View Full Version : SC400 / 300 Classifieds
- MD 5 speed pedals, master cylinder, trd shift knob
- CA fs brand new 86.5 cp pison rings will ship
- NY FS: 97 Tails - PASS and Drive with harness
- KS Carputer car PC with 10.4" touch screen console
- MD WTB: green or black oem hood
- CA fore sale-many parts for sale that were going to be used one a gte swap
- NY FS: 98 wood ashtray
- NJ OEM timing belt and waterpump SC400 1UZFE
- TX FS: Lexus SC driver and pass seat rails for sale
- WA wtb: lowering springs
- NY FS: 97 Driver Tail
- CA Buddy Club coilover
- NC WTB front camber cam
- CA FS: '99 Black Interior - $700!!!
- NJ RMM Supra TT Auto LSD w/3.769 MK4 Pumpkin
- AL WTB 1jz ENGINE HARNESS ASAP
- NY 1997-2000 white side skirt
- CA wtb 4 wire oxygen sensor
- International Fold down cup holders x 2 $50ea - black
- CA Griffin emblem (for the front)
- CA 2zjge rebuilt w/turbo internals
- CA sc300 trans, uncut wire harness, maf
- UT F/S**97 LS400 Calipers**
- FL Fs: 1jzgte and 2jzgte parts
- NY Selling 92 SC 300 Power Steering Pump
- NY WTB 98= Gated Shifter & more
- MI FS: Window Switch, High Beams, ect...
- TX Ppassenger side PW/PL controls in tan or black...
- FL FS: Driftmotion lightweight (11.5lb) Flywheel & Clutch Combo
- FL 264 in & ex cams
- FL 2JZ GE Head
- DC Tt map sensor and ignitor
- MD WTB 97+ sideskirts and rear bumper
- NJ WTB/WTT:: Decent set of wheels and springs
- GA trade my badge for your gold one
- WI 1997 fogs
- NY R154 full JDM setup
- CA Intake Manifold with Throttle body Cheap
- WI FS complete 5 speed swap
- CA CA: FS 1998 sc300 parts
- NC WTB: Temp. Gauge Needle
- NY FS 97 Auto Tran & Engine
- FL WTB 1jz/2jz oil pickup for rear sump ASAP
- GA WTB Back of the Rear Seat
- NY FS: 97 Parts
- CA FS: 97 Front and Rear Black Seats
- CA FS: LS400 calipers and window visors
- IL Wtb..Driver side door panel (gray)
- FL WTB rear lower seatbelt surrounds
- CA full race 2jzgte motor
- FL SC300 Complete service manuals FS
- NY interior parts needed
- CA FS: 92-98 Lexus SC300 BRADI Front drilled/slotted brake rotors
- WA Sc400 ECU
- GA WTB DWP 92-96 rear lip, or DWP 97 rear and extensions
- GU 2JZGTE Oil Pump
- CA F1Spec type-2 Carbon Kevlar seat
- GA WTB/LF: 97+ front bumper, Fog lights, headlights, etc.
- NJ Sc400 shift bezel
- CA FS: SC400 Front OEM Lip & Wise Lip
- CA WTB: A pillars.
- FL BNIB Autometer gauge cup 22.00 shipped
- FL 2 new oem sc400 motor mounts 210 shipped
- TX Aristo: Auto Trans, Injectors with rail, Oil Pans, TURBOS
- FL WTB window switch and inner door handle
- AL 2 used ignition coils for 1997 SC400 for sale
- AL set of used plug wires for sc400 for sale
- IN fs mk3 r154 $800
- CA WTB 93SC Center Vent Assembly (Not cracked)
- IL TRD Leather shift knob
- DC 93 sc400 rear bumper cover cheap
- FL Rear and Font Bumper
- NY FS: 5 speed pedals(brake, gas, clutch) and clutch master cylinder
- NY FS: LS400 Caliper Bolts (short ones - not cut)
- MD WTB: SC300 5spd pedals
- NY For Sale 98 SC300 Headlights used
- TN WTB coilovers
- FL Wtb drivers rubber door seal
- CA WTT 98+ sc300 front bumper
- NY FS: 97 Grill
- NY FS: 98 Conversion Parts
- CA FS: Stock Springs and Front Top hats
- CA WTB 92 sc400 taillights w bulb harness
- NY FS: stock parts
- CA FS: Front Lower LCA's, both sides
- NC WTB USDM TT turbo's
- FL WTB 97+ Fog lights, door molding, and front grill
- CA SC400 chrome wheel
- TX FS supra TT shocks
- VA WTB SAFC 2 and other things
- FL WTB cheapest random fender
- CA fs sc400 power stering reservoir
- CA Eibach Springs (Supra-spec)
- FL WTB Manual Differential!!!!!
- FL 98+ SC300 Gated shifter and 98+ gauge Cluster
- FL WTB: Low Mileage SC300 Auto Gauge Cluster
- FL FS BNIB gmb sc400 waterpump
- WI 95 Ls400 BBK
- FL Blitz Nur Spec Duals SC3 Spec......
- NY FS: TRD Steering wheel / TT desno fuel pump / Sparco Monzas/ Defi
- TX WTB: trunk latch
- FL SUPRA TT Brake Kit
- CA Supra BBK, Origin kit, few other things
- NY sc300 5 speed ecu
- NV FS: stock 5 speed parts
- LA WTB: 95 SC300 Harmonic Balancer - OVER NIGHT NEEDED!
- TX r154/w58 swan neck shifter
- CA WTT 2JZGTE to SC Harness
- TX WTB: sc300 fuel hanger cover
- OR FS: 1jzgte map sensor $100 pp/ship include
- MD 1jzgte exhaust manifold
- PA WTB: JZ/R154 Bellhousing
- TN WTB: 2JZGE VVTi Idle Air control valve
- CAN-Vancouver WTB SC4oo Coolant reservoir!
- GA A/C Pressure Regulator
- CA WTB: Soarer emblem
- WA FS: Cusco Chromoly 7 Point Roll Cage
- NY Garage Sale pt2... 1j and 2jz parts..
- MI 313sc3's for sale list.
- MD 2jzge part out
- FL TPS Harness Conector
- CA WTB: 1JZ Oil level sensor in pan
- CA Supra MKIII R154 driveshaft SoCal
- FL misc sc parts f/s
- MD Supra tt motor mount93-96
- FL WTB 94-97 sc300 stock 2jz-ge 305cc injectors
- CA BUNCH OF PARTS OFF MY 97 sc300
- NY SC300 Rear pumpkin with LSD 3.77
- CA Wtb:ur broken cluster/spare
- GA Fs: R154 front half driveshaft
- WA WTT: DWP front bumper with lip spoiler holes for one with no holes
- TN SC400 IMF headers--pick up only
- TN FS: 5spd ECU/ignitor -- sc400 ECU/ignitors -- FP ECU
- CA BNIB - Power FC and Commander for 1JZ and 2JZ HKS 1.2mm metal Headgasket
- MD 97+ Tail Lights
- FL Garage Cleanout
- CA WTB: sc tophats
- CAN-Toronto wtb: 97+ tail lights and fogs, coilovers, exhaust etc
- FL BNIB Koni Yellow mkIV Supra or sc300/400
- CAN-Other WTB: Green DS Fender, Passenger Door actuator
- PA wtb: 1jz r154 flywheel
- LA WTB: 95 SC300 Power Steering Pump
- TX FS Tan/Black driver side master window switch
- FL New oem purolater air filter 15.00 shipped
- WI FS BNIB sc300/sc400 5spd COMPLETE pedal assembly
- IL WTB: 97+ left taillight
- IN FS: NEW Supra Bilstein Shocks, Hypercoil springs
- CA SC300 Rear Brake drilled/slotted rotors and pads
- CA w58 5 speed for sc300 socal
- CA WTB a "manual" cluster for 1993 sc300
- MD Tan door panels
- GA WTB: R154 manual tranny
- AZ jzs147/jza80/jzz30 lowering springs!!!
- TN WTB 1JZ in South East
- CA OEM toyota japan window visors. NEW
- FL WTB: Stock Front Brakes
- FL wtb driver side fender
- CO SC300 1JZgte Koyo radiator
- WA New Spark plug wire set
- CA FS: 97+ Fog Lights
- LA Ultimate Gauge deal! look inside!
- TN WTB: 99 ECU w/ KEY
- FL h3 yellow hid kit 30.00!
- AR wb:1jzgte swap throttle cable
- HI Wtb: 93 sc300 ecu asap
- FL WTB: 1UZ Engine harness
- TX Supra TT Stock Suspension (Spring+Shocks)
- GA WTB sc300/400 lamp failure box 95/96
- NY 1997 Black SC300 Interior & Misc Parts
- NJ FS: OEM Pioneer Headunit and Sub
- MA WTB: GATED SHIFTER sc300
- CA FS Apexi Afc Neo
- OR WTB MKIV Black seats
- FL FS: Precision 70mm turbo. 0 miles!
- NE FS: Tan Steering Wheel w/ NEW Leather
- NY FS: TRD Front Strut Bar
- NC MaftPro - Injectors - FMU - Plugs - K&N Filter
- CA wtb 2jz w58 manual trans pedal clutch master cyl etc.
- SC WTB: SC400 Power Steering Reservoir
- FL Wtb: 2jzgte t4 manifold
- TX 2jzgte veilside style intake manifold-- CHEAP!!
- CA TW: oem 98+ front, sides, rear bumpers...
- MA 99 sc door panels
- TX FS: black leather front seats in fair condition $100 for the pair...
- TX SC300 OEM Pioneer AMP - $70 shipped
- LA ATi super damper crank pulley
- LA Tial 44MM $300 shipped!!!
- TX WTB: FMIC for 2jzgte sc300
- KS WTB: Tanabe NF210 Springs
- TX WTB: Nakamichi Amp
- NC jdm93400 sale thread help me out guys
- IL WTB: R154 Swap Parts Needed
- NC WTB 2jzgte to SC300 wiring harness
- CA sc300 tan carpet
- FL Supra tt shocks&springs 150.00 60k miles
- International WTB Standart Headlights LH+RH, LH taillight
- AL WTB... Stock Front Spring.....NOW!
- TX FS: Exhaust & Fuel Pump
- VA WTB 95 Passenger Fog Light
- FL Evo brembo calipers 320 shipped!!
- NY WTB: Pre-95 bumper, DriverSide fender
- CA Stock TT Supra Suspension..45k miles on them!
- CA Misc. Parts for sale
- FL SC300 Tan & Black Interior Garage Sale
- LA WTB: DS Door Harness
- CA Free 2JZ-GE w/ JDM intake delivery avail Bay Area
- MD Chrome/Gold Winged Griffin Emblem FS
- FL New oem sc400 motor and trans mounts
- NJ FS: Black Wingless Trunk
- CO WTB: Wire harness behind radio
- LA NA-T part out sale!
- WA WTB Sc400 ECU
- NY FS: 97+ Sideskirts for the pair
- WA wtb vertex ridge side skirts/rear bumper
- CA WTB: Stock Fan Assembly
- GA WTB/LF: Car Cover
- TN WTT/FS: Tan 3 spoke steering wheel for IS300 black steering wheel
- TN WTB: Black Climate control knobs, Seat controls, Window/mirror swiches
- CA FS: Apex Grounding Stabilizer & Alutec Front Strut Bar
- GA WTB SC300 Front Upper Control Arm Bolt
- TX WTB supra tt eibach pro kit lowering springs
- TX FS/FT Vogtland Toyota Supra lowering springs
- NY FS: TOPSPEED PRO-1 Axlebacks
- MD FS: Greddy T78-33d (67mm turbo) cheap
- NY FS: 2JZGE Turbo Exhaust Manifold & W58 Fidanza Flywheel Coilpacks
- CA For Sale: 97 + Tail Lights with Harness $200
- NY WTB Black Driver Side Front Seatbelt
- FL WTB: T4 Turbo Blanket
- NY wtb upgraded sway bars !!
- LA 92-96 SC300 MAF $100 shipped
- CA xerd headers and midpipe for sale socal
- IL WTB:97+ fog lights
- CA WTB: KYB Shock 94-96 Supra
- AL Center Arm Rest
- CA Interior For SALE!!!! CHEAP!
- CA FS NGK Laser Iridium spark plugs
- TX FS: Greddy Speed Limiter Cut
- CA FS: USDM 2JZGTE OEM ECU, IM, TB lower runners
- LA 2jz-ge FFIM!!
- NY FS: LS400 Front Calipers
- CA 1jz bellhousing wanted
- UT interior part out - 92 SC400 plus fenders/doors/trunk/head and tail lights
- TX WTB: Lock cylinder / Driverside door lock assembly
- GA WTB: Upper door trim
- IL BLACK lower door panels
- CA **FS: Vertex Rep Full Kit Brand New**
- CA FS: NEW TPS Throttle Position Sensor *JZ-GTE 89452-22080
- CA FS: Passenger Fender
