01-09-07, 08:48 AM
Quote:
Originally Posted by Bildilla
Price +/- 100.000 $
Some things to look at is:
- Mirror
- Air / heat openings on the hood.
- The front
- The Air intakes bay the back windows
This things are goving to be different on the produksjon model!!!!
There is nothing to indicate that the latest covered up car seen testing at the 'Ring is in fact the final production car, in terms of styling and mechanics. It may still be a test or engineering mule. Look at how there are bulges at the rear of the car. Those look too strange and awkward to be present on the production car. Plus, if the reports are true, then the LF-A isn't coming out for another 18 months to two years.
As far as the engine placement goes, "front mid-mounted V10 engine" likely means that the engine is still obviously front mounted, but "mid-mounted" on top of the front axle for optimum weight distribution. Looking at the revised LF-A, you can see how it would be very possible for the V10 to be mounted right over the front axle. The rear-mounted radiators would further aid weight distribution.
01-09-07, 09:28 AM
Quote:
Yes  But when you see the old and the new "Ring-car", then it is tings that indicate just that it is the produksjon model  ( NOT THE END RESULT BUT, CLOWS!! )
And that it has bin some problems whit airflow too the engin / engin heat. And after testing for long time, they have not don big work to the design. Just too the airflow into/arownd the car
But j cud be roong!!!
J DONT like the new concept front!!!!
__________________
Toyota Sportscar Club Norway
http://www.tscn.no
77 Celica Liftback, 82 Celica, 83 Celica Supra, 84 Celica Supra, 91 Soarer 4,0 V8 Activ UZZ-32, 92 Soarer 2,5 TT GT-TL JZZ-30 and 92 Camry 2,2 XL.
01-10-07, 12:18 PM
Price +/- 100.000 $
- Mirror
- The front
Good comparisons. I'm wondering if they're trying out some of the overstylized bits such as the nose and the upper side scoop as possible Supra details. Also they are showing this as an "F" configuration so possibly pushing the envelope there as well to gauge public reaction. For a Lexus it really needs to be less highly stylized. When you look at the Aston, Lambo, Ferrari and Porsche they are cleaner and don't look like they have an after market body kit.
Did anyone notice the 9,000 rpm red line on the tach?
__________________
'06 GS430 Matador/Cashmere
'02 MB SLK32 AMG
'65 Lotus Super Seven
01-09-07, 08:45 AM
More . . .
01-09-07, 12:48 PM
Quote:
Originally Posted by Koma
Yea I don't think it's going much over 120K in price range.
It's hard to compare the M6 with the LF-A, the LF-A is going to weigh alot less.
Exactly. The LF-A is said to be built on a carbon-fiber construction. That alone pushes the LF-A to a whole different league than the M6 and easily into some exotic pricing.
__________________
$_="^"^"^",`@{[(".>.\@[$_>\\$_?)\@$_/^$_&\%,\@\`/\`,"^'^[\,{-[|"[@% ^//~@^/+\`/\`').('!@/"'^'**.')]**`
01-09-07, 07:12 AM
the LF-A is mid engine you can tell from the rear pictures there are radiator vents at the tailights, plus they have stated it is V10 mid engine in press releases
__________________
06 IS350 Crystal White/Black + Sport + Mark Levinson
01-09-07, 07:19 AM
they've actually stated that the lf-a is mid engined with the engine mounted in the front of the driver. to be mid engined only means that the engine is in between the two axles.. it could still be closer to the front or rear axle.
mounting the radiator rearward offers a number of benefits:
1. reliability in racing- debris is less likely to destroy it
2. cleaner front end- allows for more aerodynamic designs, important at 200+mph.
3. allows the front of the car to be more compact and offers the designers/engineers more freedom
among the downsides include weight and complexity.
note that those shots of the lf-a on the ring are not the latest. the newer ones from the ring look slightly different, and the car at the detroit show looks slightly different from that.
01-09-07, 07:26 AM
Front to mid engin!!
Some new pix from the ring??????
__________________
http://www.tscn.no
01-09-07, 07:51 AM
Quote:
FROM LEXUS.com
LF-A Sports Car Concept
The LF-A sports-car concept was originally shown at the 2005 NAIAS to express a bold new direction in styling for the Lexus brand. The goals for the new LF-A are no different than they were with the original concept: To build a supercar with world-class performance that is uniquely Lexus.
As with all new Lexus vehicles, the styling of the LF-A is rooted in a design direction called L-finesse. The concept of L-finesse was used to shape and detail the original LF-A, and it was used to reshape, redetail and redefine this latest version. Lexus has further refined the styling of the new LF-A to enhance its exotic nature with a greater use of curved surfaces and interesting details.
The running gear of the LF-A is just as it was with the original, powered by a high-revving 500-plus horsepower V10 engine. Its front mid-engine placement, along with a rear-mounted transaxle and rear-mounted radiators, allows for excellent weight distribution. The horsepower, superior aerodynamics, and revised styling make a top speed of 200 mph not only possible but probable.
An “F” logo, indicating the vehicle’s status as a part of the new “F” marque, is located on each front fender.
“The first LF-A was a pure concept, but one that we went so far as to conduct engineering analysis on,” said Carter. “This latest concept is much closer to a vehicle that we would bring to market, and one in which we will be gauging consumer interest.”
Lexus LF-A Preliminary Specifications
Powertrain
Engine: V10 (under 5.0 liters)
Horsepower: More than 500
Top Speed: Approximately 200 MPH
Tire Size
Front: 265/35R20
Rear: 305/30R20
Dimensions (inches)
Overall Length: 175.6
Overall Width: 74.6
Overall Height: 48.0
Wheelbase: 102.3
The real info from LEXUS!!
__________________
http://www.tscn.no
01-09-07, 08:22 AM
yes. front/mid engined. this is what the s2000 is for instance. technically a mid engined car because the engine lies between the axles. this, it seems, is what the lf-a is.
here are a couple newer shots from the ring.
edit- i see this pic is actually from the same series as the last pic shown, so disregard the 'newer' comment.
01-09-07, 08:17 AM
Detailing Geek
V8 Vantage is a looker, but the engine leaves something to be desired. If the LF-A drives well and is priced similarly I think it definitely looks good enough to b chosen over the Vantage.
01-09-07, 02:56 PM
One thing it be amazing if the car does way until 3000 pounds.
2950 pounds
Ahh now I remember what the front of the LF-A looks like, an oversized front of an actual F1 car.
One thing the button for "Snow" I wonder if it will activate the AWD system.
One thing I was hoping for a 10,000 rpm redline, 1000 rpm short but I can live with that.
I cant wait to see the "Drag coefficient" for the car, would be nice to have it in the 0.25-0.26 range or even below that.
One thing I just hope that Lexus/Toyota make a Limited Edition one that has an actual F1 engine in it, say like only 15 ($1mil+) for sure they would sell easily.
Also another thing I hope they put an over the top ML soundsystem in it. Like 1kW. Only that comes close to that is the Burmester in the Bugatti Veyron.
62 - 0 mph in less than 105 ft would be nice.
0 - 62 mph under 4 seconds (3.6 - 3.8 seconds)
01-09-07, 06:16 PM
Quote:
2950 pounds
Who ever said anything about AWD?
__________________
-Allen Mok
01-09-07, 06:19 PM
I did. Whats with the Sport, City, and Snow button. Would be interesting that that the "Snow" button would activate an AWD. Seeing that your going to drive in a snowy condition.
Thats me. People might not like something like that, but it be interesting to see though.
01-09-07, 03:41 PM
it's a great looking car. awesome interior.
Unfortunately, the style is not on par to call it an exotic.
maybe just because of the color? i dont know...
but to park it next to a ferrari, aston martin the LF-A looks like an ordinary lexus coupe, not a supercar.
Tags
2009, 24hrs, club, clublexus, data, interior, isf, lexus, lf, lf1, lfa, nurburg, nurburgring, official, overclocker, race, roadste, technical  |
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
