I keep popping fuses!!?? (97 LS)
Old 05-04-04, 01:03 AM
Bj(CA)
Bj(CA)'s Avatar
Question what the ****!!!! i keep popping fuses!!??
ok, i get out of my car(97 ls coach) and turn on press the lock on the key fob, no workie. so then i hit the power lock switch, no workie, so i tried to lock with key, no workie, only the drive side locked, so i went to work. after work, i noticed my power mirrors and seat memory no workie too, so i said ahh haa!! it must be a fuse. i looked, but couldn't find the right one. checked the all and it happened to be the "sec horn" fuse that controlled all of that. kool so popped in the spare 7.5 then i adjusted my side mirrors and it stopped , ****, fuse blew again, so i took the spare from the highlander, and again it blew. now what the hell is causing this? i have no extra 12 goodies installed on the car. i didi notice that i had the ac on full blast, but why would a lex pop a fuse at full blast ac, while adjusting the mirrors!!??? sorry for ranting and grammar, just need to vent and need some help.
ps- can i step up the fuse to a 10 amp??
thanks
bj
Old 05-04-04, 09:00 AM
Bj(CA)
Bj(CA)'s Avatar
umm any advice before i leave for work?
Old 05-04-04, 04:38 PM
Strida
Strida's Avatar
Are you sure its a 7.5 fuse? And one fuse controls the mirrors, memory seat and door locks? Im not yet familiar with the LS but I'll check my fuses tomorrow. Its kinda odd that only one fuse controls all of that.
Old 05-04-04, 09:40 PM
Bj(CA)
Bj(CA)'s Avatar
thanks dude, yea, also controls clock, and the power steering adjustments, yea make no sense to me, allll that on one 7.5 fuse!!?? i mean i had no problems until now.
thanks
bj
Old 05-05-04, 12:06 PM
Lexkost
Lexkost's Avatar
Door lock is by itself 20amp fuse.
Power Seat are on a ECU-IG 15amp.
SEC. Horn is the theft system and on a 7.5amp fuse
Doe not up fuses find the problem !!
Old 05-05-04, 07:47 PM
Bj(CA)
Bj(CA)'s Avatar
hey bro, it happened again this morning!! blew two fuses back to back, but this time i had the ac off!! now it only pops when i adjust my mirrors!!! and again, it just blows the "sec horn" and when blown, the doorlocks, powermirrors, clock, power steering adjustaments do not work and also the memory seats clears its "memory" . unfortunatly i did up the fuse to 10amp just ot make it work, i now have my mirrors adjusted and going to re install the 7.5 fuse. what can be causing this?? is there a self test i can do??
thanks
bj
Old 05-05-04, 08:24 PM
Lexkost
Lexkost's Avatar
Which mirror did you try to move Right of Left when fuse blew ? If fuse blows when trying to move either mirrors may be mirror switch bad? If fuse blows only on one mirror maybe a short that mirror.
.......But seeing other things are also blowing fuses , I would look under dash by mirror switch and you may find other things bad.........................Has this car ever been stolen ?
Old 05-05-04, 10:03 PM
Bj(CA)
Bj(CA)'s Avatar
hey, umm good q-tion i think it was the driver side, mirror?? i dont think the car was stolen before, plus it came neg. under carfax report. i thought trasponder ked cars are very hard to steal??anhwho, iam really not good at diagnosing stuff like that, iam a "dash/clip breaker", verry impatient. on the other hand my buddy who is a mecp cerftifeid installer would know how to find the problem, but he;s in nj ans me in cali
ps- i appreiciae you responses to my post
bj
Old 05-06-04, 01:57 PM
RA40
Super Moderator
RA40's Avatar
Let us know what it turns out to be. The multiplex communication system is complex and most testing procedures involve checking voltage at the possibly offending connector. The Lexus dealer will have a diagnositc for this so this may be the fastest way to get this taken care of.
Good luck.
Old 05-06-04, 06:07 PM
stelios
stelios's Avatar
make sure you have the right fuse in if that does not work it might be a short somewhere
simplecar
04-30-19 08:23 AM
AdamR2
09-15-14 08:40 AM
corolla95
Florida Lexus Club
07-13-10 01:13 AM
RedSC
05-25-09 02:36 PM
2.5tsoarer
SC- 1st Gen (1992-2000)
04-29-05 09:17 AM
Quick Reply: I keep popping fuses!!?? (97 LS)
