- New decals
- Sylvania Silverstars worth the money?
- Help!!!!!!!!
- door will not open from inside or out - i searched
- Is interior door/window trim avl from Lexus still?
- hit a pothole,now she wont start....
- The times finally come!
- Deals to good to be true? Legit Website?
- Blinky dash fix ?
- Project Knightrider
- Getting a check engine code P0758 shift solenoid B
- Window Regulator Question
- Back from paint (1G0) with new leather/black interior
- So a guy wants to trade with me...
- how much do you think this sc is worth
- Just picked up another SC...
- neutral safety switch issue
- How yall feel about this drop top sc for sale??
- 5 zigen fireball sounds?
- what size are the allen heads on sc400 differential?
- GS430 Wheel on SC400?
- So I did a few things... Thoughts?
- How do you Drive your SC???
- quick question
- SC300/SC400 Key Fob Programming
- Chrome SC300/SC400 Bumper Grille 97+
- Trans codes
- Anybody know this SC from Fl?
- trans soleniods
- 1994 SC 400 WITH 180,000 miles
- Front bumper Alteration thoughts
- sc430 steering wheel controls?
- 92 sc400 PROBLEMS with TPS or IACV "NEED ADVICE"
- Kind of Flush
- No start. 5v to cam and crank sensors?
- Need advice on getting R154 to line up.
- clutch master cylinder?
- Does Anyone Have A 98 Cluster Diagram
- Is this SC 300 worthy of buying?
- Quick Question
- Tire size on an 18x10 +25
- My V8 Slow Project!
- 1993 SC400 HELP! Help me figure this one out guys!
- 1JZ First Start !! :)
- 2JZ-GTE SC300 Swap Oil Pan Help!
- oem headlights still avl from dealer?
- fuel pump ecu
- WTB: 1997 Tailight Harness
- FatBrian81's "You got alot of... car accessories" thread
- USDM or JDM cams how the hell do you tell the difference???
- 3 spoke swap no horn/cruise control
- My First Drift Day is this Sat
- Sc400:Fuel cut on start up issue?
- 1992 sc400 trunk wont stay open
- New to Lexus
- Sound of keyless entry
- can any one in south fl
- SC "party" at buddies pad
- pictures of new rims, ( not installed yet )
- Flakey paint? New bumper or repair?
- Drifting Pics From Yesterday
- sc300 with is350 grill ??
- WOW O.o GOOD DEAL GUYS
- Line Lock's & brakes
- The 5 sppd Swap
- 94 SC400 starting problems!!!
- Climate Control Backlight Voltage
- I need your opinions on exhaust tips
- Made a few changes to the Soarer
- sc300 clutch question
- Useless parts/features on your SC.
- did my ECU fry?
- Do SC300 Crossmember differeniate from 92 to 95?
- parts
- Need Help: Coolant flush fail...Leaking around water pump
- Maybe going lower, question about wiring harness
- Pressure adjustment screw on valve body?
- Replace your transmission mount!
- Help me make some sense of this please!
- just got the 1jzgte back, ofc new problems, help
- SC400 Plug change
- wtb headlight support and ac condenser
- Eau Rouge Soarer @ Exciting Car Showdown 2011 Japan
- SCXXX Ghost Riding
- 1jz to what engine is best
- rattling.
- Who's is it???
- Clear headlights in the process TEASER SHOT
- Part number???
- Double Din Pioneer install unsure speakers wires colors?
- Rear ended today PICS
- 1993 SC400 Stock Alarm functions
- Knock sensor or pcm?
- Problem got worse car starts up for couple sec then dies (>.<)
- Cant Pass 110mph!!!!!!!!
- Help on replacing the outer door lower window seal on 1st gen SC?
- Whats the difference??
- i need help!!!!
- Help with bulb types for 1997 SC400
- my car caught fire!
- lexuspartsnow? anyone buy here?
- Question about fog lights, (pics inside)
- GrrRR driveside window pulls inside rubber piece and gets stuckdown!!
- Picked Up My Exhaust
- sc with american racing 606 wheels
- TSX Retrofit with Clear Lenses
- Window Regulator ??s
- Is there a way to reset srs light in a 97 without scan tool?
- new guy here
- Need Some Help/Advices
- first sc400 problem ever, engine randomly cut offs wont start agian
- When upgrading your SC..
- Son of a____ fml
- Good read, especially for 1uz guys.
- What keyless entry are you guys using?
- Brake Stop Lights Not Working
- 2jzgte single turbo conversion choice help :)
- Need ignition diagram
- SC400 idle issue....
- eastwood fender lip finisher
- power seat
- buying stuff from .....
- Wire harness chewed up...helppp
- 92 SC400 at Idle in park rpm jumps from 1500 to 2200
- Car phone to aux output?
- bored with my sc
- Gauge cluster lights, needles, etc suddenly all went out at the same time
- Rolling my fenders soon, have some questions
- Need opinion on this 18" wheels
- Help, looking for the sticker bumper sc!
- Speedometer problem
- Lextech Lighting
- Who's Slammed black SC with 1J is this???
- Sc400 owners what grade fuel do you use?
- Uh Oh, an i fawked? Removed trunk lock, now trunk is stuck
- New SC owner!!!
- The rim fairy paid me a visit today
- SC300 Updated Pics, Needs Photoshoot.
- Need help on possible conversion/swap
- Slicks for RX7 wheels?
- 2011 project done.. for now
- AZA Z2 Staggered 18"
- Please help odd problem
- Can Unpluggd MAF cause bad ECU??
- How can I tell what year my climate control is?
- 92 SC400 (one of the orginal club lexus cars) for sale. Lots of customizations.
- Keep it Chrome/silver or paint em black with chrome lip?
- Black Wood Vinyl
- Refinishing my gray interior with black SEM
- Rear Window Defrost Repair
- DDMtuning 5k 55watt HID Install - Easiest mod done to date
- work equips or work rezax IIs?
- Looking for daizen bushing kit 92 sc 300
- sc400 questions....need help
- I should of had a V8 ????
- Ls400 cluster in SC400
- Rattle engine
- What flywheel is this?
- Need help fast? i have pics to help?
- prepare shortblock, any ideas welcome
- driveshaft fixable?
- need Keyless remote
- Did SC300 come with different tuning maps?...
- i have yet to see someone with a set of these/some pics of recent head unit install
- Should I buy this '92 SC400?
- Was there any SC vids from tx2k11?
- Any Ideas On Speedometer Issue?
- I am selling my 400....unfortunately!!!!!!
- Car is finally done, couple of pictures.
- Engine just "dies" out of nowhere, but able to crank right back up?
- Ow snap i came up on loot
- found a solution to the DDM tuning HID problem
- Origin body kit vs duraflex body kit b
- which exhaust setup do you think is better?
- supratp23
- Need Catalyic converter (93 sc400)?
- Stock 2JZ-GE power + W58 + TT Auto LSD = eventually blown W58?
- interior update!!!
- Tail light options thread (everyone post pics)
- Front and Rear speaker size?
- Brakes are dragging and hot.
- 92 sc 400??????????
- Gold Work Meisters on black SC???
- 98+ Shifter
- Maintenance on the SC3
- sc300 spoiler fitment?! pre 97 / 97+ ?!
- This is my 92 Soarer
- 1uz with r154 help!!
- whos car is this? what colour is it? what's the colour called?
- Spent a full day on claybar and wax....
- Need Help identifing.
- Drill-less headlamp restore!! A+!
- bringing back old wheels
- air bag lights always on without key !?
- A/C Condenser questions
- New pics of car
- Burning smell?
- Sexy pics!....of
- Help!!!
- 6.7sec 1/8th mile pass
- 3M Headlight Restore
- Help me my 2.5 tt wont move of
- JDM Chicago Meet Whos All Going?
- 14 years old Calipers - rebuild them?
- Salvage to Rebuilt..pics and a hot cup of coffee inside
- Looky at what i found
- 1jz oil pressure sensor
- Year difference in leather seats
- Question about leather seats year fitment for 1998 and 1999
- The estimate has arrived.... 10.3k!!!!!!
- Weird Noise from My Gas tank+ jerking
- Varrstoen Rims
- My Front-Lip Scrape Guard from Home Depot, Using Industrial Strength Velcro
- What up CL!!
- Help With Single Turbo Setup
- Does Lexus Care?
- Im new to this forum. what do you think?
- OBDII to OBDI & MAF to MAP
- Pollen count in Georgis Sucks
- Can someone ID these wheels...
- SC300/400 oem strut and spring
- Electric Fan
- How true is this ... ??
- My New RX Wheel + Question
- where to buy windows regulators less than 175?
- looking for MKIII front driveshaft
- Camber kit !!!!!
- will i need a fender roll/what size tire ?
- the other 1uz to w58 mate
- sc300-400 in 8ball and MJG music video
- Really Weird Climate Control Problem
- interior falling apart
- No power
- 92 sc400 brake lights no tailights
- Bronze wheels on my Sandstone
- Taillights
- new guy
- One Thing That Pisses Me OFF!!
- Suggestions on buffing
- BOTH doors on '95 SC300 won't open. Locked out, what do I do? PLESE HELP
- Sc 300 Project " in progress "
- needles are off - then blinks ON intermittently
- Just finished dropping in 1UZ. Won't start. Help Please.
- Lowest mileage 1994 SC400 ever for sale??
- What should i do?
- 240sx Hub to SC hub?
- w58 with 1jz clutch help?
- Dropped car off for turbo upgrade
- Finally Upgraded to Rear JZA80 Mk4 Supra Rear BBK - Brake Job from Hell
- How to get a Brand New LS400 "BBK" for 188.00
