not enough power...
Old 12-13-03, 02:18 PM
Lexs400
Lexs400's Avatar
Default not enough power...
My 93LS compared to my friend's 92LS seems to have nowhere the same power that he has. I reset my ECU which made it a little better but still nowhere close.
Any other ideas ? keeping in mind that his is stock as well with more mileage than mine.
thanks.
Old 12-13-03, 05:27 PM
5ofakind
5ofakind's Avatar
First order of business would be to do a compression check on your engine. Fuel injector cleaning, throttle body cleaning & a general tune-up would help as well ( wires & plugs ). Just a suggestion.
Jeff
Old 12-13-03, 06:09 PM
lspower
lspower's Avatar
where could i get my fuel injectors cleaned? how much est?
Old 12-13-03, 06:14 PM
persian451
persian451's Avatar
buy a can of BG-44k, that should do the trick
Old 12-13-03, 08:05 PM
RA40
Super Moderator
RA40's Avatar
I'm with 5ofakind: compression check, injector cleaning and throttle body clean. If you haven't given it a tune-up at the recco'd intervals, that is also a suggested fix. Check air filter and while you have the air snorkel off, look down between the condenser and radiator for debris.
Is your tranny slipping?
Old 12-14-03, 02:23 AM
Lexs400
Lexs400's Avatar
The tranny's not slipping.
the car has 67K miles . do you think a compression check would help ? I always thought that was helpful in case of high mileage engines.
As for the injectors, well is that something the dealer will do because I've already tried the injector cleaners but didn't help much.
I also read in another thread that changing the plugs is not really a piece of cake in this car. is that true ?
as for the air filter, I will go ahead and get that changed in the meanwhile. While I'm at it, where's the air filter located ?
thanks again !
Old 12-14-03, 01:08 PM
RA40
Super Moderator
RA40's Avatar
At 67K miles, that is practically new, I wouldn't suspect anything regarding engine compression. Stop go traffic and or short runs where the car does not warm up to operating temp can be hard on it. Seems to me, it needs a good long road trip.
The plugs aren't that bad to change. Remove the intake cover and inlet piping, remove the plug covers and simply replace the plugs. Granted it isn't as easy as some cars, this took me about an hour to do. The air cleaner is on the passenger side just behind headlight. Both these are at the 60K service interval anyway.
Old 12-15-03, 12:29 AM
Lexs400
Lexs400's Avatar
Thanks Mike.
I'll try taking it on a long trip one of these days and also get the air filter/plugs changed.
Old 12-15-03, 10:34 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
Disconnect your battery for 5 minutes, drive the car agressively for 15 minutes or so and see if it improves. Our transmission is a self-learning so if you have been driving the car slow most of the time it will adopt to that driving style.
Old 12-16-03, 07:13 PM
gs400998
gs400998's Avatar
93 is also a little heavier than the first-gen LS4. Car & Driver has the following stats for 93 LS4: 0-60 8.3, 1/4M 16.3. 91 LS4 0-60 7.9, 1/4m 15.9. 93 weighted 3,998 lb and 91 weighted 3,837 lb
Old 12-17-03, 01:23 AM
Lexs400
Lexs400's Avatar
hmm interesting. I didnt realize 0 to 60 for the 90LS is quicker than the 93. that's a shame !
mrtphan
Performance & Maintenance
08-15-13 06:54 AM
Kanderson1
10-31-12 07:18 PM
giolex300
04-12-12 10:56 AM
Cwall
RX - 1st Gen (1999-2003)
12-11-09 10:47 PM
GlobeCLK
06-24-01 05:32 AM
Quick Reply: not enough power...
