Rewiring your fogs in 95 LS400
Old 05-08-05, 04:25 PM
spinout180
spinout180's Avatar
Well, I did this on a 95 without HIDs, so not sure how it converts on a 98-00 with HIDs.
When you dropped the relay and hooked up the four wires to the original locations did the fog lights still work? At that point you wouldn;t have changed any wiring, just extended it to the relay. It SHOULD still work there, if not them something went wrong at the beginning.
Darren
Old 05-09-05, 09:28 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Darren
When I extended it at first, it worked just fine. Then when I changed the green wire, things started going wrong, like only one side of the HID's would work, and fogs wouldnt come one with HID's at ALL, it was like a either or situation. I tried ALL kinds of wires, I was working on this for over 6 hours, but no go
I wonder what could be the difference?
Then I looked at this tutorial from a 98 GS, seems a little more involved, but im wondering if that’s the only way to do it on 98+ w/HID's:
http://lexusmodz.netfirms.com/GS_DIY/fogmod/
Old 05-09-05, 10:32 AM
spinout180
spinout180's Avatar
Hmmm..... ya know, without a better step-by-step description of what was attempted and what happened each time I can't really be that much help.
It IS possible that the relay was rewired for 98-00 cars, I will see if someone locally with an HID-equipped LS will let me get into the wiring.
D
Old 05-09-05, 05:22 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Well see, when I used the hot wire from tail light fuse, they would turn on when my parking lights are on, but off again when the HID's are on. But when the HID’s turned on, the tail lights turned off as well.
When I used a constant hot wire, (windshield wipers) they were on anytime the ignition was set to ON, regardless of what position the stalk was in. Then again they go off when HID's go on.
In all instances, they actual fog light stalk would not control them, they were constantly on, even if they fog light switch was set to off.
Then when the green wire wasnt connected to anything, not only were the foglights not operational, but only ONE of the HID's would work.
I tried to tap into a wire instead of a fuse, but the results where the same.
I guess Lexus tried thier best to make sure someone wouldnt turn on fog lights without the headlights. But Im going to try and make it work, any suggestions would be very helpful.
Old 10-04-05, 05:39 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
BWUAHAHAHAHAHAHAHAH
i shall revive an old thread merely to ask my question!!
is there any way i can modify this mod(?) so that the foglights are controlled from a separate switch?
Old 10-04-05, 06:26 PM
spinout180
spinout180's Avatar
Yes, you can... the wire at the relay that comes from the OEM switch could be removed and you could wire it to any switch you wanted... just ground the other side of the switch.
Old 10-04-05, 09:21 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by PureDrifter
BWUAHAHAHAHAHAHAHAH
Yes, but why would you want to do that? You use the existing OEM switch and make it independent of all other lights.
Old 10-04-05, 09:29 PM
PureDrifter
BahHumBug
i could do that.....but my oem switch is broken.
i will replace it eventually, but right now, i could use the $60 elsewhere(trying to hardwire iPod to OEM Nak Stereo.)
Old 10-04-05, 09:41 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
oh ok, just thought I could save you the hassle.
Old 10-04-05, 09:53 PM
PureDrifter
BahHumBug
lol, np.
my current project is almost ready to be implemented. i only ned to figure out where im drawing power from behind the radio and how im going to power the iPod Dock so i can charge the iPod. any idea if the antenna cable in our cars connects into the back of the HU?
Old 02-21-06, 11:47 PM
Caoboy
Caoboy's Avatar
i know this is an old thread, but does anybody know if this works with a 92ls400 with HID? i searched and searched, and this thread was the only one that came up remotely related. i lost my fog's when i put in HID.
Old 02-21-06, 11:58 PM
spinout180
spinout180's Avatar
Sorry, but this topic will only apply to 1995-1997 LS400s, and possibly 1998-2000. The car was redesigned in 1995 so nothing before that will be applicable.
Old 02-22-06, 10:49 PM
Caoboy
Caoboy's Avatar
so where's all these threads the original poster was talking about how people were rewiring first gen foglights? i cant find ANY thread related to it. a little help would be nice..
Old 02-22-06, 10:53 PM
spinout180
spinout180's Avatar
I simply typed "rewiring foglights ls400" in Google and it came up with several results. That was some time ago, they may not be around anymore.
Old 02-22-06, 11:03 PM
Caoboy
Caoboy's Avatar
yeah i cant find any threads on it at all. google is no help. links are broken or just lead to some random thing. does anyone know where the relay for the foglight is on the first gen? i would really like to do this, it sucks not having foglights.
Quick Reply: Rewiring your fogs in 95 LS400
