DIY Guide for Lower Ball Joints
Old 03-05-05, 09:15 PM
Majkmil
Majkmil's Avatar
Is this the same procedure for my 98 LS? Thanks
Old 03-08-05, 04:08 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Anyone.....?
Old 03-23-05, 01:09 AM
damon
damon's Avatar
Default Great Post!
Changed mine today. Got some pro garage help that cost $50.00 on top of $85.00 in parts, but I am very happy w the results. One side was a ***** , the other took about 8 minutes.
damon
94 LS 400 168,032 miles
I know my way around an LS but am damn sure not a mechanic. It would have been painfull for me to hit steering & suspension components that hard!!
My LS most likely does not appreciate me hitting City ******* at speed either!!
no more hollow thunk when I hit road rasch!!
Old 03-23-05, 01:34 AM
PHML
Master Thread Closer!!
PHML's Avatar
Oversteer....
U da man....great pics....and easy to follow write up....thanks a bunch.
Pete
Old 04-09-05, 04:29 PM
Montalvo
Montalvo's Avatar
Thanks!
I went to Luxury Motorsports today for an oil change (50K service) and alignment. They said I need the ball joints replaced and quoted me $340.
The ball joints shipped to me are $100. I think that if I was able to lower my Lightning and all my Mustangs, I should have to problem swapping these.
Old 08-17-05, 11:10 AM
RA40
Super Moderator
RA40's Avatar
What was the approximate work time involved? The procedure looks straight forward that I may attempt it.. Is an alignment suggested after doing this swap?
LMS quoted me ballpark $325 for the lower ball joints.
The dealer was $500.
Thanks.
Old 08-17-05, 02:47 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by Montalvo
Thanks!
wow, for 210, I had my lower ball joints, outer tie rods, and stablizer links changed. They also installed my L-sportline springs and shocks. But thats labor only, im not sure if you meant parts + labor.
Btw, the lower ball joints were $115 if im not mistaken.
Old 08-17-05, 02:48 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Thanks.
Wish i could advise you, but I changed so many parts at once, Im not sure which threw off the alignment, but Im pretty sure it was mostly due to the outer tie rods.
Old 08-17-05, 08:47 PM
sha4000
sha4000's Avatar
Thanks.
you shouldnt need an alignment after you change the lower balljoints unless they they mess with another suspension part like outer tie rods but then all you wuld have to do is mark the spots on the tierod before you remove them like he stated in the instructions
Old 08-21-05, 08:11 PM
deanbrown
deanbrown's Avatar
This is a bit of a newbie question, but what are the symptoms of a ball joint going bad? I've never had one go bad on any of my cars.
Dean
Old 11-06-05, 05:40 PM
Lexizm
Lexizm's Avatar
The DIY write-up was great, well done. I've worked on cars before when I had my mustang, so I'm not afraid to tinker with the car a bit. It wasn't hard at all. The one thing I must say is that you must get the the tool (Pittman Tire Rod End Puller) at AutoZone or some other place. It was a life saver. I can't imagine doing this job without it. The first one (driver side) took me a while because I broke a adapter and had to go to the store waaaay across town. Suggestion, always use 1/2 inch rachet and sockets; I learned the hard way. Oh, also the 'big/large' bolt under the the ball joint for GS's is a 17 or 19mm, 19mm I believe, not a 27mm. Other than that,everything was dead on. Great DIY post
Check my post:
https://www.clublexus.com/forums/sho...2&page=5&pp=15
Old 07-12-06, 10:21 AM
ARISTO 161
ARISTO 161's Avatar
awesome write up!!!
now i don't need to ask for the copy of the repair manual!!!!!!
thanks man.
now i can go and do my own. good thing someone told me about this thread, or else i would have tried posting it up ;p
Old 07-12-06, 02:51 PM
Suneet
Suneet's Avatar
Never saw this thread before, but it seems like very useful info. I'm thinking of doing my CA bushings soon. I thought I would take out the CAs, remove the bushings myself, and go to a shop to see if they can press in the new ones for me, and then reinstall the CAs. Should I do these ball joints also at the same time?
Old 07-12-06, 05:38 PM
Lexizm
Lexizm's Avatar
Well I would say it really depends on how many miles are on your car. If I was going to have the bushingspressed out and replaced, I would definitely go for it bro.
Old 07-12-06, 06:59 PM
Suneet
Suneet's Avatar
I've got 183K miles on my car. I'm going to press out the bushings myself using the "drill and crack" method, and get them pushed in by someone else.
So these are the ball joints that are in the lower control arms? I was under the impression that you had to buy new control arms, and that you couldn't buy the ball joint seperately? What about the upper ball joints? Are those available?
Quick Reply: DIY Guide for Lower Ball Joints
