Tanabe DF210 springs discussions (The Mother thread)
Old 04-05-08, 07:02 PM
  #211
steveski
steveski's Avatar
Wow the 20 offset is quite a bit more outward than my 35 (obviously). I wonder if the camber will be enough when you lower the car or if you will have to adjust more camber to make the tire tuck? It appears to be out pretty far? My 35 offset tucks without adjusting camber - have about 1/8" between sidewall and fender. I see though you are stretching a smaller tire though. Looks good bro.
Old 04-05-08, 08:29 PM
  #212
PureDrifter
BahHumBug
PureDrifter's Avatar
ehh i dont think the front on that is +20, or if it is its wierd coz my 20x9 +30 look more aggressive in the front than that.
Old 04-06-08, 05:36 PM
  #213
eg6ky
eg6ky's Avatar
mines only 19x8 instead of 9, and it's def. a gay high disk wheel. Back of the wheel says +20. Trust me, i'm not the normal newb that is on here all the time. I got a smash deal on em and couldn't ride any longer without wheels so i got em. Maybe next year i'll get some Better wheels but i want it lower first.
Thanks for the props steve. It bugs me soo much that it still sits that high, it's the highest sitting car I've ever owned. If i have to use some camber I won't mind. Just as long as it's low. I may put some spacers on the front too, once i get it lower, don't know yet.
Old 04-07-08, 06:53 AM
  #214
19psi
19psi's Avatar
ha, i was looking at those wheels too on ebay. like $400 for the set of soemthing crazy right? i just couldn't decide if they'd look good on an LS, so i passed. they dont' look bad at all; once it's loooowww, i think they'll be better. i have a pair of 25mm spacers for sale if youwant them. $35.
Old 04-07-08, 08:43 AM
  #215
eg6ky
eg6ky's Avatar
$498.shipped to be exact haha. Those spacers have studs with em or no?
Old 04-07-08, 09:54 AM
  #216
19psi
19psi's Avatar
yeah they're the studded billet aluminum kind. very nice but a bit too thick for me to use on my fronts...they came with the wheels i got a few weeks ago.
where are you in KY?
Old 04-07-08, 10:46 AM
  #217
PureDrifter
BahHumBug
25mm spacers on +20 wheels?
damn, thats -5, which is possible on narrow rims in the rear with a roll+mild pull+stretched tires, but will require a load of work for the front.
Old 04-07-08, 11:46 AM
  #218
19psi
19psi's Avatar
yeah i think they'd only be good for the rear.
Old 04-07-08, 04:53 PM
  #219
eg6ky
eg6ky's Avatar
I'm in paducah, those are big, just weighing my options since they were cheap.
Old 06-21-08, 08:12 PM
  #220
93lexES300
93lexES300's Avatar
Default Tanabe springs and spacers
So I installed the tanabe springs a few weeks ago and my total drop was about 2". I like the ride from the springs but it's too low. I'm going to fab up spacers that will rais the height 0.5" so I get like 1.5" front and 1" rear drop.
I know most like thir car low, but anyone else interested in some spacers?
Old 06-21-08, 08:18 PM
  #221
PureDrifter
BahHumBug
no, its the ghetto way to do it since it messes up the spring rate. you're better off swapping the springs for some H&R, which give a drop like what you're looking for.
do it once and do it right, and if you dont get what you want, fix it the RIGHT WAY.
Old 06-23-08, 11:48 AM
  #222
jcrome04
jcrome04's Avatar
Yeah you should just get some different springs that don't drop it as much.
Old 06-23-08, 06:55 PM
  #223
L_Sport
L_Sport's Avatar
Amen to that, I am sure that there are peeps on here that would be willing to buy your used springs. You may take a small loss since they have been installed but spacers are "no bueno"
Old 08-20-08, 04:46 AM
  #224
Daniel N
Daniel N's Avatar
Default Tanabe springs on standard coilovers?
Hi,
Can anyone tell me if a 1993 LS fitted with Tanabe springs on standard coilovers will damage the coilovers faster than with standard springs?
And will there be any problems with 4 guys in the car when riding on Tanabe springs on the standard coilovers with 19", such as speedbumps ect..
Thanks
Daniel
Old 08-20-08, 05:51 AM
  #225
greenvy2k
greenvy2k's Avatar
well i guess that it is safe to assume that u might be getting the df210's. If the struts are brand new i don't think that u will have a problem with blowing your struts abnormally quick. If the struts have some age on them though they might go just in a couple of months. With the rubbing issue on 19's there is just a little more info that we would need to know that you might rub, like your offsets and width. i have 20's and had 7 people in my car just this past weekend and i didn't rub.
Quick Reply: Tanabe DF210 springs discussions (The Mother thread)
