A/C, Heater problem, please help.
Old 06-17-05, 12:29 AM
ShowDiscipline
ShowDiscipline's Avatar
Default Problem resolved
Problem resolved
Old 06-21-05, 05:47 PM
ssscarpone
ssscarpone's Avatar
When it does not blow air is the compressor running? If it is, then narrow it down to the blower motor or its electronics. If the compressor is not running when you turn the ac on and it doesnt blow air, then it is probally the hvac system in general. But you cant really troubleshoot unless you have a electrical diagram. Check your blower for a restriction or seizing.
Hope that helps alittle
Old 06-22-05, 10:08 AM
ssscarpone
ssscarpone's Avatar
Without a wiring diagram it is hard to troubleshoot. You can verfiy there is power to the blower, if there is...... then take an amp reading to see if it is drawing low or high amps. This determines if the motor is seizing if it above fla amps. Or if it is low amps maybe the squirral cage is loose on the shaft and is spinning freely.
If there is no power to the blower check the relays and curcuit if you have a diagram. A relay may intermidently get stuck open killing the power to the blower.
Hope that helps.
vegita40
11-27-18 09:02 AM
is250smoke
04-23-09 11:06 AM
Chungstyle
SC- 1st Gen (1992-2000)
01-20-06 01:06 AM
Quick Reply: A/C, Heater problem, please help.
