View Full Version : SC400 / 300 Classifieds
- OR Fs:jdm spec aristo twin turbos
- FL Wtb: Oem or aftermarket struts and springs
- OR Megan supra/sc300 downpipe with jdm aristo gte flange
- NY FS: Leftover parts - let me know what you need - no reasonable offer refused
- IN FS- upper and lower door panels
- LA FS: injector resistor
- FL Chromed Custom Power Steering Reservoir
- TX WTB r154 swap parts
- NY WTB: Supra TT struts and lowering springs
- CA WTB: Oem waterproof car cover
- GA WTB SC300 Shell
- FL wtb sc300 chrome window trim
- NY FS: Bare SC400 1uz alum engine block NICE for project
- CA SElling CHEAP Driver FENDER!!
- FL 1jz alternater 30.00
- AZ stock 1jz bov $50
- AZ FS: Ebay red/clear tails $100 obo
- OK 92 SC300 Tail Lights
- NC Fs: 93' sc300 mt ecu
- ECU, GTE coils & clutch pedal
- CA WTB: 1998+SC400 engine cover plastic
- TX W58 -2JZ Bellhousing
- NY wtd driver side door panel for sc300
- FL Another reman sc300 a/c compressor 60.00
- CA WTB Black Sc400 Carpet
- FL TH400 Adapter Kit
- CA FT/FS vertex rep, Mk4 calip, diff.
- CA FS 1993 SC300 ECU for Automatic $125
- NC WTB: driver side window reg. an GE oil level sensor
- FL WTB: Steering Rack for '93 SC300
- GA FS: 99 Lexus SC300 Front Bumper
- CA WTB: hood dampers and driver side door handle(inside)
- FL Sc300 coolant tank 35.00!
- SC 1JZ rear sump set up
- CA WTB: 92 front pass fender, jade green
- FL sc300 rubber a/c lines 75.00 obo
- FL sc300 a/c reman compressor 100.00
- AZ WTB: Vertex rep body kit
- LA WTB: Engine Tray/Splash Guard
- WA WTS - Stock SC300/ 400 Steering wheel w/ Airbag *Cheap*
- FL WTB: Grey shift knob and shifter bezel with slots for heated seat buttons
- NC SC400 Rear Roof Window Visor Spoiler
- WA WTB SC300 Crank Pulley
- PA 95 sc300 mt ecu/computer/ 95 2jzge longblock/ 95 2jzge engine harness
- NY FS: 95-96 Pass Taillight
- NY FS: Glass highbeams
- NY WTB: Tan Drivers seat
- IL WTB: 6spd rear axles
- LA WTB: Mint Tan Floor Mats
- PA WTB: Downpipe/Flexpipe for N/A
- FL WTS: 1JZ Alternator, 2JZGE Ignition Coil, SC300 AC Control Unit
- CO HKS VPC, Bee*r Rev limiter, HKS turbo timer
- CA Fs: Jdm aristo twin turbos ****
- FL WTB:SC300 Hood latch cable
- TX ZEES Zelius axle back dual exhaust w/ dual tips
- FL SC300/400 roof wing
- AZ wtb: DWP gas door lid
- TX WTB Blac Perforated Rear seats
- CA Wtb r154 reverse & abs sensor
- FL IPT stall converter 300.00!
- TX WTB: 92-96 SC trunk "Lexus" emblem, uncracked driver tan window trim!
- NV Injen CAI + k&n filter and Cat delete
- FL 1jzgte auto ecu-Rebuilt jzx90 175.00 or trade for aristo ecu
- FL 1jzgte auto trans & converter 200.00 or trade
- CA WTB: used coilovers
- FL WTB - SC300/SC400/Soarer Rear lip for 1992 - 1995 rear bumper
- FL 1jz/2jz Lightweight Crank Pulley
- TX WTB: Wise rear spoiler
- IA 97+ tail light ECU/module
- CA 2jzgte upper and lower intake manifold
- GA WTB ECU for a 1993 SC300
- NV Precision 525cc High impedance Injectors
- OK Cleaning out the Garage
- TX WTB: Tein CS coilovers
- AZ Wtb: sc300 auto rear driveshaft
- NY WTT: 97 fogs with es300 retro for regular 97 fogs
- CA WTT: 97+ sideskirts and front lip for AC, Vertex, etc.
- CA is300 injectors
- NC WTB ASAP - SC400 power steering reservoir
- IA WANT TO BUY: Outdoor Car Cover for 36 SC300
- MD aem 3.5bar map sensor with pigtail
- FL OEM Crank Pulley - 62K miles
- TX FS: BFI OEM Air Filter Box 1992-97 SC300
- NV Fujin Lip
- NY MAPECU with PHR PnP Harness and Rush Antilag
- IL FS: TT Fidanza Flywheel, New SC300 Emblems, Heated Seat Switch
- FL SC 300 AC Climate Control
- PA FS: 94 sc400 Headlight Set (hi/low)
- FL Sc300/400 1992-1996 turn signal fog lamps
- GA wtb wise rear wing replica
- CA Works Bell short hub - $80
- VA FS: BNIB AEM EMS S2 for SC300, Deatschwerks 1000cc Injectors
- WA WTS: Ebay Roof Visor (cracked but fixable) - $40 shipped.
- NV wtb: jdm 2jzgte map sensor
- OH WTB Transmisson for my 1jz sc.
- TX FS: SC400 motor mounts, Diff polyurethane bushings, SC400 engine cover
- CA WTB: X -Pipe for 1998 SC400
- NJ FS: 1jz stock tiwn turbos and 1jz Auto Trans
- WA WTB - Rear Driver Side (Control Arm)
- MO WTB: OEM Y Pipe
- TX FS: Mint! 99 SC300 Tail lights
- CA WTB:Tokico Blues
- FL 2jgte: Super Spark coils,HKS DLI, chromed TB, and plenum and more parts.
- CA WTB SC400 Transmission / Tranny Automatic
- PA Wtb: radiator for 93 sc400
- CA FS: Turbo feed line -4 AN
- TX WTS Adaptronic with PNP harness for SC4. Clean 97 Head lights!
- PA WTB: SC300 2JZGE engine mount brackets
- LA FS: beautiful luxurious black carpet $100
- LA FS: BN manual shift boot trim $35
- PA FS: W58 with bellhousing no propeller shaft
- CA WTB:98+ Trunk spolier/wing
- NY FS: 97-00 Sideskirts and Door moldings - red
- FL WTB: 97+ Tailights, Front lip for 97, tan leather front seats
- TX FS:W58 & R154 bellhousing, W58 tripod plus shifter, R154 shifter, NA diff, W58 RPS
- TX Black Window Switches Driver & Passenger
- TX Black interior part out (CHEAP!!!)
- CA FS: Supra spec KYB Gas-A-Just shocks with "Falken" Factory Tuned lowering springs
- NY WTB: Door Panels and Coolant Res Cap
- MO FS: Supra TT Rear Calipers and Rotors
- MO FS : W-58 to 2JZ Bellhousing
- OK DevilsOwn Meth kit!!, Tial 40mm Wastegate, Aeromotive Fuel Pressure Regulator
- FL WTB: Soarer ECU
- FL OEM Nakamichi head unit and OEM 12 disk Changer
- CA FS: Soarer black rear seat belts (3) and front lower tether bars
- AZ Tan Interior Part out!!!
- PA FS/trade for OEM. Origin 25mm Front Fenders
- TX ONEJAPMAN - FULL car part out (widebody, wheels, engine, everything)
- CA FS: 2JZ-GE Partial Turbo Kit
- CA FS Grey interior dash/interior odds and ends.
- NV vvti (1uz) engine + auto trans for sale
- FL FS: 2JZ Fuel Injector Resistor, HKS DLI, 1JZ AFPR Kit, 1JZ Chrome Intake, 97+ Rear...
- CA LS400 4pot Front Calipers and Brakes
- CA SC300 K&N - Drop in Air Filter -
- PA WTB: Ikeya Formula Control Arms (or equivalent)
- SC 2JZ injector resistor pack
- TX WTB: Center AC Vent
- CA 7mgte leftovers + some 2jz stuff
- NY wtb sc300 ac compressor
- MA FS: Clutch Pedal Assembly
- OR Fs:1995 cruise control motor cable complete assembly! Plus 2jz ge coil
- CAN-Toronto Map ecu 2
- MO WTB 97+ SC300 Driver side Window Regulator assy
- CA 95% Complete Air Suspension Kit
- AR WTB oem black front seat belts
- CA Sc400 injen intake kit used
- FL WTB 1997 lexus sc400 COOLANT RESERVOIR RADIATOR OVER FLOW RECOVERY TANK OEM
- MD WTB: Inner Door Panels 92 SC (Spruce)
- GA 2JZGTE valve covers for sale
- FL 1JZ/2JZ Part-out
- NY FS: 95-96 Pass Tailight with harness
- NY parting out the car..
- NY FS: 97-00 Lexus SC Pass Airbag Tan
- CA fs:97+ bumpers and sides
- CAN-Toronto FS:Shift Solenoids/Ignition Coilpacks/MAF Sensor
- FL 4 GReddy 60MM Gauges with all wiring/sensors
- LA FS: LS400 Fronts
- CA FS: 97-00 Tail Lights
- FL wtb 1jzgte automatic transmission
- CA FS: Pre 95 Bumpers DWP w/ Fogs
- NJ Sc400/a340e tranny oil pan
- TX FS:1JZ Starter,94 Taillights,Brakes,Heater Core Valve,Door actuators,A/C lines & more
- NV wtb: Na-t Stainless braided feed/return lines
- AZ WTB: 1JZGTE Motor
- NY FS: Lexus LS400 Front Calipers
- CA WTB Tail Lights
- CA WTB: SCX00 Driver side inner door handle
- GA Black 99 Conversion, Black Interior,Dash,Seats, 5 spd Conversion R154
- PA Prothane: Front Lower Control-Arm Bushings ('92-'96)
- FL WTB: Black Sc hood & r134 a/c compressor
- FL Wooffer for SC400
- FL New 97-00 lca poly bushings 290.00 shiped
- FL New oem 2jzge water pump with rear housing 90.00 shipped!
- PA WTB: '97 SC300 Lower Control Arms (or just Bushings)
- NC Some GE parts, door handle
- CA FS: damaged 95-96 taillights with harnesses
- CA F.S. various sc parts
- CA AEM EMS Gen2 30-6100
- NY WTB Headlight Assembly
- CA Sc300 , glass hbeams, stock shocks, and other parts
- FL WTB tt waterpump back housing
- GA Fs:Sc oem black seats.
- CA FREE: box of stuff
- CA thatWESguy part out!! Swoop on parts while you still can.
- CT 1UZFE transmission adapter plates......
- CA almost perfect tan door panels both!
- LA WTB: 2jz/1jz MAP Sensor
- CA The rules...
- CA SUPRA TT Twin Turbo Rear Brakes w EVERYTHING Shim Kit etc. BRAND NEW
- WA Did you buy my AEM wideband?
- PA FS: Lexus Steering Wheel + airbag
- GA WTB: W58 transmission
- NC MINT 98 Kouki Tail Lights , MINT 96 Driver side tail light , 1jz-2jz W58 transmission
- FL WTB: 95 Supra TT Calipers
- TX Wtb crank timing gear 97 sc300
- CA WTB:98 Engine valve cover.
- CA 2jz-gte parts!!
- PA Does anyone have all/any of these 4 parts?
- NY Orgin/Vertex Style +25mm Front fenders
- CA (wtb) 2jz/1jz-gte/ F bumper/fender/hood
- FL fs/flush wing clearcoat peeling
- FL tan door paanels
- SC FS: JDM Aristo ECU
- GA need rear window have moon roof 4 trade
- Wtb factory lip for 92 - 96 sc300
- UT FS - SC400/300 Headlights and higbeams left and rights sides
- TN WTB: 1998 SC mirror drivers side Pearl White ONLY
- FL WTB 2jzge Alternator ASAP!
- TX SC400 coolant tank and level sensor
- CA WTB: Complete R154 for GE, Complete Shine auto project kit
- CA stock 2jzgte pistons & rods, wideband gauge, & NA-T manifold
- LA WTB: mk3 R154 front drive shaft
- LA Entire working A/C part out
- NY WTB: eBay subwoofer box for SC
- GA Busted rear window
- WA Wtb: Sc400 power antenna assy
- FL FS: TT 6spd LSD, 440cc, mk3/cressida LSD
- VA WTB: AC Climate Control, Center Console, and Manual Shift Boot Console
- FL SC400 Ksport Control Pro's Coilovers
- WA WTB: Kouki SC Fogs & Tailights
- PA Wtb: r154 soarer setup
- VA WTB NAKAMICHI factory amp
- GA Free
- GA Free
- OR Tw/fs megan ez street coilover
- FL Cluster for parts
- FL Fs brand new discontinued hks gt wastegate
- FL WTS: 1JZ Alternator for sale! Quick sale need gone!
- IL WTB: 92-96 Trunk w/spoiler (painted Platinum Silver)
- MN WTB SC400-300 24mm rear sway bar
- FL WTB: 92 SC300 AC compressor
- FL 92-95 rear lights 75 shipped
- FL Red sc 92-96 bumper
- FL Red sc mint trunk no holes
- FL Red flush sc wing 80shipped
- FL 00 sc300 front bumper very mint
- CA WTT or Sale: 6 speed lsd
- CA Wtb & wtt
- NJ For Sale 95 SC300
- AR WTB: Supra TT fan blade and P/S reservoir
- MO my lexus/toyota lot II
- MO WTB:Supra TT Lowering Springs/Struts
- OR SC300 NA-T Kit Quality Parts for Cheap
- AZ FSMoto 2JZ-GE Intake Manifold Kit
- CA Wtt/wts ac rep bumber/ aristo ecu/socal
- CA JEGS Upper/lower front control arm bushing
- NY WTB: sc300 fuel pump ecu
- GA I need a Catalytic converter for sc300
- CA Safety 21 6 point rollcage
