Where is the AMP?
Old 05-03-05, 07:55 PM
mamaya3367
mamaya3367's Avatar
Default Where is the AMP?
Hello Everyone,
I have a 94 LS400 with a NAK stereo. My front speakers are staying on after the car is off and draining my battery. I think its the amp. I found the sub woofer amp, behind the rear seat drivers side but I believe there could be another. I have looked in the following areas with no luck. I posted earlier under title "battery draining". I didn't know if to continue the same thread or start another. Anyway any help would be appreciated.
1. I looked in the trunk below the CD players.
2. I looked under both front seats.
3. I looked In the glove compartment.
Old 05-03-05, 08:34 PM
nthach
nthach's Avatar
Originally Posted by mamaya3367
Hello Everyone,
under the CD changer.
Old 05-04-05, 04:55 AM
mamaya3367
mamaya3367's Avatar
I removed the CD changer. No AMP found.
Old 05-04-05, 06:59 AM
Macc
Macc's Avatar
Don't know whether this will help. On my 92LS, the amp is in the trunk, behind the back seat in the upper left. Had to take a couple of clips off that hold the liner in to get to it. You might try looking in there.
Old 05-04-05, 08:14 AM
mamaya3367
mamaya3367's Avatar
You’re correct, there is an amp. I disconnect it and the sub woofer (back center speaker) turns off. There seems to be another amp that powers the door speakers.
Old 05-04-05, 10:51 AM
rrgone
rrgone's Avatar
I know you say you've already checked under the cd changer, but the info at this web site indicates that's where your amp is located:
http://www.carstereohelp.com/stereor...400CDChgrR.htm
Not to hijack your thread here, but I'm interested in the resolution to your battery draining problem. My 1998 LS does this too. The previous owner took it to the dealer to check for parasitic current draw and was told that it was within specification. So he installed a Priority Start Battery Protector just before selling to me. I haven't had any problems.
For your information my mom's 1991 LS also drains the battery if it's not driven for a week or so. She tells me that it drains much faster if it's parked with the doors locked.
Good luck and would appreciate an update if you figure this out!
-Tom
Old 05-04-05, 06:38 PM
mamaya3367
mamaya3367's Avatar
Hello Everyone,
I found the amp I had to remove the stereo and found it attached to the back of the unit. I need to send it out for repair. Anyone know of a place in TX that will do a good job?
Tom,
My battery draining problem is due to my amp not turning off when the car is off. The speakers remain on, therefore draining the power from the battery.
hang3xc
03-04-20 04:56 AM
Daspyda
12-19-16 08:00 AM
ken.iritan
04-02-07 10:52 PM
andy2003si
01-24-05 10:33 AM
Baker Bootleg
06-08-04 02:47 PM
Quick Reply: Where is the AMP?
