Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
I checked my 95 LS headlight assembly today and found 2 bulbs in main light. One for HI and one for LOW. (When you switch to HI both bulbs lit)
Is it supposed to be like that ???
What do I do if I want to replace Low with HID ?
This ad is not displayed to registered members. Register your free account today and become a member on Club Lexus!
Originally posted by Vik I checked my 95 LS headlight assembly today and found 2 bulbs in main light. One for HI and one for LOW. (When you switch to HI both bulbs lit)
Yes, that is correct. You have an H4 for low and high beams. Another bulb also lights up for high beams which is an HB3.
If you want to install an HID kit, I suggest you get it only for the low beams. Getting the low/high beams sounds nice, but I believe revving the HID's up just so you can flash your high beams could reduce the life of the bulbs.
Originally posted by caliness but I believe revving the HID's up just so you can flash your high beams could reduce the life of the bulbs.
Thank you for information
Nothing happens to the lamp when you swithch to or flash Hi beams. Hi/Low system works different way. It's same bulb but it has metal strip with window in it. When you switch to Hi beams small motor inside assembly moves strip to different position. You can get examples if you look on the net. Wiring not a big problem ether. You don't get twice as many wires.
The only thing that troubles me how reliable all this assembly is.
I'm aware of kits with that capability, however, HID's take some time to turn on. So, if you were to flash someone using the hi/lo kit you would have to wait for it to start up and by then you would probobly be on a different freeway! :P
Originally posted by caliness So, if you were to flash someone using the hi/lo kit you would have to wait for it to start up and by then you would probobly be on a different freeway! :P
Originally posted by caliness I'm aware of kits with that capability, however, HID's take some time to turn on. So, if you were to flash someone using the hi/lo kit you would have to wait for it to start up and by then you would probobly be on a different freeway! :P
I think the lights that Vik is talking about is a single projector unit that is used for both low and high. These are like the ones used in Euro cars with BiXenon projectors. Yes, the unit needs to warm up but once you are on the road,the light is already on. "Flashing" would only involve a moving a cutoff shield up to let more light through.
Re: Re: Re: Re: Re: Weird headlight assembly or not ?
Quote:
Originally posted by Neo I think the lights that Vik is talking about is a single projector unit that is used for both low and high. These are like the ones used in Euro cars with BiXenon projectors. Yes, the unit needs to warm up but once you are on the road,the light is already on. "Flashing" would only involve a moving a cutoff shield up to let more light through.
From what I know, bi-xenons require a motor to move the bulb forward when you high beam, that requires time. I could be wrong, though.
Re: Re: Re: Re: Re: Re: Weird headlight assembly or not ?
Quote:
Originally posted by caliness From what I know, bi-xenons require a motor to move the bulb forward when you high beam, that requires time. I could be wrong, though.
I don't think so. I have a set sitting here in my office and the motor only moves the shield.
Re: Re: Re: Re: Re: Re: Re: Weird headlight assembly or not ?
Quote:
Originally posted by Neo I don't think so. I have a set sitting here in my office and the motor only moves the shield.
You're right - motor (or something) moves the shield's window only. If you want to flash your HI's when your lamps swithed off in can be a problem because HID take some time to warm up. Caliness was 100% right when he mentioned it.
If you can't flash your Hi beams when you need it what choice do you have ?
PS:
There is an australian car sign:
"Horn broken - watch for finger " or something like it.
HID's are on as soon as you flip the swtich. The warmup time is the time it takes for the lamps to reach normal operating temperature and the beam color to stabilize. As for the Bixenon projectors, the movable cutoff shield is operated by a solenoid rather than a motor, which makes the operation of switching on the high beams almost instantaneous.
Another issue to consider, however, is that a 95 LS does not have clear headlight lenses. It’s hard to say, but a lens like that could scatter the light so much that there might not be much of a difference between your halogens and HIDs. This would also cause a lot of offending glare to oncoming drivers. You might want to check out www.hidforum.com for more info on HIDs in general.
Originally posted by electro992 As for the Bixenon projectors, the movable cutoff shield is operated by a solenoid rather than a motor, which makes the operation of switching on the high beams almost instantaneous.
Gotcha. Thanks for the correction.
If the Bi-Xenons are used as highs only and are usually off, then yes "flashing" would not be as effective. The point of the cars with them, though, is that they are already on as lows. When you need to "flash", the shield is moved and the light "becomes" the high beam. No warm up.
Originally posted by Neo If the Bi-Xenons are used as highs only and are usually off, then yes "flashing" would not be as effective. The point of the cars with them, though, is that they are already on as lows.
I would say opposite. When you flash not only cutoff shield moves to different position but another bulb lights up so you have more light coming out as well.
If I understand properly even if you have no HI beams you still must have HI's "sort of" working. What second bulb is for ? I'll check with my dealer tomorrow.
Let's see if I can clear up the confusion a little bit. A low beam headlamp takes the beam produced by the light bulb and "cuts off" the top portion of the beam using the cutoff shield. This is done so that the light stays close to the ground and other drivers are not blinded. In the case of a bixenon projector, the cutoff shield is removed, allowing the full power of the lightbulb to shine through. You can see farther with high beams beacuse the cutoff shield is removed, and therfore that top portion of the beam that was removed with the lows is now usable.
That said, a bixenon projector will have no problem performing a flash to pass manuver. The cutoff shield is retracted and the bulb is lit, resulting in an instantenous high beam. However, for Viks particular car, a single xenon projector would be more approiate, since he already has a seperate bulb for the high beams. The single xenon would simply replace his low beam bulb, and his regular highs will remain as they are.
