CCFL Dome lights & License Plate Lights
Old 10-14-08, 03:30 PM
Debonair
iModerate
Debonair's Avatar
Default Trunk CCFL's while i was at it.
I also had an extra dual 4" inch kit that installed in the trunk in about 20 minutes.
Old 10-15-08, 05:44 AM
iazybandit
iazybandit's Avatar
Nice! First time I saw cathodes in the trunk.
What you use to plug into the trunk? Granted, I put this in my Camry, it was simply plug and play. It works with any car that uses 194/921 bulbs. In the process of making them work in 3022/3175 festoon bulbs. Just need to order parts. I have some laying around if anyone is interested.
I also soldered a fuse holder and added a slow burn fuse. The inverter I have pictured is the cheap one where if you plug it in the wrong way, it will blow out the slow burn fuse as well as the inverter. The ones I have laying around have built-in reverse polarity. So if you plug it in the wrong way and it doesnt work, just flip the plug around. No need to replace fuse or inverter.
Old 10-15-08, 07:07 AM
Debonair
iModerate
Debonair's Avatar
Those look real nice and bright. I am sure the 12" are much brighter than the 4" i used but I already had them and I the light they produce is more than enough for me.
I spliced into the factory light wiring. The inverters I used were of the "cheap" variety, i guess, but that's where a simple multimeter come in to play. No need to dummy proof them for me - I'm no dummy.
Old 10-15-08, 07:08 AM
Debonair
iModerate
Debonair's Avatar
Originally Posted by L3XOTIC
Props for all the hard work and effort
Thank you.
Old 10-15-08, 08:50 AM
iazybandit
iazybandit's Avatar
Thats one thing I dont want to do...splice into any of the factory wiring. Thats why I opted for the easy plug and play option
Old 10-15-08, 10:45 AM
MPLexus301
MPLexus301's Avatar
Wow you have done a really nice job. I wish I had the guts/*****/know how to cut into my car like that because I really want to do the dome lights and interior trunk light.
Old 10-15-08, 01:12 PM
Spyder78
Spyder78's Avatar
thanks for the write up for the trunk!! Gotta to modify your install cause my system would crack the cathodes in a minute back to the drawing board.
Old 10-15-08, 01:53 PM
Debonair
iModerate
Debonair's Avatar
I really should say I tapped into the wiring - not spliced into it since i cut nothing. I used these oh-so popular T-Taps that just crimp right over the existing wires. Everything else was saved and could be returned to stock at any point. No cutting required. Lots of 3M double stick tape is though.
Old 10-15-08, 08:11 PM
3rdelement
3rdelement's Avatar
i wouldnt worry about the ccfl,they are durable! i ran my 2 15's and 1000watt amp for 2 yrs with no problems.
when i get home i need to swap them into my new is300
Old 10-17-08, 06:36 PM
Spyder78
Spyder78's Avatar
already broke 3 sets in the trunk.
Old 10-18-08, 02:10 PM
timywong
timywong's Avatar
I used SMD led strips in my trunk now. CCFL broke cuz of vibration i think.
Old 10-19-08, 12:01 AM
Debonair
iModerate
Debonair's Avatar
I have a question for both of you. Did they break from something hitting them, audio system vibrations, or rough ride vibrations(dropped)?
Old 10-19-08, 02:04 AM
Spyder78
Spyder78's Avatar
audio got 2 12" type R pumping about 1000 watts rms. So audio owns me.
Old 03-25-09, 11:40 AM
RandyJ
RandyJ's Avatar
Hey
That look really nice!!
I'm new to the club
I would like to add the lights on the lexus
Where can I get the bulbs from & can you tell me what bulbs I need?
Can't wait to see how it turn out
Thx
Old 03-26-09, 05:42 AM
burgy
burgy's Avatar
Look great, but the last thing I want to do is make it easier for the Cops to read my license plate. I have done full LED in all dome lights and door lights on both my cars. Great job and nice install!
Quick Reply: CCFL Dome lights & License Plate Lights
