error code 31 HELP !!!
Old 07-10-05, 04:40 PM
phillipin
phillipin's Avatar
Default error code 31 HELP !!!
I jumped my diag port because of the issues i'm having with the engine stumbling.
Im gettin error 31 also known as
MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
--AIRFLOW METER/CIRCUIT
--MANIFOLD PRESSURE SENSOR/CIRCUIT
--ECU
So I know i should check all my vaccum lines but what else should i check, or pull out and clean. at idle sometimes i can hear little poots of air popping out. So i'm wondering if i have a cut vaccum or cracked vaccum line somewhere.
please give me suggestions here.
I cleaned my maf sensor twice and this probably has something to do with it, but im not 100% sure.
pchouston
RX - 1st Gen (1999-2003)
02-10-19 09:04 PM
AliGS300
11-21-09 12:20 PM
hyhflo
Performance & Maintenance
12-28-08 06:29 PM
asf4life
08-18-05 08:54 PM
Quick Reply: error code 31 HELP !!!
