- problem: cant get lugnut off
- Where to buy donut tire
- Opinion: HyperSilver Rims on Matador Red?
- iFORGED TRACK EDITION (1pc) : READY TO ORDER
- Continental ExtremeContacts availability
- New Tire Break-in?
- Opinion Falken FK452 Tires 245/40ZR19 on 19x10R pls
- Offsets vary by center design?
- HanKook Tires
- special request
- 245 50 18?
- L-Tuned Rims with BBK (Supra) fittment?
- Will this set up fit?
- advice on new tires
- RunFlat Tires
- Chrome Stock Wheels
- Help id the wheels on this Porsche, pls
- replace gold oems? sc400
- Siping or not?
- Consumer Reports '07 UPH Tire ratings
- problem with a 1 day old tire.
- can anyone identify these wheels?
- SC300 Wheel Fitment with LS400 Front brakes
- HRE quality
- I need wheel suggestions
- offsets on gs400? Help!
- Toyo Tire's
- advice re changing IS350 to four 245/40 tires on stock 18" wheels
- Are ACE wheels any good
- Biggest tire on a gs430
- 245-50-16 fitment
- Thickest tires for Stock 17s
- Converting converted wheels
- Is it possible to convert bolt pattern 5x112 --to--> 5x114.3 (fit on 2GS) ?
- 18s dented for the third time!
- These Wheels...Yay or Nay? and what tires?
- SSR Vienna owners help
- which UHP tires for IS350
- Pothole + Alignment = Ugh
- Question on Rims
- What"s The Best Tire Size For 20's Staggered
- Wheels that look like Zauber Gettins?
- Anodized wheels?
- (wheels) A.Z.A 's on gs400? HELP
- Tires again...
- Offset help for 2nd gen GS430
- Recommendation for a '94 ES300
- Noob Rim Question!
- Would the same Borbet Type FS Wheels fit both a 98 TL and a 02 GS430?
- has anyone powder coated their brake calipers?
- where to buy Works?
- Widest wheel spacer i can go on a gs400
- Lexus fitment wheels with 8.0"~8.5" +10~+15 spec on tirerack?
- Where to get trafficstars?
- repolish
- Question about gold finish on Brembo Sport Drilled Rotors
- Forums to find SUV wheels?
- TSW Wheels?
- Bridgestone RE960 A/S for IS350?
- will these wheels clear bbk?
- disassembling a 3-piece wheels TOOL NEEDED *PICS*
- Question: 270/30-24 on GX?
- Michelin Pilot VS Goodyear Eagle (TIRES!)
- 2IS offsets vs. 2GS offsets
- Good A/S performance tires
- 35+ offset fitment help
- Dunlop SP Sport 5000
- WORK VARIANZA SC1 - New Wheel
- offset question
- lexus gs stock 17s 5 star
- Will they fit? Help..
- 275/30/19 Bgf Kdw2
- Junction Produce Heritage / Heritage3?
- will 255/35/20 bead on a 10.5?
- My Tires and The Drawbridge
- Lexus Brake Decals
- Biggest rims on a GS300
- Is It Easy To Bend 19's
- tire wobble
- Will LS430 wheels fit a GS?
- Curious to know - a wheel spacer question
- hubcentric ring question
- wheel question
- what brand of tires for 1995 ES300
- OEM tires fitment on aftermarket wheels... question
- Is EBC the only maker of green pads?
- 19" Dazz Matiz Wheels needed
- * Picture * Forged Wheels
- Rim fit question
- Tire Problem
- offset question
- tire rack tread depth compared to discount tire
- Need new tires..Whats best?
- center caps: use them or lose them?
- LS 400 tires
- Racing Hart R5 Pro - Need Info...
- offset question, sorry!
- Kranze Wheels
- Needed info on tires
- Maya's vs Trafficstar's
- +50 offset
- New Rotors Causing Vibration?
- what r those !!!!!!
- Clear Coating Caliper Help
- The SHAKES!!!!!
- 275/35/19 Need Pic
- Steering wheel shake problem???????
- name this wheel!!!
- Question on tires.
- clear anodizing?
- Wheels & Tires for my garage queen!
- Choose right tire size
- VERY Troubling Story From Bimmerfest...
- Tire question, bubble in sidewall
- trying to match a wheel .....
- recommended tires for 19's size 275/35/19
- fitment
- O. E. Wheel Distributors in Sarasota, Florida
- Is it okay to mix LOAD INDEX?
- Keep getting bad valve stems...
- SOCAL: Has anyone gotten their wheel's offset changed?
- fittings
- TR Ordering
- Aftermarket wheel sensors
- MB wheel questions
- Shipping Question
- referral number
- question about stainless steel brake lines
- sc430 wheels
- Anyone try these "sort of" OEM wheels?
- Anyone running 225/45/18's in front???
- Wheels worthwhile to refinish??
- Sumitomo HTR Z III
- Tire Brands
- Is there a spec range for wheel weights?
- Wheel Weight...
- Michelin Pilot Sport PS2 vs. Pilot Sport A/S
- Every tire store saying different sizes?!?!? Which ONE?!?!?
- What Rims Are these?
- Can anyone Vouch for kenneth@themodcity.com
- Wheel help
- Good Mechanic needed in Central Massachusetts
- Anyone heard of VSR Rims?
- leaking air from new tire on gs 300 2004, help!!
- Need Advice About Replacing A Single Tire On '99 Es300
- Another Offset Help Thread (pleeeeeassse help)
- iFORGED TRACK EDITION (1pc) : PREVIEW
- EBC Brakes for RX-300
- Wheel Question (Scratching My Head)
- Need some comparisons with these 2 rims..
- Looking for good faq on choosing rims...
- Tire Size
- Picky Gs wheel balancing!!
- Can you fit a 18x8.5 +25 wheel on a 2GS3?
- 19x8"f (20mm offset 20x10"r (25mm offset)
- New HRE wheels (full-face design)? [pics]
- What kind of polish and wax to use on black wheels?
- whats a good tire?
- 18" wheels on 225/35/18 tires, tires to low?
- How will 18" wheels and 225/35/18 tires look on a 92 ES300?
- question on upgrading wheel size
- L Sportline brakes??
- Anybody purchased from O.E. Wheel Distributors LLC
- Need info on these rims.
- problem with tires
- 18x8/9 offset help
- Looking for new tires to replace OEM on IS250 AWD
- Goodyear Eagle F1 All Season
- 19x10 on 295/30 Tires
- SSR GT3's & Tanabe Werfen GT-03 the same wheel?
- 18x11 Fronts 18x13 Rear - TIRE SIZE?
- Need Help 19x9f +45 19x10 +45 For Gs2. How Is The Fitment? Any Issue?
- Second Gen GS Boxes / IB
- Wheels for the LS430/460
- Trouble Installing Wheels
- 06 SC430' wheel on 01 LS430????
- BBS LM-Rs on Cayman and 335
- To paint or to powercoat
- Wheel Offset size suggestion
- Will this offset work on my GS
- Ok fellow 2g GS's. Help me come to a decision...
- Annodizing the face?
- Has anyone seen the "NEO Chrome" Wheels??
- VOSSEN WHEELS - New Wheel Line
- Which Wheel Locks Are Better? Pics Attached.
- size labels gone... is there a way of finding out the offset of a wheel?
- lx470 w/20s
- question bout fitment & tires
- tire options for oem 17" chromies
- 20in wheel/tire fitment question 03 gs430.
- Turanza LS-H or Turanza Serenity
- Question abour drilling tires for TPMS
- yet another rim thread 19s
- TT wheels tire fitment
- Ultra High Performance Tire?
- Tire Rack Wheel Search Help!
- Grind backplate of wheel to reduce offset
- Tire size for 98 es
- Need Help with vibration on a Brand new Tire/Wheel Pkg. install
- Will 2002 17" LS430 Rims fit on 2004 LS430?
- question about tires size...
- What tire should I buy?
- In need of agressive look <----
- Why doesn't anybody make OEM knockoff wheels.....
- GS wheel fitment help needed!
- spare wheel/tire to fit over bbk
- Stock replacement tires
- Anyone running Falken Azenis RT615's?
- Direzza DZ101's FTL
- 16" gs430 rims on a is250awd
- painting chrome rims
- Black with Gold Lipped Rims
- What Lexus are These Wheels From?
- Help me find Giovanna attacks
- Replacing 18" summer tires on new GS350
- Anyone know if these will clear TT calipers?
- General wheel offset question.....HELP!
- BBS sold to Belgian firm
- Ordered wrong tire size!Need advise.
- OK - Staggered but 18" fronts, 19" rear?
- Kumho ASX, Good Tire?
- Need Help With Wheels
- Help Deciding Which Wheels Look Better! Pics Included!!
- Tire Pressure Help
- Quieter and Most confortable tires ?
- 285/30/20 vs. 275/30/20 PICS
- What are the best wheel locks?
- Work Rezax Rim vs Curb
- sc300 rim with
- So whos gettin these rims for their IS???
- Dunlop SP Sport 01A review (negative)
- Avon Tech R-A Closeout!
- Pilot Sport PS2
- The Wheel Buying Guide
- I need new breaks!
- How many miles will I get with NT555 tires
- lexus wheels
- What offset is recommended for 18x8 0r 18.7.5 rims on 2001 LS430?
- Will these wheels fit??
- Good Wheels?
- The best way to stretch tires!!!!
- Who says Nittos beat Falkens?
- Rounded 285/25/20 Toyos
- Calling all wheel experts! 285/30/20?
- Plastic wheels may be coming to production cars
- brand new 2 the game. need offset advice.
- Can I fit 225 40 18" tires on RX330 18x7" wheels?
- Tpms Is 350
- New Wheels or Spacers?
- Redrilling in Southern Cali / OC shop
