PDA
View Full Version : SC- 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153
  1. whose lexus is this?
  2. Changing Location
  3. how much do you think my car worth?
  4. Foglight mod: 92 SC400 with a 95 front bumper
  5. How many 5 speed sc300s were made/show them off
  6. HELP! Harmonic balancer holding tool
  7. $1600 SC400 worth it?
  8. motor mount/driveshaft
  9. Finally back up and running! sleeper style :)
  10. I was to excited to not show everyone
  11. Auto To Getrag Manual - which shift knob setup did you go with?
  12. Flywheel Bolts?
  13. transmission fluid
  14. 1995 Lexus SC400, a few things not working.
  15. A/C compressor broke
  16. Smelling gas in the cabin
  17. Starting issue, with no clicking
  18. steering wheel hub
  19. Should I get it? First car :)
  20. any idea on how to fix this?
  21. sumner washington import meet!!!!
  22. 95 SC400 with 225xxx miles.
  23. SC400 Exhaust System
  24. pics of my audio.. any thoughts?
  25. MacMini In 1jzgte 1992 Lexus sc300
  26. sorry but, i gotta ask
  27. sc400 brake caliper issue...
  28. Small video of my SC400 manual (and my supra)
  29. Radio, Power mirrors not working.
  30. Nakamichi sound system failure? Help please.
  31. new member
  32. Finally! I look what i got today !!!
  33. New SC400 owner/engine swap
  34. Stock exhaust question
  35. Climate Control and blown fuses
  36. Ambient Temperature -22 Degrees
  37. Power doors keep unlocking
  38. Drift setup for my SC300
  39. Power steering "rack"?
  40. exhaust size for sc400
  41. Check out the new pics, Wheels too.
  42. Alarm
  43. Soon-to-be SC owner
  44. 1997 SC300 worth buying at this time?
  45. Diagnosis Request: Electrical Issues?
  46. How to get that slow crank/startup sound?
  47. it was only a matter of time...
  48. What is the sharp noise?
  49. Custom Painted Rotora 6 Piston 355mm BBK Project
  50. new member to CL
  51. 1jzgte Part numbers and help needed.
  52. me and leesc300 shoot some pics
  53. 1992 SC400 - Steering wheel cover
  54. engine start knocking after i changed oil and spark plug any idea?
  55. Not so stock ride height...? Possible spring sag.
  56. 1jz swap help needed
  57. what does this sound to you?
  58. Should have listened wheels suck
  59. from beginning
  60. WANTING TO GET A sc300 ANYONE HELP
  61. HKB BOSS hubs? better think again.
  62. New sc300 for $500
  63. D2 Racing RS coilovers
  64. 97 1uzfe limp mode issue HELP??
  65. Soarer Questons.
  66. MSD Digital 6 ignition w/ 2-step on my SC300 w/ vid
  67. Htc evo pics
  68. hey everyone NEW on CLUBLEXUS can anyone help me find this SC
  69. '97 sc300/
  70. Parting Out My Lexus SC400
  71. how much should I cut my springs
  72. Girlfriend vs. Climate Control
  73. cost of rebuilding the engine?
  74. Swapping a Driver's side chair for the Passenger side??
  75. vertex fender fitment problems help!!!!
  76. A/T Throttle Cable
  77. recent acquisition and i need some advice (pics inside)
  78. Can't get bolts of wheels.
  79. need picture of 245/35 tire on 10" wide rim
  80. spacers for inner tie rod?
  81. SC400 - A few questions
  82. what have you done with your huge antenna?
  83. Please help... psngr seat problem
  84. name this sensor on the 1jz block
  85. Advancing base timing on sc400/1uz
  86. Really need advice
  87. Trickle Charge?
  88. torque steer
  89. How would i acquire this?
  90. NEED HELP** What kit is this???
  91. need advice
  92. Climate contol wiring diagram
  93. removing, rear axle nut
  94. sc300 or mk4 clutch pedal assembly?
  95. Most power from stock turbos. 1J /VVTI & 2j /VVTI
  96. The new ride... SC400 :D *Pic Heavy*
  97. Hydro fan on 1JZ?
  98. What do you guys think about over-fender rivets??
  99. oil leak behind plastic covers
  100. High temperature????
  101. Fi ?
  102. i need to know asap. (can you chip a stock ECU)
  103. So got a little bored with mighty putty, and trying out a new turbo
  104. What wing is this?
  105. JUST CANT WIN!!! but thanks NOVA
  106. How is everyone SC doing through Earl
  107. made a big boo boo w/pics
  108. Need Help!!!
  109. Awesome Article on the vvt
  110. Installing New Radio Question?
  111. What kind of modern stock leather seats I can fit in my SC?
  112. Help me Finish my project
  113. Help me Finish my project
  114. Need help identifying this sensor in the front bumper area (pics)
  115. Tps sensor???
  116. LS seats
  117. sc400 1jz swap?
  118. Interesting Alternator question....
  119. Updated Pictures
  120. Help me decide (rims)
  121. ugh decisions decisions...
  122. Help!!! How to remove door pillars
  123. Does any1 know about map sensors!!!
  124. wise lip to fit 97+ bumper?
  125. Faster SC400?
  126. I am the New guy....
  127. DIY Maintenance- My comprehensive story.
  128. Door Handle doesn't work (an unexpected reason)
  129. Few Pics - SC300 on Gold Works
  130. Rolling Like A Bigshot (Professional Rolling Shots Inside!)
  131. Can't read ECU codes
  132. Tsukuba Time Attack Soarer w/ 1.5JZ-GTE (2JZ-GTE block, 1JZ head) & Hollinger Trans
  133. strange sound
  134. Confused on swap
  135. Air bags problem
  136. Automatic transmission stuck on drive.
  137. Post Your Pixel Art Cars Thread
  138. Another build thread to the long list
  139. Questions about 1JZ supra/chaser for SC300
  140. automatic gear shift knob
  141. SO you turbo......
  142. My $250 Project SC300 progress (and a couple questions)
  143. In Dash?
  144. Vertex Ridge Wide Bodykit
  145. knock sensor sc400???
  146. FMIC Fitment?
  147. CAn anyone help me?
  148. Photoshoot pics from last week
  149. high mileage / first car
  150. need help
  151. I'm Officially back in the SC Club!!!
  152. Security over apperance..audio/SC related
  153. When your bored at work.. draw..
  154. whos selling 5 speed swaps???need asap
  155. SC drifting knuckle steering mod
  156. New Member here! Need help. Pics included.
  157. Rolling shots n more..past weekend's bbq meet
  158. DIY 95-96 tail light mod
  159. turnbolt canyon sc300 meet
  160. Another code 25
  161. Help please
  162. Cheap Power Steering Hose???
  163. saw this for sale
  164. Code 25
  165. any tips for building my NA-T?
  166. Just picked up another SC
  167. 1jz oil change-which vehicle?
  168. my a/c lcd went out???????????????
  169. my new sc300
  170. Rare OEM item
  171. SC300, Considering an Auto Build
  172. Tail LIght Help!!!!!!
  173. CEL came on..curious?
  174. What if the 92-96 spoiler and the 97 spoiler had a kid together???...
  175. Headlights
  176. Wheel fitment
  177. Talk me out of it
  178. help: turn signals and hazards not working!
  179. BC VVTi 2jzge cams/valves/springs/retainers
  180. Help,sc400 sputtering issue
  181. need help!
  182. Please Help with changing climate control lcd
  183. Finally got my RSP!
  184. side marker question
  185. Pics of first mods 95 blk on blk sc300
  186. OEM 5 speed shift knob
  187. SC300 & MKIV Supra Photoshoot Pics
  188. Post Most Recent Pictures of YOUR CAR.........
  189. New Pics of my NA-T
  190. Got bored took pics
  191. Yet another owner...
  192. help from sc sound guys
  193. What does a stock clutch from a 1jzgte look like?
  194. New wheels what do you guys think?
  195. What would be the best injector upgrade?
  196. wanting to get into autox need to get in any starter advise
  197. shaving fenders?
  198. *Idea* Custom Gauge setup? Who makes a nice speedometer??
  199. You may not like it but? "pics"
  200. Saturday Morning PCH Rolling Shots
  201. Is there a Fuse bumper/corner lights?
  202. Need some info on a spoiler
  203. sc400 front mount intake?
  204. Some new pics of my 94 SC300
  205. GEORGIA SCs.. I need a shop to install my strut/spring shop!
  206. One of the reasons I love my SC400...
  207. Sc400 limp?
  208. engine shaking after spark plug change??
  209. DIY Red-Out Tail Lights for you 92-94 people. Only $4 and not permanant!
  210. SC400 power steering vacuum source
  211. MAF Delete & BFI
  212. New Sc300 owner Need Help....
  213. Im a newbie
  214. Enkei RPF1 brake clearance issues?
  215. Soap n Water works wonders....
  216. sc fan clutch problem plz help
  217. can i re use the housing bolts and flywheel bolts from a automatic trans to a manuel
  218. keep the sc or get something else.. i need help
  219. SC300 mod tips
  220. Just Got an SC300!
  221. hey guys im new here from TN
  222. 2jzge Engine for $650!?
  223. Sc 300 or 400?
  224. Arizona members with 1jz swaps
  225. Yo People. Help ?
  226. Interchangeable? (2jzge-2jzgte)
  227. SC rolling shots...
  228. any sc300/400 on lowenhart lsr?
  229. Totalled my project sc400 today!!! 6000$ damage.. I have the worst luck in the world.
  230. That was a close one!
  231. My plans for the weekend...Wish me luck!
  232. Did all SC's have the storage bin insert in the spare tire?
  233. To those needing to replace your foglight bulbs...
  234. why i havent been on here in so long, dead sc3, wasted...........
  235. What does it take to beat a 911 T?
  236. Heater Doesn't Work
  237. need some help! it wont go into drive
  238. New to the forums and have a few ?s
  239. Spotted A Black Sc In Longmont
  240. PLEASE HELP!! 93 SC400 not charging and misfiring BADLY
  241. Replacing wheel studs + open ended lug nuts
  242. my new updates "photo"
  243. Engine oil
  244. New sc400 owner
  245. HELP!!!**Im buying wheels, Need help with off set**
  246. What ECU do i use?
  247. replacing alternator, need help.
  248. finally got some pics check emout
  249. turn signal relay
  250. SC300 convert Auto to Manual.. Need help.
