Tire Recommendation for 18x8
Old 06-02-12, 06:48 PM
BLK98GS3
BLK98GS3's Avatar
Default Tire Recommendation for 18x8
Hey Guys,
I just picked up a super clean 2000 Ls400
Its green.....not the best color but its pretty clean and I got it for a GREAT price.
Anyhow..... I picked up a set of TSW 18x8 with 40mm offset.
I dont plan on lowering the car. I like the stock feel of the car as it is. What is a good tire size for me to go?
235/45/18?
or
245/45/18?
or other suggestions....
Stock tire size is 225/60/16.
Thanks in advanced guys. I ll get pics up shortly.
Old 06-02-12, 06:50 PM
TheBry
TheBry's Avatar
245/25/18?
I have 245/40/18 on 18x8
Old 06-02-12, 07:28 PM
BLK98GS3
BLK98GS3's Avatar
Originally Posted by TheBry
245/25/18?
lol. 245/45....thas what i meant.
how is the ride quality on your set up?
are you lowered or stock?
Old 06-02-12, 09:38 PM
lev00221
lev00221's Avatar
The correct size is 245/45/18 if you want to keep the OEM outer diameter measurement for wheel/tire together. This will give you the best ride quality and ensure that you don't have speedometer error.
Old 06-03-12, 02:38 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
if you're lowered the 45 series will rub, go down to either a 225/45 or a 245/40 tire.
did you check to see that the wheels cleared the front brake calipers?
Old 06-03-12, 10:03 AM
BLK98GS3
BLK98GS3's Avatar
Did not test fit yet. It's 18x8 w 40mm offset. Do u think it will rub?
I'm leaning more towards the 245/45
Old 06-03-12, 10:39 AM
python
python's Avatar
18's wont look right on that car..2 small. u better mount one on the car and take a look at it first
Old 06-03-12, 10:51 AM
SpencerT
SpencerT's Avatar
Its hard to believe since the stocks are 16's
But python is correct. 18's look way to small with the stock ride height
rear: 245 40 18 front: 225 45 18
they look small and the fender gap is large
lowered with tanabe df210s
Id still like to go up a tire size all the way around but the fender gap is gone
Old 06-03-12, 11:52 AM
RA40
Super Moderator
RA40's Avatar
245/45 at stock height.
18's are fine and comparing them to the stock 16's the +2 wheel sizing is ok. 19's look nicer as do 20's. Rubber for 19's isn't that wallet friendly compared to 20's. Old school there were plenty of 17-18" wheels combos that look good, depends on how you fit them up in the execution.
If the tire diameter is 26.2-26.7" there is about a 3" gap in front on properly working shocks. Back is about 2.5". That won't change unless you fit a tire with a different diameter from stock. Of course lowering improves the appearance.
Old 06-03-12, 09:09 PM
BLK98GS3
BLK98GS3's Avatar
Awesome guys. Thanks for the advice.
I am not looking for anything super fancy. I just think the stock wheel is super plain. Anythings gotta look better than stock.
Old 06-04-12, 01:06 AM
TheBry
TheBry's Avatar
The ride quality is good, and I'm lowered.
Old 06-04-12, 01:23 PM
SpencerT
SpencerT's Avatar
245 45 18 will rub when your how low?
Only with coilovers or do you think they would rub with my tanabes too?
Old 06-04-12, 03:46 PM
PureDrifter
BahHumBug
it will probably rub(in the front). i rubbed way back when i was on 18s and my old LSportline suspension.
Old 06-06-12, 03:18 PM
Lexuses71
Lexuses71's Avatar
I'm running 245/45-18 @ stock height. Smooth ride and on my car, it doesn't look like a huge gap between fender and top of tires. Ride quality on this car is very important to me.
STREETGS
10-13-21 04:34 PM
infiniti24
SC- 1st Gen (1992-2000)
13
03-18-10 10:55 PM
ecstaticSC
Wheels, Tires & Brakes Forum
03-30-09 09:42 PM
ISFjimmy
04-04-08 11:39 AM
fangtl
11-04-06 08:52 PM
Quick Reply: Tire Recommendation for 18x8
