Moonroof LS 400 '90
Moonroof LS 400 '90
Are there any adjustments on the moonroof. It works fine, does not leak; however it appears to
have some vertical play in it when seated in closed position. One can push up on it from inside the car, and approximately 1/2" of movement can be noticed.
I would not worry about it, but it has a rattle in it, and I think I hear some wiind noise.
I have been looking for exploded view of it, but have not found one.
Thanks
Thanks
3UZ-FEEEE
Originally Posted by AussiLS400
Your in luck as there is a pdf in the library section of this forum.
https://www.clublexus.com/index.php/...ew/1693/1/360/
