Dash lights don't light up when car is cold
Old 03-24-06, 07:28 PM
Ross Geram
Ross Geram's Avatar
Thumbs down Dash lights don't light up when car is cold
My dash light do not go on when it is below 45% only when the car warms up
Why??????????????
Old 03-24-06, 08:53 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
something about a big 142 post long thread stickied to the top of the forum alludes people.
Old 03-25-06, 09:45 PM
jerrygrier
jerrygrier's Avatar
Default Dash does not light up when car cold
See the first sticky listed. You have a couple of bad capacitors in the power board behind the dash. Capacitors cost 25 cents. Dealer will insist on replacing the whole board for over $1000. Good luck.
Old 03-25-06, 10:14 PM
uncle_el
uncle_el's Avatar
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/40025-instrument-cluster-circuit-board-is-bad-1000-bucks.html
Old 04-05-06, 04:54 AM
vinegaroon
vinegaroon's Avatar
Default Cluster fix
Why??????????????
Try looking at www.mrwizard.com website. Houston dealer uses him with confidence.
Old 04-05-06, 09:59 PM
KilaWombat
KilaWombat's Avatar
i have this problem with my 93 too... either you can go to the dealer or you can go the the guy that people on here suggest, which is cheaper but will it fix everything? i plan to get mine repaired in the future if i hold onto the car
Old 04-05-06, 11:02 PM
vinegaroon
vinegaroon's Avatar
Default Cluster problems
Well anything is cheaper than going to the dealer. All of these cluster problems seem to be caused by the failure of capacitors (of which there are many) in the very complex circuitry of
these clusters. Some of the folks who repair them have found how to diagnose and replace
the failing capacitors and viola! the problems are solved. The capacitors are very cheap, but Lexus doesn't make any money fixing them. They make money selling the two boards (and
probably some other parts) that make up the cluster. I don't know how the fixit guys have been able to diagnose just which capacitors do what, but they can save us bunches of money and
do what Lexus should be doing but won't. At least check them out.
Old 04-06-06, 10:49 AM
KilaWombat
KilaWombat's Avatar
so, the guy suggested on here fixes the gauge lights...the lights on the climate control and whole center console is dimmed as well and eventually comes on....is that fixed as well?
Old 04-06-06, 06:23 PM
vinegaroon
vinegaroon's Avatar
Default Additional fixes
I think you will have to go to his website and check it out. I think you can email him or use a
toll free number as well. Just go to www.mrwizard.com.
Old 04-07-06, 07:12 AM
Lexs400
Lexs400's Avatar
what year is your LS ?
I have a fixed cluster that I am selling with new needles from my 92LS.
u can email me at aassume@hotmail.com
Old 04-07-06, 12:08 PM
KilaWombat
KilaWombat's Avatar
but, what about the mileage....is that going to be different because it's coming from another car?
Old 04-07-06, 01:52 PM
vinegaroon
vinegaroon's Avatar
Default difference in mileage
The mileage is stored in the smaller of the two boards on your instrument cluster. You may
be able to exchange the small board if that is not where your problem is. It's not hard to do
if one has some manual dexterity.
40cpe
01-01-15 08:49 AM
motoyz250
09-06-08 05:20 PM
SC400MAN
Maintenance
06-05-04 06:01 AM
Thuggybear
10-29-02 06:35 PM
2Lexus430s
SC- 1st Gen (1992-2000)
05-20-02 06:02 PM
Quick Reply: Dash lights don't light up when car is cold
