as well, which you can pick one up from eBay for about 30 bucks or less.
don't u mean Strut Tower bar, not Sway bar?
Old 10-13-06, 10:18 AM
persian451
persian451's Avatar
Oops.. I fixed it.. brain fart
Old 10-14-06, 12:52 PM
crazimofo
crazimofo's Avatar
persain451!
...too much smoking, thats why.
Old 10-15-06, 09:47 PM
persian451
persian451's Avatar
possibly
Old 10-16-06, 11:11 AM
steveski
steveski's Avatar
You don't have excessive miles for the shocks to be completely worn. Push down on the front fender to see if it bounces more than once. Your car should not handle that bad boss.
Old 10-18-06, 10:34 PM
LeXuSrAcIn
LeXuSrAcIn's Avatar
Well if I hit a bump in the road the car makes a loud thud sound and pretty much bottoms out. I'm really assuming its the shocks but I guess I'll have it checked out.
Quick Reply: Excessive body roll
