Brake Wear message
Old 11-11-05, 01:17 PM
TJW98LS
TJW98LS's Avatar
Default Brake Wear message
Ok so I was stopping from 60 MPH and had to rather hard and the brake wear message pops up on the cluster. How much time do I have before something bad happens with the the brakes? I can't get the car in anywhere for awhile, too busy.
Old 11-11-05, 03:43 PM
ychachad
ychachad's Avatar
You have about 1/8" - 1/4" of pad left. which will get you around for a few weeks at least. However, the sensor is expendable and the filament has already been worn out to break the circuit. That's where Lexus will hit you with a bill for about $80-100. Plus the cost of the pads, and maybe resurfacing. Until you replace the sensor, the light will not go away. I soldered mine for free.
Old 11-12-05, 11:05 AM
ychachad
ychachad's Avatar
There is a wire at the tip which gets cut as the brakes erode. fill it up again with molten solder so there is a connection again. Don't worry, the solder will not melt the plastic.
Old 11-13-05, 11:27 AM
TJW98LS
TJW98LS's Avatar
THat's weird...I replaced them and the message is gone...are you sure???
Old 11-13-05, 08:13 PM
OGS
OGS's Avatar
Maybe you can help me out with something.
When I installed my BBK kit, that stupid red light (red triangle) and "brake wear" warning came up....and well, 6 months later its still onn.
can I do as you posted above on a 05?
Old 11-13-05, 09:20 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
OGS, i think what happened is when you installed the BBK u took the sensors off the car. easiest way to remedy this would be to just jump the connectors and weatherproof it.
Old 11-13-05, 09:54 PM
OGS
OGS's Avatar
Originally Posted by MeanLex
Yes, should work on your sensor as well unless it's extremely worn. How long did you use the car prior to installing new brakes once the sensor came on? The only way to tell is to look at your sensor wire.
The car had about 8k miles on it when I put the BBK on.
Old 11-13-05, 09:55 PM
OGS
OGS's Avatar
Know of any place (around the South Bay area) that can do that for me?
Old 11-14-05, 04:59 AM
ychachad
ychachad's Avatar
When you installed your new brake kit, you disconnected the sensor. Maybe they have no place for it. You should reconnect the sensor (plug it in) and then just let it hang loose or cut it short and splice it. For me the brake sensor is useless, as I check the amount of pad left everytime I rotate my tyres, and I'll replace the pads if they are remotely close.
Old 11-14-05, 09:01 AM
OGS
OGS's Avatar
I checked the box they gave me with all my stock stuff in it, but I don't see the plug looking thing.
It should be right there near the rotor right?
Old 11-14-05, 11:06 AM
ychachad
ychachad's Avatar
Yes, the tip touches the rotor when the pads wear out, then the wire burns off setting off the alarm.
Old 11-14-05, 03:13 PM
TJW98LS
TJW98LS's Avatar
I take it back...the message is still there. CRAP, I guess I have to take it in again.
Old 11-14-05, 04:11 PM
PureDrifter
BahHumBug
Forum Moderator
you did reset the ECU (discon battery for ~5mins) after u soldered the wires right...
Old 11-14-05, 04:18 PM
TJW98LS
TJW98LS's Avatar
I'm not sure...Midas did it.
Old 11-14-05, 08:32 PM
TJW98LS
TJW98LS's Avatar
I'll check into it, I have to take the car in for servicing anyway.
Quick Reply: Brake Wear message
