Finally installed the chrome 'Angel Eye' Headlamps
Old 12-18-07, 08:34 PM
  #46
gsCrazy
gsCrazy's Avatar
hey olu, you think you can hook up the halos and take a picture of how they look at night.
also are you using the spacers you made and what bulb size fits in those headlights? does the 9006 size fit?
Old 12-19-07, 06:44 AM
  #47
Olu
Olu's Avatar
Sorry, I'm done taking the lights out until it warms up again. It's too cold in my garage to do any serious work.
I forgot to post pictures of the spacers and mounting of the light bulbs. I'm using 9006 bulbs from an HID kit. The projectors are supposed to have H7 bulbs. I think the light pattern would probably be more even with the H7 bulbs.
Pics:
This is the spacer by itself
Picture of the projector and the shield. As you can see the shield goes down at an angle to the left. That's what creates the flare off to the right.
No spacer
Spacer in place
Bulb secured
Old 12-22-07, 03:21 PM
  #48
Celjesta
Celjesta's Avatar
WOW that came out realy nice...
Old 12-26-07, 02:07 AM
  #49
PHML
Master Thread Closer!!
PHML's Avatar
Thanks for the pics.....so 5/8" spacer will give you the best light output?
Btw...your return ground wire is facing down...right?
Pete
Old 12-26-07, 02:42 AM
  #50
Solo_D33A
Solo_D33A's Avatar
and I need 9006? I'm currently using D2R.... can I use that? or shall I change to 9006?
Old 12-26-07, 05:54 AM
  #51
Olu
Olu's Avatar
Pete
Yes the return ground wire is facing down. 5/8" gave me the best light pattern
These projectors use H7 bulbs. D2R bulb would work, but you'd have to modify it to get the best light output.
Old 12-30-07, 01:55 PM
  #52
nanotech
nanotech's Avatar
So these lights should work perfect for cars with factory HID systems? If so I think ill be getting some!
Old 12-30-07, 02:04 PM
  #53
Solo_D33A
Solo_D33A's Avatar
You want mine? :P I've thought on changing to OEM with AAC halos instead...
Anybody know the difference in height from base between the point of light output of 9006 and D2R? ie if their output point is the same then I should be able to get the same spec off of this tread and work perfectly instead of measuring and cutting as I've got no way to cut and working without a garage for extended periods in -10'C isn't a good idea.
Old 01-02-08, 07:13 PM
  #54
Olu
Olu's Avatar
Check out this thread. nyAristo has his hooked up and there are some dark pictures, but no night shots.
This won't work with oem HID systems. You'd lose your auto-leveling and you'd probably get worse light output with D2R bulbs.
Old 01-18-08, 03:08 AM
  #55
PHML
PHML's Avatar
So outside diameter of spacer is 1"....depth is 5/8" for your 9006 McCulloch HID bulb. I got H7 HID bulb...so I wonder if I need the spacer at all...or depth would be different.
Old 01-18-08, 03:32 AM
  #56
Olu
Olu's Avatar
No it's made for an H7 bulb so you're all set. I suspect you'd get better or at least more even light output as well.
Old 01-26-08, 06:43 PM
  #57
PHML
PHML's Avatar
I just installed mines today....I got H7 HID kit for it....but HID bulb return ground wire was on top when installed...so I just dremel the other side of the HID bulb...and now the ground wires is facing down as it should be....looks like a good beam pattern....will know more tonight....when i do some adjusting. Pics to come.
Pete
Old 01-26-08, 07:46 PM
  #58
Olu
Olu's Avatar
I'll be curious to see how they look.
I uninstalled mine and got these:
LS430 retro fit
Old 01-26-08, 07:58 PM
  #59
kit cat
kit cat's Avatar
LS430 retro!! Looks beautiful!!
Old 01-27-08, 09:28 AM
  #60
natnut
natnut's Avatar
LS430 retro fit
Where did you get these from?
Quick Reply: Finally installed the chrome 'Angel Eye' Headlamps
