1991 LS 400 Alternator
Old 05-21-06, 12:56 PM
J_Swaleh
J_Swaleh's Avatar
Question 1991 LS 400 Alternator
Hey, I'm a newbie to the lexus world and i need some help. I need a writeup on how to replace the alternator. Any help would be great, but if anyone has a writeup, it would be the best.
Thanks
Old 05-22-06, 09:13 AM
denverdog
denverdog's Avatar
i don't have the answer to your specific question, but if the alternator is gone, look up prior posts on the power steering pump. this could easily be the cause of the alternator going. there shouldn't be more than a thousand or so prior posts on this topic. this is one of the major design flaws in the ls. it pays to know about it.
Old 05-22-06, 11:45 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Welcome to the LS forum.
Hope this helps:
http://www.lextreme.com/alternator.html
Old 05-22-06, 07:10 PM
5ofakind
5ofakind's Avatar
Think about rebuilding your alternator ...rather than buying a remanufactured or new one.....they are quite expensive......
Any good auto electric shop should be able to rebuild your existing alternator...
Old 12-22-14, 01:07 PM
SirNeedHel
SirNeedHel's Avatar
Default rebuild instructions
I bought a LS 400 about a year ago, and of course my power steering has leaked all over it. I would greatly appreciate instructions on how to rebuild the alternator and maybe even how to rebuild the power steering pump.
Old 12-22-14, 01:10 PM
sha4000
sha4000's Avatar
Just search in this forum for leaking power steering pump.
Old 12-23-14, 02:49 PM
oldskewel
oldskewel's Avatar
Before rebuilding the alternator, you might want to figure out whether it is a good Denso one that is worth rebuilding vs. a disposable Chinese one that is worth replacing.
Regarding the PS pump, it seems everyone eventually has problems with the idle-up valve. Many have problems with the o-ring between the reservoir and pump leaking. Some actually need a new pump. It sounds like many people see a leak there and just replace the pump. This does take care of all 3 possibile problems, but may not be necessary. But yes, you do want to get the PS leak taken care of if you want to preserve your new alternator.
If you're able to rebuild the pump yourself, you can save some $$ that way. I did it on mine and it was trickier than I expected. But in the end it was just that the o-rings and seals had cooked over time and were too hard to seal properly.
Old 12-23-14, 05:57 PM
dicer
dicer's Avatar
What would really be helpful is to explain where to get the parts to do the rebuild.
Old 12-23-14, 09:45 PM
oldskewel
oldskewel's Avatar
I have not rebuilt my alternator. But I rebuilt the power steering pump in my '91 using:
9036317017 BEARING, RADIAL BALL 1 $12.02
0444630173 Steering - P/s pump & hoses - Seal kit Seal kit, ls400 - power 1990 - 1992 1 $27.04
RA40
Maintenance
08-19-07 07:05 PM
RUDENESS
06-05-05 08:48 PM
gn3
Performance & Maintenance
04-10-05 08:57 PM
alexamparo
Maintenance
10-10-02 03:49 PM
Quick Reply: 1991 LS 400 Alternator
