no heat
no heat
hey guys. I was power washing the undercarriage of my ls (I do this once a year in the fall) to remove all the dirt and debris. It is nice and clean.
Suddenly I dont have any heat in the car. If i set it to the AUTO climate control setting and put the temp up to MAX HOT I dont get any air flow. If I manually set it to MAX HOT and set the air flow to HI, I get full air but no hot air. Is this a coincidence, or could I have messed something up that controls the heater during my power washing adventure???
problem solved
It turns out that when I flushed my transmission fluid using the method where you disconnect the hose to the radiator, I must have lost some coolant during the procedure. All I needed was to add about 1/2 gallon of fluid and I've got my heater working again. Yes I feel like a tool! sorry...
mfalcon
10-29-16 06:04 PM
