- Speedometer/Odometer Non-functional
- New look to my ride!
- Measurement to see if Work VS-ZF will clear LS BBK?
- Radio not working! Thoughts??
- Unsure of what to do with my 93 SC400
- To anyone who replaced a broken windshield...
- 98 sc300 brake master cyl diff from trac to non trac??
- Sc300 Play in the streeing wheel
- Wrecked my SC300, thoughts?
- Help: Power Window Problem
- Pic Request: Lowered/Slammed on 19's
- 6spd (2, 4th gears) not going in gear
- Filling emblem holes
- need 95 sc300 wiring diagram or some additional thoughts on fuse blowing?
- Anybody else fed up with their gas guzzling N/A 2JZ???
- Weird window issue
- Help please 94 sc400 stopped running
- Need your help for opinion the wheels!
- Sc300 headlights
- The Story of the Purple Bullet w Complete Pic's (the quarter of a million miler)
- Looking for 97+ fog lights and grille
- New toy, upgrade advice etc?
- Weird cluster issues!
- widebody opinions!!!
- Place to buy new oem headlights?
- Fun drag runs
- 2jzgte BWS366 boosting @ 12 psi...
- Temp Gauge Issue
- Supplier suggestions requested
- a3xx transmission cooler
- larger tires on sc400
- Alarms
- what to do with my wiring?? ideas
- Rare Jdm soarer aerocabin up for sale
- got new wheels finally, right before toyotafest!
- license plate lights doesn't work.
- Quarter of a million mile daily driver, runs like a Rolex
- Sc400 cluster repair
- 92 SC300 Wheel Bearing / R. Differential Advice
- --Adaptronic ECU Sponsorship Opportunity--
- 1993 sc400
- Window regulators differences??
- SC400 starts and dies won't idle
- FS goes in the classifieds, not here
- Newbie creates new photo album
- Which Custom tail looks better on my car?
- 97 sc400 ac relay testing
- Part identification
- How do you power up a 94 SC300 cluster for benchtesting?
- Need little help with buying a sc300
- Strange power window problem
- NA-T Question / Kit Question
- After Rack Replacement, any reason for Airbag Light to be on?
- Mechanic pressed trunk lock out. Don't have key
- Custom Engine undercover ideas ?
- 97+ rear bumper exhaust plug
- My lexus picture thread
- 2000 Tail light mod gone wrong
- SC in a land slide....
- weird connectors? whats this...
- Basic Tire Size Question - 92 SC400
- Photoshoot with my SC and R32
- Help
- Weird Issue with rear?
- Anyone have these headlights?
- Soarer and sc300 windshields
- 2jzgte with W58 speedo or odometer not working....
- Shine or AC sides and rear with pre 97 front + lip.
- i hope everyone has signed up on this
- Anyone ever repair their door lock actuator?
- Front tire wear... bump steer?
- Greddy Evo 2 exhaust
- What's needed to add stock subwoofer to base Soarer?
- Stock exhaust setup
- Toyota emblem for the trunk
- What should o sell my sc400 for?
- Blew the twins, so It's SINGLE TIME
- 96 sc400 seems sketchy
- no license plate lights...
- Found an sc300.... Good deal?
- Popping, clicking noise when I turn wheel. Mechanic says it is universal joint.
- Painting Valve Covers.....best "rattle can" paint?
- If you had to part with your SC What would you get?
- anyone running aftermarket sound systems, this is my first install need help
- A/C problems after Haltech
- need help 97 tail disassembly
- climate control problem
- Help cylinder 1 ignition issue
- Interior paint project.
- 1995 lexus sc400 power steering pump pulley
- Alternator plug swap?
- front end popping, turns in very easy
- Part number for gated shifter bezel
- I wrecked my car.
- Opinions on this body kit
- AC Code 11 Need some help
- Choosing the Right Rims on a SC. Black/Black
- F-Sport shift knob!!
- Wheel Color on a Platinum Metallic?
- Cheapest place for parts?
- what side skirts should i get for this bumper
- aftermarket headunit/sub amp install?
- ALLDATAdiy.com
- BBS CH-Rs
- Rideskinz Fujin VIP front lip with Shine rear and sides or complete Shine kit?
- all fs go in classifieds section only
- 92 Sc300 auto to manual Cost
- Body kit problem
- Sc400 is not charging properly!
- The Perfect Soarer???
- 93-98 Supra front bumper lip on Lexus Sc300/400
- Uzz32
- Should I paint my Sc rims gold?
- EGR hose connection question
- NEED HELP Sc300
- Ganador Mirror Wiring
- new sc300! slight project...
- custom door panels
- what are the diffrent years for the wireing in the sc400
- New lexus owner having electric problems
- Climate display blank
- Snazzy blue digital in-dash voltmeter installed. What voltages should I expect ?
- New shoes!!! Are teasers still allowed..??
- Ive searched, where to purchase T's project
- 98 sc 400 ECU with key
- Can I replace my 92 SC400 OEM radio with the one from 98 SC400?
- Sc400 Exhaust hangers
- 98+ SC400 vs 98+ GS400
- new '94 SC400 owner, need some pointers
- AMP issues
- SC Body Kit Advice
- Alarm goes off randomly in the middle of the night
- Greetings from SoCal Noobie..Purchase Advice!!
- 1995 lexus sc300 saved
- Which to buy: SC or muscle?
- Not so pretty '400
- kazama motor mounts question.
- OEM amps. high input or low input?
- Pre 97 spoiler installation??
- new here with a few questions
- New guy, looking at a SC400
- what is the weight of a stock chrome wagon wheel
- 1995 sc300 oil around top of motor
- bout to go ape ****** on this stereo
- Lip canards, what do you think?
- 96 sc300 new to the site
- Door Chime issue
- Cluster removed, No steering column adjustment
- Sun visor
- Why "Slammed"?
- Good Body, 260k engine
- 96" sc300 keyless entry chirp or honk diagram
- All FS threads go in the classifieds section D:
- Sc300 bent hub?
- "THE" clublexus eaton m90!
- power steering vacuum valve
- 1995 sc300 fog lights dont fit with 93 bumper ?
- lost all keys to 98 sc4, looking for creative ideas or advice
- Auto Headlights
- Is there any SC car meets in Orange County?
- Stance for a first time Lexus owner
- i cracked the stock ecu! full tuning capability free! download now.
- 1/4 Mile Times For SC300/400's
- Toyota has discontinued the V160 6-speed
- pics of my interior and engine bay
- 1998 SC300 Rear O2 sensor "mod"
- Little box with plugs in the front fender. Can i remove it?
- Im proud to be part of the club lexus family
- Rain guards
- Has anyone seen a Timing Belt break on SC300?
- New member
- Weathertech Floormats for SC's
- Tanin auto!!
- Free dead SC400, worthy of a GTE swap???
- FYI: Part numbers for 3 spoke steering wheel swap
- lexus sc400 5 speed swap
- Might Have Been asked a Million Times but Asking This
- Can you switch passenger/driver leathers?
- Soarer water pump
- Newbie in sc400: antenna sail mast?
- SC400 does burnout until the brakes catch fire
- wheel fit
- Soooo has any one ever done this? lol
- Climate a/c heater display not working help
- In desperate need..!
- Electric not working at all
- Rock Chip - Dammit! - Advice Needed
- 1996 SC400 - Music Options?
- any recommended shop to rebuild my r154???
- sc300 cut springs?
- 1992 sc400 cluster problems
- Can EGR be blocked off in car?
- Fuel Pump ECU Mod Question
- SC400 lips and body kits
- Wise/Behrman Spoiler??
- Toyota Soarer Cluster?
- 2015 Rebirth of the New Lexus SC 300 Turbo & J Lo loves the SC too!
- burning plastic smell!!??
- Soarer on the touge
- Turbo LS1 sc300 still going strong
- Radio not working please help
- Sad day sold the sc...
- Grounding Issue ?
- What Rims are these
- 2000 rx300 steering wheel swap
- Sc300 roller
- vinyl wrap seams
- PWR radiator
- Possible new Sc300 owner
- LFA Style front inlet idea.
- Quick questions from a newbie to the Forums
- 1996 SC400 150K - could this be a daily driver?
- New here -- Got a small leak! Help!
- sc400 windshield wipers issues
- Where to buy motor mounts
- new wheels for 2014 XXR968
- SC Rear Spoiler
- When was the first time you laid eyes on an SC?
- Free cluster
- Sold with a third of a million miles....
- Help with brake lights
- Tilt Steering Failure
- 98 sc manual books!
- Show me your gauges!
- First Lexus
- AC diagrams
- 2jzge egr delete
- Keyless entry + push to start
- I need help fast....Sensor!
- Climate Control Issue
- So the weathers finally better, so i washed the car.....
- spacer question
- SC from the future!!!
- sc300 speedo problems
- Anyone delete their high beams?
- climate control stopped working
- is lextreme safe?
- Part number help
- Help my hazard lights dont flash
- Weridest discovery about my door locks
- SC400 Battery & Tire Questions (Winter)
- How much is my SC worth?
- Interesting discovered feature
- can a Soarer fuse box work in a lexus
- Need Help !
- fuse box and battery relocation questions
- Bad experience with Lextech...
- Another gauge cluster thread...
