Key Ignition Light (GS) bulb swap to LED....Lots of pics
Old 05-17-05, 03:11 PM
  #31
engin_ear
Everything in Moderation
engin_ear's Avatar
Originally Posted by GS408
thanks i found them... i will be ordering the #74's... but before I do can you guys tell me which number I need for the lights that go on the lower inside of the doors? I would like to make those match as well.
thanks
they are 168/194 bulbs. you can replace with LEDs as well, no problem fitting.
Old 05-17-05, 03:13 PM
  #32
GS408
GS408's Avatar
Default Appreciate the Super Fast response!
CL
Old 05-17-05, 03:16 PM
  #33
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
thanks
You'll need 194/168 bulbs for the courtesy lights.
Edit: would've been faster, but I was distracted by a phone call while replying.
Old 05-17-05, 04:18 PM
  #34
GS300Rich
GS300Rich's Avatar
The superwhite looks so much better around Key ignition light. THis is a great cheap mod, and it only took a few seconds. Couldnt get any better
Old 05-18-05, 02:45 PM
  #35
chuckb
chuckb's Avatar
wouldn't it look funny with a superwhite bulb in the key hole and everything else stock?
Old 05-18-05, 02:49 PM
  #36
engin_ear
engin_ear's Avatar
Chuck:
Pretty much no matter what you put in there it's OK with the rest of the dash. It might look multi-color for a second, but once you get in and close the doors all the courtesy lights go away. I did mine all in blue LED, and it's really cool when they all fade out and it's back to stock. Prevents things from getting too ricey too. If you do superwhite dome light, door & footwell, the matching key ring will look good.
Jerry
Old 05-18-05, 07:41 PM
  #37
GS300Rich
GS300Rich's Avatar
I changed out my footwell lights to the same led as the keyhole light and I have the polargs in the bottom of all four doors. Yes it might look funny if I didnt do the rest of these lights
Old 05-19-05, 03:40 AM
  #38
PHML
Master Thread Closer!!
PHML's Avatar
No it wouldn't....imo .
Old 05-24-05, 06:09 PM
  #39
GS408
GS408's Avatar
Default glove box doesn't fit
ok so i ordered the #74's and installed them. they look great at night. Only the glove box left, it seems that LED doesn't fit. Anyone else have this problem? or am i using the wrong LED?
Old 05-24-05, 06:19 PM
  #40
rominl
exclusive matchup
rominl's Avatar
no that's the one. it feels loose right? that's the case for mine too. i just put it that way and after putting the lens back on, it seems ok
Old 05-24-05, 07:07 PM
  #41
GS408
GS408's Avatar
Default loose LED
hmm i will try that later on... but mines feels like it doesn't go down far enough because the LED seems to big. So you put it on loose and put the cover back on to hold it in place?
Old 05-24-05, 08:44 PM
  #42
GS300Rich
GS300Rich's Avatar
Mine didnt fit either. I tried putting the cover back on but it wouldnt stay. When I get some time to really get into it I will try to make it fit. RIght now the light is stock.
Old 05-25-05, 12:21 AM
  #43
rominl
exclusive matchup
rominl's Avatar
yeah that seems to be the case for me. i just let it be unless it stops working
Old 06-05-05, 12:38 PM
  #44
golffnutt
golffnutt's Avatar
I would like to replace all of my interior lights (door panels, dome light, ignition light, map light, footwell lights, etc. ) with super bright LEDs that are bright, bright white. Can anyone tell me the model or size of my lights and what model LED would replace each? Also where can I find a source to buy these? Thank you very much for your help.
Old 06-06-05, 08:58 AM
  #45
engin_ear
engin_ear's Avatar
There's a sticky post at the to of this forum on this. Also please search thru some of the recent posts for LED bulb vendors.
Quick Reply: Key Ignition Light (GS) bulb swap to LED....Lots of pics
