View Full Version : SC400 / 300 Classifieds
- FL FS: 1jz chaser ECU ....WTB: 2jzgte ECU
- GA Georgia Garage Sale - SC / Supra / 2jzgte / oem & aftermarket
- NY Fs: 97 lexus sc300 partout
- MD FS 1997+ Rear bumper + extensions
- CA WTB non Ca ECU (ECU without 3rd O2 Sensor)
- CA FS powered by max SC300 JZZ30/Supra JZA80 coilovers
- MD 1jzgte VVTI Head/Ecu/Harness/Front Sump Pan
- CA WTB: Starter for 97 Sc300
- CA carbonetics lsd for 6 speed rearend socal wiill shipped
- OH FS 1998 front bumper black (needs some work)
- FL big brakes fs
- FL WTb: white plastic cap for seat motor
- HI Custom fiberglass subwoofer enclosure spare tire well
- SC Wtb:40mm-50mm wastegate and other turbo stuff....
- CA Fs: Usdm twins & aristo jdm twins !!
- UT Wanted: sideskirts
- CA FS. Blitz SUSpower core type LM air filter $70 91770 area
- FL nardi torino steering wheel and nrg adapter
- CA FS/FT sc400 stock F calipers/rotors & airbox w/K&N filter
- FL WTB: Wanted 97-00 Lexus SC Tail light( Harness)
- 93 SC 400 coil springs, take off used
- CA Carbon Fiber 92-96 OEM style wing
- FL Ogura JZ/R154 HyperSingle plate clutch!
- TX borg warner s366, na-t fuel rails and more
- MO Wtb: Jic magic spartan full catback exhaust
- CA WTB: 95-97 SC300 Chrome Center Caps
- MI WTB Tan Passenger Door Panel
- CA FS: As New 97-2000 Tailights w/ Harness and Bulbs
- WTB: Stock coil springs
- UT WANTED: DWP Front Bumper Cover
- NY F/S 2jzge turbo kit
- MD Rebuilt 1jzgte complete swap
- CA WTB Sc300 keyless entry
- FL WTB...97+ driverside tail
- IL Wald 97-00 rep front lip 450.00!!
- CA FS: Supra Rear Seat
- LA 1jzgte ecu inner cooler coil packs.
- KY WTB:AEM v2 or Haltech sport 2k,TT Valve and Spark plug cover, oil pump etc...
- FL SC400 struts and Tanabe springs nf210
- CA FS: '95-'96 Tail Lights
- GA 750 HP!! NA/T Part-out Best of Everything - Must See!
- AZ wtb fan shroud; does not have to be perfect
- CA FS: black window switches and center console knob caps
- TX wtb bfi intake box and the kit
- CA Wanted : lowering springs new
- FL Wtb: Silver spruce ds fender
- CA wtb 97+ tail lights and 97 fog lights
- FL Black front seats 200.00!!
- NJ WTB canister purge valve p/n 90910-12168
- FL *2jzge full engine seal kit*
- IL 1997-2000 Sc Door Moldings
- AL FS: R154 Front Driveshaft
- CAN-Toronto WTB:Front and rear wide fenders
- CA Stock Pioneer Head unit, 12disc changer w/mag
- CA f/s R154 Fidanza Flywheel
- NY Polished Intake Manifold
- FL f/s supra tt front calipers/rotors and pads
- TX Stock Pioneer Head unit, 12disc changer w/mag, and Stock Amp
- CA Fs: Jdm aristo twin turbo !!
- WA WTB: Full Vertex Replica kit
- AZ FS: 1uzfe(sc400) PPE performance headers
- MD Black Parts - No offer refused -
- NM WTB: Drivers side hi beam 95 SC300
- PA WTB sc400 ECU
- VA WTB: 2JZGTE Throttle Cable
- FL Holset H1C, Garrett GT35R compressor Housing, 8 Blade 500+whp turbo!
- FL PRECISION PT67 Journal TURBO/1JZ CAMS WITH GEARS
- CO WTB passenger door lock actuator
- ME 1996 JZX90 1JZGTE swap w/ 20k miles
- CA (FS) TAN drivers side airbag
- FL FS SC Parts
- CA WTB: 1jz soarer ECU
- FL wtb: 1jz engine harness
- WA WTB: DWP 97+ SC300 full oem kit
- ME LOOKING FOR PARTS ASAP ! What do you got??
- CA parts you maybe interested in!!
- NV WTB 92/93 sc300 ac compressor
- CA FS: 97-00 Fog lights, 97-00 front grill
- CA WTB sc300 bra
- FL WTB 95 Fog Lights, 93-96 high beams, set of OEM headlamps
- OH Some goodness
- WA WTB: SC300 Supra Manual Pedal Assembly Pedals etc
- GA FS/FT 1jz\2jz parts
- TX 1000cc injectors
- MO 2jzgte intake manifold
- FL Black interior and Boost Logic crank pulley
- IL 2jz gte us Spec Auto Transmission
- MD FS: Garage cleanout - stock wheels, radio, pass. glass, 95+ gold spoiler
- PA WTB: 98+ Left Tail Light
- MD wtb door panels, black carpet, tan front seats
- CA FS: Jdm Steering Wheel, Stock Steering Wheel, MDX antenna, 92-94 Tailights
- MD fs: OEM toyota 1jzgte/2jzgte oil pump - NIB
- NY Sold my sc sale. FFIM, Daizen Bushings, fog lights, Grey parts
- FL Front sump tt oil pan set up 125.00!
- OH WTB: 1jz alternator oval plug.
- CA Black Rear seats
- CA f/s brand new in box carbonetics lsd for 6speed
- FL FS:GENUINE GARRETT TO4R (T67) Turbo
- NY FS: SC BLACK front seat side trims & control & back map pocket panel OEM LH or RH
- TX SC300 Free AC Compressor, Front calipers/pads/rotors, Gates Belt
- FL f /s genuine precision 750 hp intercooler
- CA SC400 stuff also SC430 TQ Headlights Headers
- IL Garage Sale!! SC400!! Everything must Go!!
- FL Black center console & e-brake boot
- AL BNIB GTE parts and ferrea
- CA FS: BLACK passenger door card
- CA SC Stock Springs + Free SC Parts
- MO Master Power T-70
- TX WTB: SC Hood and MAF
- CA FS: 99+ OEM Black Front seats(Perforated)
- CA fs diskchanger
- TX DWP fenders
- FL JDM 2JZ-GTE 440's $75 shipped
- FL WTB: 1JZGTE manifold T4 divided, fuel rail -8 or -10, valve covers, oil pump.
- CAN-Other WTB: Half/Lip Kit
- CA FS Carbing radiator cooling plate $75.00 shipped
- FL Supra tt center caps 35.00!
- CA FS: Black Interior and misc items off 95 5spd
- OR WTB Heater fan transistor for 95 SC400
- CA Two 2jz TT Ignitors with pigtails, tow hooks, na auto driveshaft, 97 repair manual
- FL Holset HY35, 1JZ-GTE T3 mani, 46mm wastegate and dump $700
- FL JE Pistons Brand new and Injectors
- GA Wtb 2jzgte water neck w/ bypass pipe
- FL 2jzgte ecu auto usdm SC tan driver side window switch
- VA FS: Full Set of Stock Suspension,Climate Control, and Stock Radio
- CA WTB===> (TAN) Driver side Interior door panel
- CA BNIB W58 to 1uzfe adapter plate
- TN WTB: HKS Style Wastegate Spacer/whole wastegate
- TX wtb window switch assembly for driver side and passenger
- FL Anyone sell the Shine Auto front bumper locally in FL?
- CAN-Other WTB: Daizen Sway Bars
- GA WTB stock sc400 full exhaust in ATL.
- MD FS: HKS FCD | Apexi Safc | 1jzgte exhaust manifold gasket
- CA WTB passenger door panel BLACK!
- CA HIC Window Visor FS
- CAN-Toronto WTB Ebay black housing headlights and high beams
- CA WTB: Garnet Pearl Rear Bumper
- FL New 1j or 2jzgte intake v/s seals 15.00 shipped!
- FL new 2jz/gte mls headgasket 75.00
- FL black front seats 300.00 firm! Local p/u only
- FL 97-00 tail lights 240.00 shipped OBO great shape!
- MD Fs: mapecu3 Bnib with pnp 1jzgte jzz30 jumper harness
- CA FS: NEW Seibon carbon fiber doors
- GA 2JZGTE Headgasket/ARP Stud
- CA FS: Pair of oem mufflers from 98 sc400 vvti
- FL FS: 95 headlights
- NY 2jzge XS FFIM and LS1 Coils for Dizzy delet
- CA RSX S Black Leather Seats
- CA Front bumper w/fogs pre 97 socal
- FL Door panel
- CAN-Toronto WTB tan window trim - both sides
- TX FS: '92+ Passanger Side Glass High Beam
- FL F/S Turbo-Back Exhaust, 5Zigen Fireball Mega mufflers, SMIC and more!!! OBO!!!
- CA garage cleanout
- NY Supra Seats !!!
- CA FS: Walbro 255lph Fuel Pump, Oem Tensioner Bracker, Oem 2jz-gte Cam Gears, Headlights
- IL 97-2000 Rear bumper extensions Silver
- CA Black OEM floor Mat's (So Cal)
- CA WTB kaaz 2way, lsd or full pumpkin..
- CA FS-92 Fenders and oem Sway bars San DIego
- CA FS: Full Vertex Kit SUPER CHEAP
- CA Wtb: Usdm twin-turbos !!
- FL wtb 1997+ tan pass side airbag
- CA Supra Rear Carpet
- CA JDM Soarer Badge Set
- CA FS: 97 supra repair manual, sc400 ps reservoir, sc300/400 tow hooks and more
- GA 1JZ OEM Timing Belt
- NV tan heated seats from a 1992 sc400
- UT WTB: SC Roof Metal and Gauge Cluster
- TX WTB: Soarer emblem (rear)
- WA WTB: 97 BUMPER & Coilovers
- CA Clean Climate Control and MAF
- CA willing to buy Auto Couture rears and side
- CA FS: Tokico Blues
- TX front fender liners
- CA FS: Vertex Rear Bumper
- FL Wtb coilovers
- FL misc 1j/2j parts f/s manifold,ecu,waste gate,fuel rail,datswerk pump,msd dis4
- SC WTB: 2jzge turbo manifold
- IL 93-98 Toyota Supra (Megan Lowering Springs)
- NY Supra tt suspension $125
- GA WTB: 2jz crankshaft
- AL FS: Black OEM Steering Wheel with Airbag
- SC wtb: passenger side door handle plastic cover piece
- CA Wtb/fs/wtt: 2jz-gte twin turbo !!
- NY FS: New T-Bolt Clamps
- AZ Looking for engine undercover for 92 SC400
- FL wtb fuse boxes
- CA SC PARTS! tokico shocks/drop springs-interior door handle-headlights
- MI Wtb DWP fenders
- MI Complete Soarer Emblem Set
- CAN-Other WTB: 1JZ Flywheel .. used or resurfaced. =)
- WA Broken Door Handles
- WA BNIB 97-2000 tail lights
- TX ASAP!! WTB 92 SC400 1UZ Radiator or compatible alternative
- NY BNIB Manley Titanium Spring and Retainer kit for 2jzge
- FL Supra TT struts & TT Eibach Lowering springs
- OH WTB: 97+ Fogs in new or like new condition
- TX Tan interior items for CHEAP!
- MD WTB: Tan Floor Mats
- MD WTB: Courtesy Step Light Cover
- PA Used flywheel and pressure plate for 6spd (v160)
- FL 97-00 tail lights 240.00 great shape!
- VA Wtb: Seats,carpet,door panels
- PA MKIV Apexi GT Spec exhaust
- UT FS: SAFC 2, Turbonetics Racegate, Aeromotive FPR, 750cc injectors, etc
- CA FS: Cheap! JDM Window Visors
- CA Fs Oem outer tie rods great condition 91770
- CA WTB: 1996 foglights
- TX 1999 radio, cd changer, amplifier (x2), all door/deck speakers
- CA fs: jdm soarer oem front lip 92-96 + all mounting hardware
- TX Autometer, NGK
- CA FS 97+ side skirts BLACK 91770
- NY wtb catback exhaust system sc300
- PA 97+ side skirts
- FL clean&clear 97 sc headlights 180 for the pair!
- MO my lexus/toyota lot
- MN Wtb r154 front half or whole driveshaft
- FL FS/WTT: 95 and red 94 taillights (looking for fr. bumper)
- CA FS: 97 + Fog Lights
- CA fs: vertex front bumper
- CA Black Cupholder
- CA fs: jdm side markers
- NJ WTB: Interior bits
- FL FS: Tial Wastegate
- CA WTB sc400 lip and ls400 calipers
- CA WTB: 2jzGE Valve covers / Intake Manifold for CHEAP
- TX abflug coilovers + fujitsubo catback exhaust
- CA FS: 1996 SC300 Misc. Parts (exhaust, headers, bumpers and more!)
- IL Wtb Uncracked right side vent
- FL wtb lower springs 99 sc300,exhust cans and more
- MI FS SC300 Tokico Illumina Adjustables w/ Tociko drop springs, Climate control
- WA 1jzgte stock injectors
- AZ FS Sc400 Oem front lip and dwp rear extensions
- FL couple oem parts I had..
- NY Universal 80mm throttle body in red
- NY FS: Drift Motion 2JZ-GE T4 Twinscroll Flange Manifold
- FL 2JZ-GTE VVT-I 75MM Throttle Body
- CAN-Other WTB: a CLEAN set of headlights.
- CA FS: Sc300/400 Item Sale Misc ITEMS
- CA Stock springs, radio, high beams
- NJ garage clean out MUST GO
- PA WTB: 97+ stock body kit
- CA WTB: 5spd Swap Parts
- MN WTB 95/96 passenger side(right) tail light
- CA 5 Speed Engine Wiring Harness - 5 Speed ECU - From a 1992 SC300
- FL 5 speed harness
- PA FS: MKIV OEM Suspension assembled
- FL WTB:XS Power intake manifold
