- Painting stock wheels
- Cluster Question
- HERE YEE HERE YEE the sc outta the shop!!!!! ZEALS INSTALLED AWSOME
- Difference between the SC3 and Supra head
- Information about SC300's for someone new
- Retrieving the Codes from My 2jzgte vvti Engine
- Calling all factory 5 spd SC's, I need some help
- SC400 Diff carnage...
- Post A Picture of Yourself With your SC
- Jacked up sc story
- WHICH COMPANY MAKES 25mm spacers or Thicker?
- I havent ever had one of these Lexus things...until now!
- Decided to keep The CAr!!1
- Got an SC300? have a shirt to go with it??
- LSD for 6sp V160/V161?
- noob need help on wheel fitment
- megan coilovers lowdown
- Sooo, $400 parts, $500 labor to fix A/C? Hmm?
- headlight qustions.
- help! - Junction Produce Table in an SC300
- 97 Black 5spd For Sale in LA area (not mine)
- Quick pic of the new wheels
- You guys are gonna hate seeing this....
- camber correction kit & camber kit
- Supra TT or SC?
- need help....!!!!
- can i has pics of 97+ fogs?
- Can't find Tilt Telescopic ECU.
- probleme boitier alarme
- Interesting/Functional Aerodynamic Feature?
- Foglight colors
- SC Spoilers Thread
- Another SC restoration. Making that 17 year old car look like new!
- A easy & cheap solution to burnt out cluster bulbs
- SC'S with twin turbo rims Pics only
- shop in SoCal to roll/pull fenders and need camber kits for my sc300
- Wat kind of rims is this?
- Lug nut key for Rays lugs???
- Where do you get lower control arm bushings?
- Can i buy lower ball joints w/o heving to buy complete control arms?
- airbag fuse?
- cant find throttle cable
- My to do list...
- Anyone have pinout/wiring diagram for SC300/400 seat plug? Annoying seatbelt light
- I went black
- Does anyone else have this happen to them when getting gas?
- wiring issues
- Is the factory alarm good enough?
- Sc owners in tampa?
- Nitto neo gen vs Nankang ns-II
- O2 sensors - did they change?
- My 95 SC400 broke down on I75 today lol
- NEW BUMPER ordered, opinions???
- Tranny bangs into gear (sc400 auto)
- 97 SC400 Help?
- removing the auto tranny
- What Would You Pick
- Any hp/timing gains
- Why?!?!?
- Why isn't there a Keyless entry FAQ!!!!
- Dyeing to have black interior
- Front Bumper Inside Cabin?
- where to buy a rear visor?
- Cxracing stuff
- Chrome 6-Spoke Center Caps
- Just dropped my lady off with the painter
- Stripped starter bolt, what to do?
- low oil light problem ! help
- Lowering oem seats?
- Climate Control LCD
- paint's almost done...
- lip discontinued???
- Check engine light is sometimes intermittent
- Wheel lift concepts - ideas and suggestions welcomed
- Anyone tried to install MKIV carpet in a Sc?
- yet another photoshoot, but this time there were others!
- Hazy Wood Grain Steering Wheel Restoration
- Look what FedEx brought me!:)
- 24's Yo!
- First sc 300
- R154 swap at home...what do yo use to...?
- Leak on passenger's side floor
- After Some Mods To The SC3 5spd - Some Photos Inside
- How to get rid of Low Coolant cluster indicator?
- 180,000 Miles Checklist
- My Mini Photoshoot!
- Who can explain this one!
- Oh the things I'd do with...
- Omg!
- Any plans for spring?
- HELP car won't start!!!
- Gage Help
- REALLY quick question, plz answer Thanks to all
- PS Hose: Possible Replacements?
- engine code ???
- Sick Rims on SC?
- production numbers
- Driver Windows Stuck down
- SC needs some TLC !!
- What to do next? Back to glory.
- 5 speed guage cluster swap
- Help hooking up heater core
- So... I joined the wrecked club..
- 225 55 16 general winter tires at tirerack
- Is there a difference between these 2 MAF sensors? FMZ3AYY1 and FMZ3AYY2?
- Another 1UZ 5 speed on the road now!
- sc400 transmission
- Turbo on 139k 2jz-ge?
- Pics of 22" rear 20" front staggered setup?
- OLT i miss you
- suspension
- performance chips
- does anyone have these halo projector headlights
- rear wheel bearing replacement
- She's FINALLY here.....and nasty....my new SC300
- 97 SC300 W/ Traction Control?
- Cabin air filter
- The Seat bracket thread
- seats
- What Kind of Rims Are on This Black SC
- My first sc300....mmm lovely!
- finally took by new baby 400 home
- 2jzgte injectors in 1jz???
- VS-XX vs. Brombacher
- Want to Buy Climate Control Bulb
- wanna make your I-6 SC300 sound like a V8 SC400?
- Fastest Way to Change Key Hole Light Bulb ?
- Help Fast!!
- 1jz Fuel pressure regulator buy help!!!
- Have a Question
- Running wire and vacumn hose through firewall
- Guys need a major HELP!
- Share your moment...
- Steering wheel cover - which looks best?
- My AC and now Heat don't work....
- One shot of my SC and a few of other cars at a recent meet
- Using fuel additives in our SCs
- about to be a New SC owner..
- Any pre-95 retrofitted corner lamps?
- Messed up my sc300 need advice!
- Trac off
- Help me out please!! IS-F exhaust tips on SC300
- NEED HELP WITH ECU/Injectors
- 3inch turboback exhaust clip/AFR idle readings with revs and some death
- wrappin dash ideas
- m6 wheels on a sc
- Bought a 1jz!!!
- Help! Passenger Mirror Broken
- Snapped some quick pics tonight
- Snow day 14 inches and the SC drove just fine
- Un-installing Defi gauges / Apexi SAFC II
- el mostro first day ....pix inside
- Vinyl Wrap
- I need opinions..
- adjusting headlight help
- Bought my first SC300!!WOOWOO!
- Removing ignition key cylinder without key
- New Car Finally!!! might change name to FianllySC now!
- Leather-seats ebay seller - how's the leather quality?
- sneekus peakus : my car, fair fellows, looks how shall I say it... SPLENDOROUS
- how long does it take to take apart the entire interior?
- So I went from a 92 1JZ GTE to a 99 2JZ GE...AND Im not disappointed!!!
- Can you wire up a power seat so that it works?
- New Cluster
- making a wise lip hella strong
- 99 sc300 fog bulb?
- Pics of my SC!
- pics request: work eurolines
- Center Console Lid
- sc400 restore/pimpage
- 2010 Teaser....
- (yet another) will these wheels fit? thread
- MY first SC, few pix
- ***OFFICIAL: POST a Pic of your ride - RIGHT NOW! SC Style***
- Why don't we have a dedicated website?
- My drifting boo boo :(
- NEW to the Lexus SC World!
- Looking for parts to complette my sc400 2jz project
- sc400 Instrument Cluster
- Halo rings HELP
- New key fob for my '92 SC?
- i want 600hp out of my na 2jzge....can it be done?
- 1 more package in
- Which set of wheels would look sexier?
- PRS22's Quest for Glory....
- Phase 3
- Shifter extension for s400 ijzgte
- Ownership as a Married/Family Man?
- Anyone coming to TX2k10?
- Night shot.
- Foot light wtf?!...
- Help! Key won't turn in ignition!
- out with the old and in with the.......old?
- How much faster do tires wear out with aggressive set ups?
- alot of play in the sterling wheel
- Auto to Manuel conversion guys chime IN!
- Fender Question
- SC guys we made TV
- Whats your SC's theme song
- HELP! WTB: Alternator
- Been Lurking But finnaly have bought not one but 2 sc's in one week. One boosted.
- little question
- need some guidance on a purchase....
- Fog lights
- Project: Lose boost...and GET BOOST!
- Quick ? about speedometer
- BC's vs. Megans
- SC400 SQUEAKING noise and I cant figure it out! VIDEO INSIDE please help
- how easy is it to remove the this part of the e-brake?
- Being slammed saves you money...
- We picked up another SC on V-day:)
- CCW Classic wheel 18" offsets on an SC?
- alarm install questions... already tried searching
- first of few packages arrived today
- I think i just FOUND my SC
- Lexus Patches
- The most AWSOME fail you'll ever see!!!!!
- Just bought this classic
- how did you feel when you first bought the SC?
- seat removal.
- ??? Scxxx on isf wheels ???
- Manual brake pedal question?
- determining fair market value
- Looking for white/clear side markers for my 95 sc400
- How much is my Turbo SC worth?
- Best touch screen monitor size for stock stereo placement
- More bad news 1 more SC down right now consider selling it
- Took some some pics today with my new invisible hood.
- I got bored today and play with pic my car.
- leaking gas thro the A/C condensation hose
- My little experience today...
- New wheels = Pics :D
- 1988 Toyota Supra MK3 Turbo differential for SC400
- Air bag light
- Anyone else get a surprise from Origin today?
- Look what I found at my front door today!
- Megamarine's Damage Pics???
- (battery)Starting issues HELP !!!
- Clear lens
- Where can I find the vin # on my sc300 engine?
- ashtray's got a secret..and I know what it is..
- One-year anniversary
- SC400 Gas Level
- Well I guess Ill finally reveal myself.
- SC400 Crossmember for 2jz-gte
- what i got for my valentine
- Who has had an SC stolen or broken in to?
- To Buy or NOT to Buy
- Who's car is this!!!??
- New to CL
