Another starter dilemma.
Old 07-15-05, 08:23 PM
Strida
Strida's Avatar
Default Another starter dilemma.
I think my starter finally gave today. The car just wouldnt start. Before it takes me 3 to 5 tries to start the engine and sometimes just once and it would go but today, click..click...click x20
Checked the battery (12.5V reading), cleaned the terminals still nothing. The only thing i havent checked is the starter relay and the ignition switch. I know where the starter relay is but dont know how to test it if it is okay. i have a meter, if anyone know how to check the relay it will be much appreciated. Second, how do you check the ignition switch?
If the above doesnt solve it, then i have to dissect the top of the motor and b_tch slap that starter. Any body knows the size of the two bolts that attach the starter to the motor? thanx in advance.
Old 07-16-05, 04:02 AM
Losiho
Losiho's Avatar
Sounds like you're having the same problem I'm having :
https://www.clublexus.com/forums/sho...d.php?t=170222
Old 07-16-05, 07:24 AM
Strida
Strida's Avatar
Well tested the starter relay this morning and it is OK. Found a website on how relay works and methods on testing them. Here is the link http://www.autoshop101.com/forms/hweb2.pdf
Old 07-16-05, 07:24 PM
koolaidman
koolaidman's Avatar
lol so what if the batt shows 12.5.. under load prolly shows 3 v
do this
turn on ur head lights
turn on ur interior lights
turn on ur radio
koeo
and tell me voltage
Old 07-16-05, 10:44 PM
bluestar
bluestar's Avatar
Default Starter problems
My 1999 LS has 104K miles and started having problems starting. On the third day, after almost 20 tries the car finally started. I simply drove it to the dealer. They ran diagnostics on the car and confirmed it was the starter. RLexus dealer replacedeplacement for a new one cost me $534 including labor, parts and tax.
Hope this helps any of you having similar problem.
ps: any one know at what mileage (roughly) the starter begins to fail ?
Old 07-17-05, 05:23 AM
clark
clark's Avatar
My starter was just starting to go on my 1991 LS400 at 185K. I finally had it replaced when my front engine seals were starting to leak at 190k.
Whitenova
17
06-04-13 06:15 PM
SuicidnS13
Performance & Maintenance
11-02-10 08:51 AM
spooledx2
09-01-08 08:08 AM
cfuller74
07-21-08 08:04 AM
Quick Reply: Another starter dilemma.
