View Full Version : SC400 / 300 Classifieds
- CA Socal - SC300/SC400 Coilovers $600 (Good Condition)
- CA WTB:Sc300 MAF SENSOR paypal ready
- FL bunch of rare stuff/imported goodness
- GA FS: 92 Gray Driverside Airbag
- NY 1998 Supra NA-T part out, headlights, taillights, AEM, Turbo kit, etc...
- NY FS: W58 5spd Manual Transmission
- GA LF: R154 Transmission
- NY tan door still and drivers side rear panel
- CA Wtb: black interior pieces
- CA WTB : HEADLIGHTS good to perfect condition , highbeams ,
- VA WTB: soarer/Toyota badges
- CAN-Toronto FS: Use Tein Ha Coilovers
- CA 4 Sale 1gn 92'-00' SC300 DAIZEN Control Arms, & Steering Rck bushing kits $200
- PA Partial NA-T Kit + PHR Stage 1 Turbo
- IL Rear wing lip and trunk oem from 92-96 sc with led brake light
- FL WTB: 96-96 Front Bumper with Fogs
- CA WTB: SC400 rear rotors or Supra TT rear Rotors and calipers
- NJ FS: bushings, turbo, bov, header, tires, etc!
- TX WTB: 50mm Wastegate dump tube (stainless steel)
- WA FS: 1992 Lexus SC300 - Low Miles - $2500
- IN 700 hp na-t turbo kit
- TX FS Blitz Nurspec exh sc300
- NM NA-T dream complete turbo kit, Full-Race,AEM,GT4294r,Tial,1000cc inj., Fuel System
- NY WTB: Sc300 Fan Clutch
- NY WTB: SC300 Oil Pan, Upper and Lower
- TX WTB: Tanabe NF210 Springs
- CA FS: SC Stock Partout - MAF, Suspension, Engine Parts, Tan Interior, Stock Fuel, etc
- NC WTB: SC300 Coolant overflow with Tiny Bracket
- CA FS: 1994 sc300 motor/with tranny
- OK TWO COMPLETE 2JZ-GE Motors PARTOUT and MORE!
- MI MINT MKIV Brakes, Powder coat, DBA, Russell, Hawk pads.
- ID Boost Logic trans an auto tt rear end for sale
- CA FS: Interior Pieces, Wood Grain, Steering Wheel, Hazard Volume Temp Switches, Ashtray
- CA WTB lower radiator hose for 1jz sc300
- DC FS VVTI COILS/ WIRES/ IGNITOR with PIGTAIL CONNECTOR
- DC FS Passenger door handle
- NY FS: 97-00 Lexus SC OEM lower door molding pair in BLACK
- CA WTB: door panel & fender
- NY FS: 92-97 SC300 2jzge long block...NICE & CHEAP
- CA Wtb: Sc300 ! Latch power lock ! Ur part out sc !
- IL Glass high beam lights look new
- CA 97 Conversion Parts in SF
- AL FS:1jz twin turbos and two 38mm gates
- CAN-Toronto WTB 97 Inner and Outer Headlights
- IL lexus parts car
- International What is a voucher and why do I need one? Why did my FS/FT thread get closed? READ ME!
- MA WTT OEM front Lip for Wise Lip
- TX FS: New set of Daizen lower control arm bushings
- CA FS: Tan front seats
- CA WTB: set of oem sc3 brake pads
- CA Wtb: Stock sc mufflers
- FL NA-T parts XS-Power, mani, dp, ARP, etc all BNIB and reasonably priced.
- NY FS: Spring Garage Cleanup!!! something for everyone!
- CAN-Toronto 1992 dark green sc400 partout
- WI Soarer 1jz cylender head,Inatke mani & valve covers Merged
- TX Garage Sale: Various Parts (GTE/GE)
- CA WTB Drivers side Window motor and rail
- CA WTB: Strut/Spring Setup & 97+ fogs
- CA WTB: 97+ fog lights and front grill
- 97+ OEM Kit for sale: Sc300/400
- OK FS: Black rear seat belt buckle
- CA Oem Supra TT springs/ Scxxx Struts/Springs Complete/Front Eibach
- CA Oem sc400 springs
- CA FS: BEE*R Rev Limiter
- MD F/S 1.5jz
- CA passenger airbag, all 3 tan sunvisors
- FL WTB: P/S pump or pulley for sc300 in FL
- CA 93-98 supra apexi ni exhaust, greddy turbo timer,oem smic,1st gen gs300 ecu,more
- CA OEM TT HG Brand New
- WA sc rims for sale
- CA Driver side window regulator w/motor
- NC ALCON BIG BRAKE KIT SC300/400 SOARER/MKIV SUPRA (grex) used
- CA FS: 94 SC300 headlights and Bumper
- MO Driver's side fender/Interior parts.
- MD Fs 97-2000 sc400 driveshaft
- CA WTB: SC300 Motor Mounts, Radiator, Working Cluster
- NY WTB: W58 Bellhousing, 2JZGE Flywheel and PP
- NY FS:720 greddy cc injectors/HKS fuel rail
- CA 97+ front end part out,
- CA Hkb Steering hub,Bride rails,Soarer gauge.
- CA FS: chrome and black OEM emblems
- ND WTB 1jzgte auto ecu
- AR OLT'd cluster and climate control for sale!
- CA complete 97+ body for sale SoCal
- CAN-Toronto For Sale: 97+ Fog Lights - MINT!!!
- OK wtb: 1992-94 sc300 auto ecu
- IN soarer r154 with c's shifter south bl heavy flywheel and southbend clutch
- CA Wtb 92-96 sc300 ecu
- CA FS: 92-94 Taillights, Stock Pioneer Head Unit, 92-97 AirBag CHEAP!
- FL Flex-a-lite Electric fans 210/220 SC300/Supra
- MN WTB: 95-96 Center Caps
- International Wtb: Airbag adapter wire!
- CA FS: 18" BFG KDW Fatty Tires
- FL WTB 98 cluster
- CA Upper control arms, side mirrors, gas lid, steering rack etc...
- KS Toyota Soarer Model kit
- CA 1994 sc300 headlights
- CA WTB: front OEM "L" emblem chrome
- KY WTB 5-Speed Shift Bezel/Trim Piece
- CA 92'-94' Corner Lights Mint Condition! $50 obo
- OK WTB: Climate control and Driver door lock actuator
- CA FFIM, VVT-I GTE throttle body with dbw.
- CA FS: Greddy Profec B-II Boost Controler
- NJ wtb antenna
- CAN-Toronto FS: stock radio, amp, speakers, sub
- CAN-Other Nakamichi Stereo Parts
- IL supra tt calipers
- FL WTB cup holder
- PA interior parts for sale: minty door panels (tan), passenger window trim, dash vents
- CA FS: stock spring/struts
- CA WTB Spring/Shocks Set under $350
- CA Several stuff for sale
- CA WTT: black gas/trunk panel switch for TRAC button
- FL Apexi AFC2, v8 maf with filter adapter
- MD F/S 2jz-ge ecu
- AZ Cheap w58 tranny, flywheel, ecu, and wiring harness!
- TX 92-97 Ashtray with insert
- CA Window Regulators FS
- CA Fs: Used hks ssqv
- OK FS: 99 SC300 & 2001 RX steering wheels
- FL FS: 1JZ twin turbo from Soarer
- FL GARRETT GT30R Turbo and Tial WG For sale
- CA WTB: cd changer
- CA wtb:2jz-ge
- OR For Sale: NEW Supermade Clear Headlight Lens Covers
- OR 97+ OEM Body Kit For Sale
- TN 1992 DWP SC300 Part out
- CA WTB Front Gray seat
- AZ Clean tan interior, 93 tails
- IL FS: 97+ tails
- VA Interior door handles
- CA WTB Driver Side Door Hinge
- FL Supra TT wheels wanted
- FL WTB: SC3 parts
- IL Lexus sc doors part out?, sc 400 front bumper and lip complete
- FL WTB: 1JZ Soarer wiring harness & ECU
- GA WTB:Gray/Spruce Driver Door Panel
- CA Window Visors, 97+ black trunk+spoiler
- CAN-Other FS Brand New A/C Filter
- looking for 3" inch down pipe
- GA WTB: SC300 Fuel Pump ECU
- TX Wtb LCA w/good balljoint for right side
- CA WTB: Intake and Exhaust
- FL 2000 front bumper for sale
- IL Please read forum rules. You can't sell this here and if reposted you will be banned
- FL WTB: rear sump oil pan
- CA BC RACING COILOVER for SC300.400
- VA WTB: Original factory chrome SC300 emblem set
- FL Passenger window motor
- CA WTB: Pass Door Lock assy
- CA SOCAL:Fs/Ft; 1jzgte complete $1800 oBo
- MO WTB: Complete HVAC enclosure for 92 sc300
- TX Mounting Hardware
- MD FS: Stock SC300 OEM Fuel Pump
- MD FS: Stock SC300 OEM Headlights
- CA looking too by some parts!
- MD FS: Stock SC300 and Stock Soarer Front Calipers (2 sets)
- AZ WTB: Stock Radio w/ Harness & Bracket.
- CA EGR Valve
- AZ 1UZ Eaton M90 supercharger kit 4sale!
- FL WTB MK3 440 CC VPC Chip
- VA 97 cluster good condition
- 1uz engine
- GA WTB: sc300 HOOD for cheap price
- TX Passenger side supra 6 speed axle, Tein EDFC,Timing Gear, Fan Clutch, for sale
- TX WTB Right Side LCA W/ good balljoint
- OK WTB: Hideous eBay tails you mistakenly bought
- TX WTB: Stock JDM or USDM stock twins 2JZGTE
- OH Looking for power steering pump
- CA *Free* OEM SC400 lip.
- CA FS: Supra TT suspension 22k miles
- NY WTB: sc300 parts
- CA WTB: 97+ Fog Lights
- TX Competition Clutch Stage 2 for W58 trans
- MD fs: 1jz igniter and map sensor.
- CA 95 Tail light mint condition!
- International WTB: 95+ Tail lights
- NY WTB Some Black interior parts
- NY wtb: 1jzgte gearbox or r154 with shifter extension
- IL supra tt caliper set
- GA BUYING: R154 Tranny, 1JZ Bell-Housing, 1JZ Flywheel, etc..
- CA FS: BRIDE VIOS III low max, Corbeau Harness
- TX FS 1992,and 1995 Lexus SC300/400 Owners Manuals
- CAN-Vancouver FS:Rear Supra TT Calipers/Front slotted rotors/ Front brakes
- NJ WTB: Supra TT subframe mounts for supra sways
- TX WTB: gas lid workings.
- CA FS: HKS Hybrid drop in filter
- IL 5 speed rear end upgrade for the sc400
- CA FS: 98 SC300 Rear Black Spoiler
- FL Shine front bumper $350
- FL wtb auto shift knob black ot tan
- CA FS: SAFC2 Black + extension harness
- CA Wtb : Sc300 parts & soarer digi cluster !
- CA Wtb used coilovers
- FL WTB 97+ passenger side tail light
- FL need seats n carpet bad asap
- NC WTB: SC300 2jZGE Lower Power steering hard lines
- WI Tanabe Sway bar bushings
- GA Wtb parts for 1992 sc300
- CA FS: Tan Back Seats Upper and Lower: Excellent Conditon CHEAP!!
- CA FS: CARBON trunk SOCAL
- CA Big flow/[******in intake/BFI
- ID SC400 MAF and Exhaust Manifold
- TX FS: Greddy Emanage Ultimate
- NY I have some 98 sc300 parts layin around for sale
- CA WTB: 97 body, 95 tail light, Injen Air Intake, and JIC strut bar
- AZ FS: Misc Parts. Upper door panels, 92-96 rear spoiler w/ 3rd light, etc.
- FL 92-94 smoked tail lights
- NY wtb: 1jzgte 5 speed gear box
- OK WTB: Complete steering column
- FL Need Center Console ArmRest
- MN WTB: driver front fender for dwp 97sc300
- CA WTB: Coilovers or shock/spring setup
- CA fs 95 auto ecu
- CA 98' SC300 misc. parts+goodies!
- CA 98' Stock suspension
- FL WTB 2JZ-GE SC300 engine and tranny
- CA 1996 Lexus SC300, super clean, original paint, clean title, lots of pics
- FL w58+Bellhousing+shifter FOR SALE $500 obo
- TN DWP SC300 Part out!
- TX WTB front bumper
- AL wtb:44mm wastegate
- KS Custom made Cleared high beams (Rare) PRICE DROP!
- CA FS: DPW 97 body! final sale!
- FL 1jz part out - stock twins, hks bov, intake, polished pipes, manifold ect
- MD TRD 5MT shift knob $40 shipped obo...
- CA WTB: suspension springs or coilovers
- UT WTB: Black passenger side seat belt buckle
- AZ 95 SC300 Auto ECU
- TX Wtb sc400 exhaust manifold
- MI FORSALE :: D4S/D4C Garax 6000k HID Bulb Set & 6000k Xenon Depot HID Bulb Set
- MA WTB: caliper for a 97 SC400
- NY WTB: 95-96 front bumper complete with fogs
- NY WTB: Passenger Side Mirror (power, heated, DWP)
- CA WTB or WTT: Coilovers!
- CA FS Tan Seats F + B
- MA W58 Parts,SC300,2JZ stuff cheap...
- CA 2 cannard
- FL Need Front Seats Bad
- AZ WTB: '92 SC400 door panels, center console
- OH WTB: vertex widebody, stance coilovers.
- VA SC 300/400 car cover, shocks and soarer griffen steering wheel cover for sale!
- NV FS Tan Carpet low price :)
- TX WTB: SC300 AC Compressor
- CA GOT weatherstrip??
- VA 1JZ Swap JZA70 pnp for SC300!!!!
- IL Looking for an R154
- VA WTB: Lighter Assembly
- VA Wtb: 1995 sc300 ecu m/t - va/dc/md
- MD FS: intercooler piping 1jz
