99 LS400 Dash Light malfunction
The battery went dead on me and after a jump start the dash light isn't on anymore. Has anyone had this problem? Did the jump start burned the dash instrumentation?
Originally Posted by GRAND_LS 4
Did you by any chance connect the terminals the other way around?
If you did, then you blew your main fuse, and NOTHING in the car will run. If its something else, then check the rest of the fuses, if all are fine, then try and reset the ECU by pulling the fuse.
pcrea
10-28-13 01:46 AM
SuicidnS13
07-31-12 11:20 AM
