2012 isf headlight conversion issue
So I was following the diy thread too swap to the 2012 headlights stripped version on my 08 isf. I uninstalled everything swapped ballast and bulbs tested the leds by applying 12v to the connections on led board and they work fine but when I applied the power to the pins on the harness which should be the led pins it didn't work. Than I went to hook up the harness to the harness on the car to test the rest of the headlight before cutting and splicing the wire but my low beams, high beams and drl wouldnt turn on.. I didnt have my drl turned off at dealer yet. The turn signal worked. Also when I turned them on the led flickered. Any help would be appreciated. Is it possible that since I didn't have the led wired to the fuse for power they were trying to draw power and that's why they flickered and the rest ofthe headlight wasnt getting any juice. Or is it possible the pins on the headlight harness aren't matching up with my car harness? They aren't the Sewell lights.
jeepguy
CT 200h Model (2011-2017)
13
11-12-18 01:01 PM
