View Full Version : SC400 / 300 Classifieds
- MD WTB sc rear bumper
- FL FS or WTT: 1jzgte Soarer Jzz30 for Jza70 ECU
- TX HKS DLI for GE motor w/harness
- NJ FS: Driver and Passenger INTERIOR door handles, black
- NM WTB: SC300 Fan Shroud
- FL Black leather interior partout! get it while its hot.
- International some parts for soarer
- NY FS: Tan Supra TT front seats
- CA WTB spacers 30&25mm
- NY For Sale 1995 Lexus Sc400 parts
- MD Stock r154
- MD WTB: 2JZGE Block
- CO WTB: map ecu 2
- GA AC Climate Control / SC400 Engine Cover
- CA WTB Spacers 25mm and 30mm
- NY FS: Poly Rear SUBFRAME BUSHINGS
- PA Misc 2jzgte parts from tt auto supra
- TX 97 Tail lights and Fog lights Front Grill
- PA 5spd Pedals + Master for SC
- CA FS: 2001 RX300 wood grain steering wheel and single stage airbag
- CA Garage/Backyard Clean UP! 1jzgte/2jzge/7mgte!!!
- NY 1UZFE engine and transmission
- FL FS: 1JZGTE Soarer Manual Transmission ECU and More
- NV WTB actuator
- CA WTB- Supra MKIV suspension upper mounts
- NC 2jzge long block part out cheap!
- CA 92 sc300 5 speed conversion kit
- NY Turbonetics 60-1, Turbo T3/t4e Great Condition
- AZ wtb supra turbo rear calipers
- GA WTB: Fuel Pump,Power Steer Pump
- AZ WTB:98-00 SC400 Shifter, Gauge Cluster
- NY FS: March Madness - Something for Everyone
- CA selling perfect cluster needles and driver side inner door handle
- CA WTB - fresh 2jz-ge vvt-i head, stock or built
- GA 1996 LS400 brake assembly. Works flawlessly
- KY 2jzge parts
- CA WTS : AEM boost control/ HKS DLI II GE
- FL Aristo 3.76 with TRD diff
- NY A Couple Stock 1jz parts
- CA WTB/FS: 97+ Foglight D/P
- OK Parting out my Lexus
- WA WTB: used/old MKIV supra rear subframe mounts
- TX Soarer Intercooler and piping
- TX WTB Hic roof spoiler
- AZ WTB: Air Bag Sub Harness 09082-00760
- CA FS: Supra TRD strut bar, Stoptech, Axxis brake pads rotors, NGK spark plugs, and more
- FL 1jzgte JZZ30 Soarer ecu for sale
- FL SC400 front oem calipers used
- AZ NA supra oem suspension setup
- CA tokico blue shocks and eibach lowering spring assy
- WA WTB rear upper control arm bushings or arms
- FL Front Seat Part Out
- TX SC Black A pillars with Oh S**** handles!
- NC 3" 2JZ-GTE Downpipe
- CAN-Other FS: 2 Supra Calipers Rotors and Pads
- CA Brand New BLACK GRIFFIN EMBLEM Steering wheel
- CA norcal wtb stock exhaust
- FL TeeLex SC Part Out
- NV 3 Inch mid pipe + dual pipes
- NY FS: 97 Lexus SC300 Partout
- FL Tein FLex with EDFC low mileage
- TN WTB: Chrome SC300 emblems
- FL Almost new oem sc400 radiator and over flow tank-Cheap!
- CA fs 1996 tails glass high beams
- FL BIG FMIC, Tial Knockoff 50mm bov, HKS 4" Purple Filter 4" JZ inlet pipe Wideband etc
- IA 97+ Tail lights with lamp failure indicator and misc interior parts
- FL LS400 brake package, spacers, MSD 6A, NGK Iridium plugs for sale
- NV Sc300 grounding kit
- CA lextreme.com
- FL Single Turbo 1JZ FULL SWAP, Exedy HyperSingle, MC R154
- CA SC300, 1jz, Random Parts Sale - Garage Clean Up - Check out the Pictures
- FL FS: LQ9 Coils w/New OEM boots & New Pigtails
- NJ WTB sc300 manual conversion kit
- CA Wtb: '92-94 Climate/Volume Knob, From Non-CD Changer Car
- TN NEED a cluster gas gauge motor
- NY got a few random goodies for sale
- NY Wtb 2jz-gte short block
- IN Sunroof and A.C. compressor core
- MO w58 for sale with some other goodies!!
- MA FS: set of 2 SC door speaker enclosures
- PA Wtb: R154
- NJ TT auto trans
- TX Heater Valve OEM used $40 shipped
- LA WTB: Rear diffuser
- FL Rust free bare rear sub frame 75.00!
- FL ls400 calipers Used low mile in great shape, 130.00 shipped!!
- IL Wtb "SC300" trunk emblem
- NY WTB : coilovers
- NY WTB: 650-750cc high impendance injectors with 1jzgte fuel rail
- ND Sale or Trade!: Brand new Aftermarket Headlights, for clean used Lowbeams!
- KY WTB: Passenger Door panel and window control
- WA WTB 1jzgte Map Sensor
- CA 2JZ-GTE tubular turbo manifold brand new (Cheap!)
- TX driver A/C vent, Cluster Bezel, Parking light holders....Cheap
- FL WTB: W58 manual transmission
- TX Wtb w58
- CA 93-98 Supra 6 speed subframe, 6 speed drivers side axle, Greddy MBC boost controller
- TX R154 complete swap and 3.76 Auto TT LSD
- CO FS: 1jz 2jz garage sale
- FL WTB 95-96 sc300 wheel center caps
- FL f/s 1997 fog lights , cat back 3 inch dual exhaust system
- NY wtb: 650-680cc high impendance injectors
- TX Wtt
- AL FS: Red Needles for Cluster
- CA WTB: black window switches, seat belt buckles
- ID SC400 Lip, window motor, fan clutch, changer, more
- CA FS: Brand New Stance GR+ coilovers 92/00 SC300/400
- GA 2jzgte 750cc injectors siemens and rail
- CA SOCAL: BRIDE CUGA seat with wedge eng seat bracket
- MN WTB: SC Front Bumper
- FL WTB: Power steering vacuum valve & stock 1JZ intake/filter(w/ tubing)
- NY FS: Brand New Replacement Radiators for SC400s and SC300s
- CA FS: Supra/SC300 Tein Super Streets $600
- LA wtt
- CA WTB: 97+ SC300 front bumper
- CA WTB: 1JZ VVTI ECU M/T (Part #89661-22790)
- CA FS mystery HKS Coilovers - $450 - 91770
- OR Mirrors, trim, ashtray, FCD
- CA WTB 92 sc400 compressor
- CA WTB Headlights, 97+ Fogs, Grill, Climate Control etc..
- CA Some cheap interior parts
- NY FS: Supra 1jzgte auto and manual ecu
- VA 2nd GEN LS400 Calipers OBO
- NY WTB: T4 Downpipe, Midpipe, and Single exhaust
- NY FS: stock 1jzgte 370cc injectors with rail, 1jzgte supra ecu A/T
- CA sc300/400 oem lip
- CA FS: 1/2JZ lower rear sump oil pan
- NY FS: SC300/400 High beam headlights
- CAN-Toronto WTB Drivers Door Hinge
- CA WTB Diff and center bearing
- AZ black door window switches
- TX WTB 1000cc injectors and fuel pump.
- TX 97 usdm Tt Ecu 6 speed full conversion for Na-t
- FL Big SC300 sale (Headlight set, 1JZ Valve covers/tranny, MSD Tach, AC, Ign Coil, etc)
- CA Wtb: 5mm spacers. (DELETE MOD)
- FL Sc rear upper control arms w/prothane bushings
- IL WTB:Stock chrome headlights and DRL's.
- NE WTB Any year lip
- ME 2jzge head w/ 2jzgte ECU Intake and fuel system - $1500
- WI FS: Stop Lamp Switch Assembly SC300 or SC400 (Brake light switch)
- MD FS: 93 tan dash
- FL Wald 97-00 front lip 450.00
- NV WTB door handle.
- NY WTB Driver Side Hub/Knuckle
- CA W58 Flywheel
- NY fs: 750cc high impedance injectors with fuel rail
- NH WTB: sc300/mkIV w58 5 speed swap
- NY fs: 1jzgte ecu jza70 recapped
- NY fs:low milage 1jzgte 370cc injectors
- NY FS: USDM 550cc injectors and 7mgte resistor
- TX WTB AEM v1
- CA WTB - LS400 BBK Setup & 97+Front Lip
- GA WTB - Black Auto shifter
- IL WTB: SC300/400 Third Brake Light Rear Deck Cover in Black
- CA FS: dummy airbag tan
- NY WTB: 97+ front bumper/grill/fogs & 92-94 Taillights
- FL WTB: Climate Control
- NY Greddy Boost Gauge MINT P&H
- TN Re-key your entire car and get a master for $150!!!!
- TN Big O's whole-lotta-honkin-parts sale
- NY wtb: 1jzgte Aem for jza70
- IN FS: TT LSD in SC pumpkin
- NY Fs: 1jzgte 89661-14470 a/t ecu
- CA PBM Coilovers for sale. shipping available.
- GA 95 SC400 Black Steering wheel with airbag
- MD 97 door moldings/ 97+ front Grill
- CA WTB: 3rd rear speaker deck brake light
- TX New RC 550cc top feed injectors and walbro 255.
- NJ WTB Cheap 97-00 SC Fog lights
- CA FS: real jzz30soarer 3" exhaust setup,usdm550cc,resistor
- CA looking to sell my 3" exhaust setup
- CA Auto Couture front bumper
- CA Coilovers
- VA NA-T High End Part-Out! -AEM EMS V2-TTC 268 Cams -ETS FMIC-6265 Turbo Kit-FSMoto FFIM
- WA Custom Turbo Gauge panel (SC300/SC400)
- International WTB A340 tranny bellhouse
- NC WTB Brake booster
- CA WTB Tan Door Panels LH/RH sides
- CA 440cc injectors
- CAN-Other 99 GS400 Steering Wheel with Airbag - Black ($125 Shipped)
- MA Few goodies for sale - Fujitsubo, Corbeau, 98 bumper.
- TX WTB: Tweeter grills for both Doors
- CA FS: 99 300 Gated Shifter, Homelink Visor & Dimming Mirror
- TX Black Floor Mats Full set
- MI WTB: Wing
- CA WTB : 92-96 Driver side fender
- CA Nakamichi head unit
- CA Megan EZ Coilovers
- CA clean black door panel
- MD Na-t exhaust manifold, lq9 coils, r154 trans
- NY Wtb: Stock taillights
- OR Tanabe gf210 lowering springs and wheel spacers
- FL Espelir ASD Springs and Tokico HP Shocks
- NY Dragon Precision Industries (PI) 2800 stall torque converter
- TX Driver door power mirror $20 shipped
- NY Rideskinz Front Lip, D/S Fender, Reman Rear TT calipers, misc
- NY 1995 SC300 with BLACK interior part out....tons of BLACK interior stuff....NICE...PIC
- TX Woodgrain steering wheel and Airbag Chrome emblem
- CA WTB 2JZ/1JZ rear sump LOWER OIL PAN
- TX SC400 Motor mounts
- NY WTB: SC300 Floor Mats
- CT Wtb power steering hose for 97 sc400
- CA FS RC 440CC Injectors
- WA WTB Intercooler and piping (direct fit) for sc300 with 1jzgte swap
- WTB: Soarer R154
- CA WTB: black LH fender and trunk
- Looking for interior
- CA Custom rear speaker deck
- AZ FS: NEW 12psi 40mm external wastegate and dump tube
- AZ sard 1jz non vvti ecu m/t and 2jzgte vvti ecu
- MI WTB: Right Headlight assembly, Power Steering Cap & HID Kit
- NY FS: RECAPPED 1jzgte Ecu jza70
- CA FS-93 W58 Trans w ACT Clutch
- CA FS pass inner door handle ---- 91770 pick up $15
- FL Wtb 97+ fog lights
- CA WTB: BLACK AEM gauge bezel
- MD FS: 97 Driver Taillight
- AL WTB: Radio Antenna Assembly
- AL WTB: Passenger Side Rear Hub Assembly
- CO WTB: Royal Jade Pearl Front bumper
- CA Trust GReddy GREX Oil Filter Relocation
- OR 92-94 tails
- MD WTB: 97+ Tails
- IL Full set of OEM 99 SC300 Calipers, Hoses, Brackets, Pads, and Clips
- FL FS: Upper Door Panel - Tan
- IL BRAND NEW NEVER INSTALLED Fujin VIP Lip for 97+ SC
- IN C&R racing radiator cheap
- NY WTB: Driver Tan Upper Door Panel (Around The Window)
- NM LOOK! Lexus SC400 parts: Hinge, JVC CD player and harness, ect
- NM WTB: Upper window trim tan in color/Cupholder
- NY 1995 sc400 getting 2jz-gte swap
- CA White spoilerless trunk lid, stock Pioneer radio, aluminum PS reservoir, and more
- AZ FS: 1JZ/2JZ R154 Flywheel
- WA WTB 1JZGTE Stock down pipe
- CA WTS R154 Drive Shaft into SC300
- exhaust, cluster, Supra brakes
- NC WTB: 2jzge motor
- CAN-Toronto Drivers Side Window motor/regulator
- NV 92-94 SC300/SC400 taillights
- CA WTB rear pass side suspension
- wtb:1998 sc300 passenger tan airbag
- MD FS 1jz/7m Starter
- WA 2jzge turbo downpipe and manifold
- TX AEM FIC, FFIM, and more NA-T
- CA WTB: Stock Radio Harness for SC w/Pioneer, without CD Changer
- TX Soarer Downpipe 1JZ-GTE
- AR WTB 97+ door mouldings 92-96 sc300 auto cluster
- CA OEM Black Steering Wheel and Bump Steer Kit/Outer Tie Rod
- MD KYB AGX Stuts with Eibach Springs
- FL WTT black 3-spoke wheel for tan
