Rpm @ 60 Mph?
Old 05-25-04, 04:14 PM
gmcloud
gmcloud's Avatar
Default Rpm @ 60 Mph?
I've noticed on my 2001 LS430 that the RPMs seem a bit too high at 60 MPH -- around 3000. Seems to me that it should be in the 2000 range.
Any thoughts?
Thanks,
-gene
Old 05-25-04, 04:22 PM
pvo
pvo's Avatar
Mine is around 2000. I don't know what could be wrong though. Sorry.
Old 05-25-04, 04:30 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
I don't know that I've ever looked for this on a LS430.... is there an overdrive selector or just put it in 5th gear on shifter? Try to see if you can tell what gear you're in at 60.
Old 05-25-04, 04:42 PM
pvo
pvo's Avatar
I don't know if 2001 has it or not but I don't see it on 2004. Also found this on page 305 of the manual: "Always use the D position to improve fuel economy and quiet driving. Only in this position, shifting into overdrive gear is possible. However, when the engine coolant temperature is low, the transmission will not shift into overdrive gear even in the D position."
Old 05-26-04, 03:25 PM
persian451
persian451's Avatar
thats bit high. mine doesnt go that high for 1991 LS
DomeSL
03-20-16 05:30 PM
LEX ES300
07-26-15 09:26 PM
Tsmith1982
05-05-14 12:02 PM
egs21
01-10-14 06:13 AM
nehal51086
12-04-06 01:50 PM
Quick Reply: Rpm @ 60 Mph?
