Headlight troubles after replacing bulb
Old 07-12-05, 07:35 AM
Racerhoze
Racerhoze's Avatar
Question Headlight troubles after replacing bulb
After replacing both headlights in my brothers 1st gen LS, one headlight's highbeam still does not work. Before replacing the headlights, neither highbeam worked, but the old light on the side of the car with the headlight that is still not working did not have a broken filament... which makes me wonder what else could be causing the highbeam not to work.... is there a right and left highbeam fuse? or could there be something wrong with the connector. TIA
Old 07-12-05, 08:51 AM
phillipin
phillipin's Avatar
the bulb you put in was it a dual hi/low beam bulb?
Old 07-12-05, 09:34 AM
Racerhoze
Racerhoze's Avatar
Correct, the right side's highbeam works but not the left
Old 07-12-05, 10:15 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Yes check your fuses.
Old 07-12-05, 10:18 AM
Racerhoze
Racerhoze's Avatar
hmm, im not familiar with the fuse locations on the ls.... would they be the ones shoved way the hell underneath the drivers side footwell?
Old 07-12-05, 11:39 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
and driver side in the engine compartment.
Old 07-12-05, 11:58 AM
Racerhoze
Racerhoze's Avatar
yeah, we took out the drivers side headlight and there were fuses under there, so I wasnt sure if they were sprinkled everywhere or what
TurboDooze
01-10-18 12:23 PM
Es300Lover
02-20-13 10:11 PM
rclab1
09-22-10 05:11 AM
my_shaldan
GS - 1st Gen (1993-1997)
04-07-08 11:18 PM
reddlexus
Lighting
11-03-05 07:39 PM
Quick Reply: Headlight troubles after replacing bulb
