Clear Turn Signal in REAR.....?
Check this out: https://www.clublexus.com/forums/sho...threadid=38638
If you Need more info feel free to ask.
Light
Hey there, now I have xenon parking, regular, and bright headlamps. I like it a lot. And it goes well with my clear corners. how did you do the tail light. How did you take it out? how did you get into it? is the white a new piece or just removing of orange like the clear corners?
https://www.clublexus.com/forums/sho...threadid=38441
The link above is info for clearing the headlights, the tail lights are about the same, the only difference like I said on the other thread is the outer corners of the tail lights have little tacks that fuse the light together, these must be removed before the light is wiggled open because it can cause you lens to crack! Be patient and be careful! Take your time. The cool white lens that I replaced the ugly orange with is already inside your tail light, you just snap that one off of the back of the orange one vary carefully. Glue is used to hold every part together inside your tail light so you will need to take everything apart piece by piece. Unfortunately the lenses and assembly inside the light are not held together by heat sensitive glue like the outer taillight housing and you need to pry things apart without cracking things. I found that using a flat head screw driver to slide between the orange lens and clear lens helps snap it apart plus there are interlocking tabs on the orange and clear lens that you will need to push apart. Once apart you just simply put the clear lens back in without the orange. This lens since its by it self is a little smaller and will need to be tacked in place on the black insert using a little super glue. I hope this and the others threads will provide any one with enough information to tackle this mod.
