Valve cover gaskets?
Old 10-31-05, 09:38 AM
Christian
Christian's Avatar
Default Valve cover gaskets?
Hello,
I need to change the valve cover gaskets on a 92 LS. How hard is it?
Chris
Old 11-24-05, 05:47 PM
sahtt
sahtt's Avatar
Turns out there was a mixup and my 'valve seals' were really valve cover gasket issues. The one on the rear is the one leaking slightly but I'll probably replace both. I haven't looked into it at all but I assume you still have to remove the intake manifold, being the hardest part.
Old 11-25-05, 10:30 AM
Christian
Christian's Avatar
Hello,
I allready did the job. I did the passenger side first and it turned out to be the harder one. The intake manifold can stay in place.
The car had 465000km on it when I did the job. Here are some pics.
driver side
Old 11-25-05, 10:31 AM
Christian
Christian's Avatar
passenger side
Old 11-25-05, 10:34 AM
Christian
Christian's Avatar
driver side valve cover
Old 11-25-05, 04:08 PM
Christian
Christian's Avatar
Hello,
only on the drivers side cover was that much buildup! The price for 2 gaskets and 16 plates for the bolts and the TB gasket was around 50 or 60$ at the Lexus Dealer.
Chris
Old 11-26-05, 04:05 PM
sahtt
sahtt's Avatar
Excellent, that doesn't look too bad at all. Did you do the cam plugs or any other maint. while the valve covers were off, or at least clean them up?
Old 11-26-05, 04:45 PM
Christian
Christian's Avatar
Hello,
yes I cleaned everything so the covers looked like new, but the passenger side cover almost had no buildup. I also checked the valve clearence which was perfect.
Chris
harvfran
03-22-19 06:07 PM
tjwashow
03-26-14 01:27 PM
southtrian
Performance & Maintenance
04-21-06 11:04 AM
Quick Reply: Valve cover gaskets?
