Retrofit from C-class
Hi All,
Not sure if this is the right section, but I am looking to retrofit a projector onto a cbr600rr. I have a projector from a C63 with the lights and ballast. I have heard I can purchase a universal ballast to power the light, but looking at the bulb/connectors I am a bit confused where to go.
The bigger connector is the factory wiring harness and I have no idea where it goes. Ideally Id like to keep this bulb as its a osram (which I hear are the best). From the motorcycle itself, its a pretty simple Pos/Neg power plugs. I do have the option of going to a constant on or using the "highbeam" switch to have the option to turn on/off.
If its more work to get this projector to work then I guess ill dump the project, but any help is greatly appreciated!
mcanlay250
09-30-11 05:37 PM
BinaryJay
03-24-10 02:13 PM
