View Full Version : SC400 / 300 Classifieds
- WI 2006 RSX type S front seats (black leather)
- CA Tein EDFC
- FL WTB: 1JZ-GTE Alternator
- CA 97+ SC300/400 door molding and spoiler FS Los Angeles
- CA 1jz spec lightweight flywheel
- FL Tein Flex Coilovers
- FL WTB 1jz bell housing, 1jz flywheel
- AL WTB Brown Flip Down Cup Holder
- NY WTB straight(non curved 5spd shifter)w58/r154
- MD Part Out: 93' SC300 Shell Blk/Blk
- NC 95 / 96 taillights on great conditon
- CA **FS: 92-94 OEM Tail Lights**
- CA WTB : Throttle Body with all the sensors attached for 92 SC300
- FL F/S 1jz long block
- CA FS: 97+ Gated Shifter no bezel and 97+ Side Skirts
- CA WTB: CA Looking for stock catback exhaust for SC300
- CA Greddy Emanage Ultimate
- IL WTB: 95 Fog light, Spoiler, Glass highbeam, Tails, Radio,
- IL 5speed Swap sc300 complete
- CA Wtb:w53/jz bellhousing & flywheel
- CA Partial Black interior for Trade + cash
- AZ For sale: Tenzo r type-m wheels and tires
- AZ WTB/WTT: Espelir ASD front springs
- CA 99 Sc Rear Tail lights OEM tailights 97+
- NC WTB: Rear bearing, hub assembly
- MS WTB: 18's w/tires for 92 SC400
- VA WTB: Single exhaust
- TX WTB - Stock 1999 pioneer amp
- CA WTB: Coilovers
- CA WTB: Fan shroud and fan clutch for my 1JZ
- CA Wtb: w58/jz bell housing and flywheel
- FL SCx00 hood with cut out
- CA 92-96 front bumper, rear tan passenger seats, front passenger seat, 92 corner lamps,
- FL W58 trans
- CA WTB: 95+ passenger side window Regulator
- CA F/S Supra front TT brakes
- CA FS: DPW 97+ sides, rear bumper &rear valences
- CA Wanted : Front struts and springs
- CA WTB: Dashboard Center Vent Assembly
- NY wtb: 2jzgte wiring harness (asap)
- OK WTB: Struts/lowering Springs or Coilovers
- CA Seat Bracket&rails Passenger and driver
- TX FS A/C Brain Only
- TX WTB: gray driver side door panel
- CA WTT Vertex front replica on any stock front bumper
- CA 2JZ-GE Full Complete Motor + Auto Transmission $500
- FL Garage Cleaning sc300/400 parts
- AL WTB: Lowering Springs
- CA WTB: 97+ fog lights
- MO WTB black or gray carpet
- TX New Driftmotion Stainless Steel Power Steering Hose
- NJ WTB: OEM 5speed SHIFT KNOB
- CA FS: Replacing Rubber string for seat nets for $3
- CA 93.5-96 motor mount brackets, and complete 2jzge part out
- FL FS: OEM Lexus Tan floormats in great condition
- VA WTB: 93 SC300 interior and exterior
- OK Throttle Body and Distributor 1996 SC300
- VA WTB Factory Nakamichi Amp
- NY Part Out: 98 lexus SC-300 complete NICE
- CA WTB : ECU / MAF for 92 SC300
- TX WTB: 92 5 speed sc300 ecu
- NY 1995 sc300 parts
- OR WTB: Early SC300 5 Speed Cluster
- FL Supra W58 tranny
- MA FS: TT OEM Suspension
- CA FS: HKS Ti Dual Mufflers Only
- MS FS: Custom 3 gauge Pillar, Defi FP Gauge
- VA R154 13 lbs lightend flywheel
- CA Lexus SC300 Front Brake Pads....$40.00 Shipped
- NY FS: Carbing supra strut bar with MCS
- GA WTB: SC400 automatic transmisson
- MD SC400 Front Lip Spoiler
- MD FS: 1jz-gte Timing Belt Brand New In Box
- CA wtb alternator for 2jz asap!!! will pick up socal
- TN FS: Haltech Platinum Sport 2000 (NA-T plug-n-play)
- FL FS: Apex'i SAFC 2
- CA Wtb: 97+ fogs, grill, headlights
- CA FS - 38 MM Tial Wastegate Brand new
- FL Brand New DriftMotion PS hose
- CA 97+ SC300/400 tailight for sale
- CA socal: 2jzge 1994 Sc300 / supra Auto engine harness
- CA WTB driver side fender. Socal.
- CA wtb: dwp 97+ front sides and rears
- WI WTB: DWP Gas door
- WA WTB...Driver side fender in black
- MD Ac kit/performance/interior/ everything has to go
- IL Gray center counsel in good condition, cheap
- TX FS= NAKAMICHI front door speaker enclosures
- TX WTB- Drivers Seat Leather +++++++
- TX Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts
- CA WTB : IAC / ECU / Ignition Control Module for 92 SC300
- CA WTB : IAC for 92 SC300
- CA Dave H turbo kit NEW PT61
- AL FS:clutch kit for ge
- FL Wtb: Map-ecu
- CA WTB : TPS sensor
- CA WTB: 12 CD Changer for '95 CS300 (86273-24030)
- MA FS: Strut Tower Bar
- AL WTB:screw in type o2 sensor
- FL WTB: OEM Mudflaps
- MA few parts- garage clean out
- VA WTB Lots:JDM Soarer/1JZ full swap/Turbo and performance parts
- MS FS: Tan Soarer Steering Wheel
- MA Looking for GE head in MA
- MA WTB: Trunk and spoiler
- NC FS: 1JZ CUSCO hyper Single Clutch/Flywheel *Ultra Deal*
- FL i need 2 headlight housings, with no lenses
- MD Tan Master window switch
- NC WTB: 1jz or sc300 lower (short/thick) A/C Lines
- FL WTB: Driver Side Knuckle
- IN FS: GOOD cupholder and some emblems
- MD 1jz Intake Manifold, Cam Gear Cover $50 Shipped
- FL WTB factory Air Intake
- CA WTB Drivers and Passanger Door Lock Actuator
- FL GE motor, cruise control, BL 2.5 MM HG, w58 5 speed, v8 maf
- FL HKS Racing Ti MKIV catback
- CA WTB : Fuel Pump
- MD Supra TT Auto Diff 3.77 LSD
- OH WTB: W58 flywheel
- NY TONS of black interior parts for sale.....
- NY FS: JDM 3 spoke steering wheel
- NY FS: AEM Wideband
- CA Wanted : Springs / Struts / Shocks
- CA looking for some used T&E Vertex Front Lip
- CA WTB: "Lexus" and "L" trunk emblems
- FL Wtb: 92-94 Cluster
- MS FS: 1uz-fe SC400 parts: engine, oil pan, manifolds
- CA F.S. Socal SCXXX A/C parts, Trunk, Misc.
- MI 5 speed swap w58
- WI WISE sport lip in mint condition
- CA WTB: High pressure power steering hose
- VA WTB: 97+ SC300 Gauge Cluster
- FL Brand new 5spd lexus clutch line
- FL Injectors 870cc and fuel rail 2jzgte Pick up only
- TN WTB low mileage 1uzfe, hopefully near TN
- CA 5 Speed OEM shiftboot
- CA WTB: w58 bellhousing & flywheel
- MD FS: Drift Motion Stainless Power Steering Hose
- CA FS: EBC Yellowstuff rear brake pads (Supra TT)
- CA wtb: excellent condition sc400 grey driverseat
- CA WTB:coilovers that go really low for 92 sc400
- CA SC300 headers (Xerd)
- TX 1998 Lexus SC 400 v8 White with Tan 90k
- CA 5 Speed Harness, MT ECU, 2JZGE Engine SoCal
- FL 1j long block
- NY WTB: 2JZ Crank Pulley
- VA Fs/Ft:Built Th400 setup for GTE
- CA Brand New Greddy Front Strut Bar
- MD FS: 1jz Throttle Body w/ Super Sequential Blow off Valve welded on
- MD FS: Supra Auto TT LSD in SC300 Auto Pumpkin
- MD FS: Power Steering Pump & A/C Compressor
- PA 1999 SC300 2jzge motor, auto transmission & much more
- FL Parts for Sale Pick up only
- CA 97+ JDM bumper & replica Wise spoiler
- NC WTT apexi power fc boost control kit for 1jz soarer ecu
- CA FS: Supra MKIV MVP Motorsports Max-Air Intake Heatshield/Piping/K&N filter
- MS FS: Used Complete Automatic Transmission 1JZ
- PA FS Greddy SCL
- CA Fs: Soarer digital cluster !
- WI WTB ++ SC400 Rear driver-side Brake caliper ++
- CA Greddy STB ; GTE spark plug cover
- FL sc300 5speed pedals
- CA FS: ESPELIR's & KYB GR-2 strut combo!
- MA FS: 92-94 Taillights (Smoked amber)
- CA WTB : mass air flow sensor MAF, 92-95 sc300
- MS WTB: Interior Door Panels
- OH WTB w58 flywheel
- MD FS: Full engine gasket kit 1jz-gte
- NV WTB: Driver Door Panel, Door Handles (both)
- TX 2jz gte twin turbo sc300 swap $2500
- CA WTB SC Spoiler and/or trunk
- FL I cant wait for this to happen again<<<<have withdrawels
- FL 7M-GTE Injector Resistor Pack (for 1JZ inj)
- FL "REAL" walbro gss331 255lph fuel pump F/S
- FL W58 Flywheel
- MA WTB: 2 front sway bar links and o2 sensors
- CA wtb: 96+ alternator plug and resistor pack
- NM WTB sc300 Shift bezel
- VA FS: R154 lightened flywheel 13lbs
- FL WTB Rear bumper lip+ pasenger side 97 tail light
- CA TOMS billet 2JZ oil cap
- CA SFBAY local; many 2jz-gte parts, and NA+T parts W58 slave new
- HI WTB 93 sc400 ecu
- CA Sc300 Complete sunroof!@$#$^$@&*@$^*%^*
- KS FS Real JIC Magic Front, no knock off copy
- CA FS:D2 coil-overs. Barely used. 700
- IL WTS: Greddy E-manage Ultimate
- CA FS: 97+ side skirts and door inserts
- CAN-Other WTB Ls400 front caliper and spark plug wire cover for 1jz
- CA WTB: New or used injen intake for SC400?
- IL WTB: 2JZ oil level sensor for rear sump oil pan
- CA WTB: piston rings and bearings.
- CA Anyone in need of a 1uzfe??
- Anyone in need of a 1uzfe??
- AL FS:92 sc300 harness & computer,ge partout
- CA 1UZ-FE MAF Sensor
- CA FS: 97 SC300 Complete Front Brake Setup
- CA FS: sc300/400 brakes, front & rear! oem & aftermarket!
- FL WTB 2 sc300 Front fenders!!!
- CA WTB: Seat brackets
- FL FS: Driver side Highbeams
- OH FS: 2jz-GE 5 speed harness, GE 5 speed ECU, GE head
- NY WTB: Cut SC300 harness
- CA Fs 95 auto tranny
- CA FS: SC400 OEM Front Lip / FS: Stock 2jz Fly Wheel
- AL WTB:stock motor mounts
- OR WTB 1jz/2jz stock power steering reservoir
- MD WTB: Soarer Emblems
- FL W58 COMPLETE W/Extras Works PERFECT.>!!
- FL WTB: Driver Side Window Regulator
- IL WTB: Black OEM center console trim bezel
- FL FS: 2JZ-GTE JDM Head
- FL Fs: Apexi neo - bnib
- CA FOR SALE: Black Interior Parts/K&N Air Filter/Door Panel
- FL 5spd Shift Knob MINT condition
- FL FS: LS4 BBK Calipers
- FL Manual SC 300 Radiator and HKS DLI
- MA R154 For Sale
- TX wtt: used master key w/transmitter
- VA FS: Upper Interior Window Trim
- NJ WTB SC300 radiator
- TN WTB used axle back exhaust
- TN So you need door parts?
- NJ wtb 02 sensors
- FL sc300 motor parts
- CA Brand NEW Drivers side 97+ Fog Light, 97+ Rear Bumper, Roof Wing, Stock Radio
- FL wtb: SC300 motor mounts asap(good condition)
- OR 97+ New in box Fogs, New Grill, used extensions
- VA WTB: in need of both door moulding for 97+ sc300/400
- TX 1999 SC300 OEM wheels + full size spare = $275
- WA WTB: SC300 Manual radiator
- CT WTB Vertex Ridge Wide Body Style kit
- GA LF: Splash shields and Front extn.
- MD Wtb hks 272 cams
- NJ WTB: 92-95 OEM Front Lip
- CA Bumper 97+
- NC WTB SC300 2JZGE head.
- FL Greddy boot solenoid
- CA WTB : 97 tailight, driver side only in good condition
- CA FS: stock 1jz downpipe
- LA Map-Ecu for sale.
- FL WTB: Soarer Emblem, Griffin Emblem
- CA Tom's Advox Coilover for sc300/400
- CAN-Vancouver WTB: Power Steering Pump for 95 sc400
- CA Wtb used sc400 coilover
- RI WTB AutoCouture Kit
- MI WTB:Daizen Camber Kit F/R
- CA WTB: GTE map sensor and ignitor
- GA 97+ Headlights for sale!
- wtb automatic soarer harness
