LFA Model (2012)
Lexus LF-A Roadster
Old 01-13-08, 01:03 PM
kattanh3
kattanh3's Avatar
Default Lexus LF-A Roadster
UPDATE: I apologize if this is a repost, admins please feel free to remove this thread.
From WorldCarFans:
Detroit Auto Show: Lexus LF-A Roadster Revealed
An "F" logo on each of its front fenders, indicating belonging to Lexus' exclusive "F" brand, and its aerodynamic form set off in a fiery red paintjob, there's little to stop this little number stealing the show this week. After all, that's what its 200 mph lightweight predecessor, the LF-A Coupe Concept, did at Detroit last time around.
Unsurprisingly named 'LF-A Roadster', this concept's as capable as the last. Lopping off the roof has failed to lessen the rigidity and structure strength of the coupe on which the new model is based, with much of the body consisting of lightweight but durable carbon-fiber and aluminium panels. And in conjunction with the same high-revving V10 engine used in its coupe counterpart, performance is naturally in another league. With a 5.0-litre displacement and generating in excess of 500 galloping horses, test-track speeds of more than 200 mph are achievable - thanks partly to a tuned weight distribution placing the engine behind the front axle but forward of the passenger compartment. The engineers are calling it a 'front-mid' configuration. We'll simply call it clever.
Styling comes from that of the coupe concept LF-A, fortunately requiring few aesthetic modifications. A stern member of the L-Finesse design philosophy, the LF-A Roadster has a compact, low-profile front end that tailors to a similarly near-identical rear encompassing rear vents, a sharp tailgate and now more elongated rear lamps. New at the rear is a rear wing that raises at speed for required greater downforce, while cool air feeds the radiators via two large air intakes, which are carried over from its forerunner. Standing only 48 inches tall much like the coupe, a low-profile stance is visually aided by twenty-inch alloy wheels.
With the coupe concept having been given the green light for production in both V10 and hybrid guise only last year, expect crowd reactions and those of press to be a key deciding factor in the approval of any future Roadster model.
Press Release
Detroit, MI - The engineers and designers at Lexus continue to use their groundbreaking LF-A premium sports car concept as a medium for expressing their ideas about what a high-performance sporting vehicle not only can be, but should be. In this latest expression of the LF-A, they have removed the car's top to create a high-performance roadster.
The LF-A Roadster is based on the sturdy yet lightweight carbon-fiber and aluminum body used for the LF-A coupe, which helps maintain the structure's strength and rigidity even without a top.
Like its coupe counterpart, the LF-A Roadster is powered by a high-revving V10 engine that approaches 5.0 liters in displacement. The V10, capable of more than 500 horsepower and test-track speeds greater than 200 mph, is mounted in front of the passenger compartment but behind the front-axle centerline in what the LF-A's engineers refer to as a "front-mid" configuration.
The engine is connected via a torque tube and propeller shaft to a transaxle that is controlled by paddle shifters. The torque tube is a structural member that adds rigidity to the drivetrain and chassis while also reducing vibration.
Styling is rooted in the Lexus L-Finesse design philosophy, conferring the LF-A Roadster's front end with a compact, low-profile, aerodynamic shape. Like its coupe counterpart, the LF-A Roadster stands just 48 inches tall, but the Roadster configuration adds a speed adaptive rear wing.
The rear is marked by a pair of wrap-around, arrowhead-shaped taillights that bracket a pair of large grilles. These grilles vent the heated air from the car's two rear-mounted radiators into the LF-A Roadster's aerodynamic wake. The radiators are fed cool air by two large intake ducts mounted just above the rear wheel wells. This aft radiator positioning not only allowed the designers to keep the car's front profile low and tight but also aided the LF-A's chassis engineers in their search for optimal weight distribution.
Helping to provide balance and scale to the design, which features an overall length of 175.6 inches and a wheelbase of 102.6 inches, are high-performance tires on turbine-styled alloy wheels. The front tires are 265/35R20s, while the rears are 305/30R20s. Like the LF-A coupe, the brakes consist of 14.2-inch cross-drilled, vented discs up front, and 13.6-inch cross-drilled, vented discs at the rear. The front brake calipers are six-piston units and the rear calipers use four pistons each.
An "F" logo, located on each front fender of the Roadster, indicates the vehicle's status as a part of the new "F" marque. The name is derived from the original "F" designation for the first Lexus LS prototype. That vehicle was internally coded "Circle-F," with the "F" standing for "flagship." The Circle-F designation further evolved into the code name Flagship One, or F1, and the first F1 concept developed into Lexus' first vehicle, the LS. Since then, the "F" code has come to signify a special vehicle program within Lexus that falls outside the normal engineering and development process. In addition, Fuji Speedway is the IS F's home circuit, and the shape of the F-logo was inspired by many of the track's turns. The all-new Lexus IS F sport sedan is the first production vehicle to carry the F marque.
http://www.worldcarfans.com/9080113....dster-revealed.
Old 01-13-08, 01:07 PM
plex
1UZFE/2JZGTE
plex's Avatar
repost there's a 5 page thread on this already
Old 01-13-08, 01:19 PM
97-SC300
97-SC300's Avatar
When I first saw this, I couldn't stop staring at it. That paintjob is beautiful.
05RollaXRS
LFA Model (2012)
08-09-14 11:27 AM
Hoovey689
10-11-12 01:42 PM
Lexwang07
LFA Model (2012)
12-28-07 07:16 PM
Quick Reply: Lexus LF-A Roadster
