LS430 vs Ls460 Retrofit for 2GS
Old 02-22-10, 10:20 PM
Jasbmo
Jasbmo's Avatar
Originally Posted by LiCelsior
01-03 LS430s were not projector housings, only 04-06.
LS430s are known for their wide output due to their shroud.
this picture will win you over .
vehicle equipped with LS430 projectors
this picture was overexposed making everything brighter. but in any case, the LS430 has a super wide throw.
Old 02-23-10, 10:24 PM
GS3Tek
GS3Tek's Avatar
I remembered showing that picture also and someone said it was photoshopped
Old 02-24-10, 06:31 PM
djyoshi626
djyoshi626's Avatar
Does the LS430's 04-06 retro to the SC? I've read about the SC430 retroing into 1SC and of course the X5, but I'm really liking the 04-06 430's output. I've driven in an 02 430 and I like that output as well, but it seems this is... brighter in a nutshell?
I plan on doing this in a 98+ 1SC by the way... hopefully with those glass headlights rather than plasticy
Old 02-25-10, 02:38 AM
0x21
0x21's Avatar
those projectors are way too big, they will not fit in the sc housing
Old 03-01-10, 04:12 AM
JnC
JnC's Avatar
Overexposed? Yes, Photoshopped? No
Originally Posted by skizot
So I finally got around to taking some decent output shots. And let me tell you, several of these really do rival Hak's famous "165+ degrees of driving pleasure" (LS430 / Highlander) shot. =P~
Also, after taking my car outside city limits I am truly amazed at these projectors. I can honestly appreciate them much more after seeing their full capabilities. I guess before when I've posted about how I didn't think they were that bright was because they were being drowned out by the super yellow high wattage street lights everywhere. They're definitely bright enough.
Anyways, on to the pictures!
Just a normal driveway shot:
The following shots were underexposed to show the perfect alignment between low beam and high beam.
Low Beam:
Low Beam and High Beam perfectly aligned:
Now for the awesome shots. :P
Full-sized image: http://skizot.com/gallery/d/3497-1/DSC_0066.JPG
Full-sized image: http://skizot.com/gallery/d/3518-1/DSC_0073.JPG
Full-sized image: http://skizot.com/gallery/d/3539-1/DSC_0080.JPG
Thanks for looking.
Old 03-01-10, 11:42 AM
tpham86
tpham86's Avatar
oh my god..
Old 03-04-10, 03:31 AM
JnC
JnC's Avatar
Originally Posted by tpham86
oh my god..
Old 04-05-10, 01:49 AM
BIGVIC23
BIGVIC23's Avatar
https://www.clublexus.com/forums/lig...s460-hids.html ... guess this has been discussed b4... my bad. Well.. my post is still better.
Old 04-05-10, 08:19 PM
GS4_Fiend
GS4_Fiend's Avatar
I gotta agree that's overexposure...
Check out my thread, that's how it really looks like. But the pictures doesn't do justice. In reality, it's superior.
Old 10-09-10, 08:03 PM
JamesP909
JamesP909's Avatar
Originally Posted by JnC
Did anyone saved these pictures? The link does not work anymore.
Old 10-09-10, 09:13 PM
1SWTGS
1SWTGS's Avatar
(current set up) pics of LS430 retro with PIAA Super Cobalt 6600K/PIAA Tera 6500k parking lights,50w 3000k fogs cutoff at 50ft. http://www.youtube.com/watch?v=tJBx2uhllDwpics of LS430 retrofit with Garax 8000k cutoff at 50ft ,and 50w 3000k HID foglights LS430 retrofit with Philips 85122+ http://www.youtube.com/watch?v=FhbJr...e=mfu_in_order
Old 10-10-10, 04:14 AM
j three
j three's Avatar
1SWTGS, looks good. Which low beam bulb was the best performing for you?
Old 10-10-10, 04:59 AM
1SWTGS
1SWTGS's Avatar
The PIAA's are the best. current using now.also I also used the PHILIPS 6000K Ultinon (no pic of them)similar to the piaa's but less white and brightness.
Old 10-10-10, 02:28 PM
j three
j three's Avatar
Oh, so the Phillips Ultinon's are less bright and white? From what I read the Ultinon was supposed to be the brightest 6000k bulb. I guess they never put them up against these bulbs huh? Do you have the standard lenses or are they the clear lenses?
I have a 99 LS and I want to do a quad projector setup, but the 430's are kind of expensive! I'm debating on going with two pair of FXR's on the lower priced end for a quad bi-xenon setup, or LS430's for low's and 2010 460 bi-xenon's on the upper end. All would have clear lenses. I like the 2010 460's because it has the chrome shroud and doesn't have that bug eye'd look of the 07-09, and would have a smoother more factory appearance. Not to mention it would be cool to have all Lexus parts v.s. the FXR's.
On the other hand the price of the FXR's are unbeatable, $135 a pair. The 430's and 460's are going for around $350 a pair, so I think i am going with the FXR's for $270 for two pairs, unless I score some crazy deals on the other setup.
Edit. Holly smoke those PIAA's are a grip!!!!!!! I was just doing some looking around and the average price is around $370!! If you got them cheaper do share. LOL!
sc-fsport
02-28-16 03:27 PM
handoverfi
Lighting
21
06-23-09 04:22 PM
BLKSC400
05-08-09 09:52 AM
808d-no
Lighting
07-27-08 03:08 PM
GSteg
12-17-06 01:46 PM
Quick Reply: LS430 vs Ls460 Retrofit for 2GS
