View Full Version : Performance & Maintenance
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
  1. Hesitation / sputtering around 1500rpm
  2. Future SC300 owner with questions, performance and some others
  3. IMF SC400 Headers GB $399!
  4. SC400 Trans whining and clunks
  5. Lets Discuss - 3.23 Gears in MY SC400
  6. Need Help With My SC300!!!
  7. question.
  8. Radiator replacement help
  9. should i run 2.5 or 3 inch piping? help me order real fast.
  10. Need quick verification
  11. High Mileage concerns
  12. R154 shifter Question(please help)
  13. Gas tank drain plug location ?
  14. 1jz pistons?
  15. Resonators
  16. s4s hybrid kit owners post.
  17. working on tt manifold on ge lower runners
  18. working on tt manifold on ge lower runners
  19. TH400 In an SC300.. Question on Install.
  20. Newbie to JDM need help
  21. Intake adapter and k&N filter #0810
  22. VSS no.1 code 42
  23. 1JZ running good, sorta...
  24. Noob ? GE GTE Questions
  25. 1995 SC400 Overheating problem. Need solution HELP!
  26. Upgrading alternator and battery
  27. PLEASE HELP QUICK!!! Aluminum Radiator for sc300 A/T?
  28. Loud exhaust
  29. SAFC froze now running rich...??
  30. So is 1 turbo better than 2?
  31. Aristo swap to Usdm ecm/specs
  32. Cant rev after headgasket install
  33. greddy speed cut
  34. what do ya think so far
  35. Suggestions on a Borla setup...
  36. GOING SINGLE! first pics in side
  37. need help asap. weird part melting
  38. Timing Belt "O" BOI.. VVTi 1UZ
  39. Please help.. Pinouts needed 1992 SC300-2JZGTE!!
  40. What clutch should I get?
  41. Driver door won't open!
  42. Help with wiring..1992 SC300 Auto w/2JZGTE
  43. Help from you 1JZ gurus please...
  44. Water Pump replacement?
  45. 99 SC300 Transmission vs 99 GS300 trans?
  46. Question/Verification on Fuel ECU bypass wiring
  47. bulding a turbo kit need intercooler piping for the sc300
  48. sc400 custom exhaust piping question
  49. 5 spd Swap with an OBDII Car
  50. supra 550's...?
  51. yes or no question
  52. 2jzgte swap...
  53. replacing rod bearings, motor in car?
  54. What is the number of the tail light bulb?
  55. Sc400 gurgling sound/ hot exaust
  56. New Ebay Exhaust Out
  57. clutch just dropped while driving =O
  58. HELP need asap...(really means Starter Issue)
  59. in search of soarer 1jz engine harness pin out
  60. Need help with twinturbo setup !! Please !!!! Asap !!!
  61. Egr mod do i put the resistor here? picture
  62. CAR Hesittating & Loss of power!
  63. spoiler brake light
  64. More Problems!
  65. Power Steering Tube leak
  66. Transmission Upgrade (Auto or manual)
  67. Hold the exhaust please....
  68. boost my LS or upgrade to XJR
  69. exhaust swap question
  70. Looking to buy a catback exhaust
  71. Looking to buy an intake
  72. Any interest in SC300 headers?
  73. need help smoging my 1jz-gte
  74. What is this called???
  75. Checking interest for the IMF headers..
  76. which would be better?
  77. Which NGK Plugs to Use?
  78. GE block and TT head Who's got it?
  79. A340E and an A341E transmission
  80. I have got the throttle body and intake manifold off
  81. Drive Shaft Bolts
  82. Lexus warning light
  83. are these motors and trans the same ????
  84. Fellas Got a Check enging light on 98 sc400 vvti
  85. Radiator Leaking!!! LS400 part in SC??
  86. Rear O2 Sensor removal and tricking?
  87. Wtb: 1jz turbo or 2jz turbo motor !! Socal !!
  88. CEL turns on and off
  89. Need help gathering minor tune up parts SC400 98 vvti
  90. sc400 tranny to a 1jz-gte tranny???
  91. would this work?
  92. Gotta figure out why the oil light was tripped when.......
  93. Lost on the turbo size to get. Please help.
  94. underdrive pulley?
  95. Is it just me or does the a650e tranny drive funny?
  96. 95 SC400 won't fire, need help with external fuse box wiring
  97. Clutch replacement
  98. need help with auto tranny on 93 sc400
  99. Amsoil Help
  100. HELP AC doesn't work
  101. 1uz-fe (71, 76mm turbo spool)?
  102. Short shift kit
  103. Canister is leaking Gas...Please Help !!!
  104. Does anyone still use the MSD BTM?
  105. 95 SC300 won't shut off
  106. traction light flashes, check engine on. Car won't drive
  107. TT coil fitment on a na-t (please advise)
  108. Where O Where do my hoses go? W/pics
  109. AEM EMS+ JDM 2JZ-GTE help please
  110. Any Plug and PLAY standalone for aristo engine
  111. sc300 belt squeal
  112. Crank Pulley Bolt Removal?
  113. Cam Gear Cover Mod and 02 Sensor Question
  114. Squeaky Clutch 94 SC300
  115. Few questions for a Newbie (engine swap questions)
  116. Where to begin
  117. Question i'd like an answer to please (Engine Swap Questions)
  118. One simple question!!!!
  119. ge water pump on 1j?
  120. car bogging and hesitating. pls help :(
  121. I just got my 92 lexus sc400
  122. Smart people...
  123. '92 5sp won't crank, no fuel, no power door locks after installing new battery
  124. Supra flywheel
  125. 1993 SC400 Over Heating Problem
  126. 1JZ hesitation issue
  127. Difference Between 2 W58 shifters?
  128. Changed spark plugs, now car barely running...HELP
  129. supra fuel pump?
  130. results on
  131. *What car is this clutch pedal from*
  132. Code 52+55 (Knock Sensor)
  133. Camshafts...1uz
  134. Check engine light
  135. exhaust leak help
  136. 2jz-gte + w58...clutch component concerns...
  137. A few problems/diagnosing help
  138. IS300 steering wheel? what is needed?
  139. Fuel cut? clutch slippage? HELP!
  140. knock sensor help!!!
  141. Do you trust this TURBO MANIFOLD?
  142. Anyone run a surge tank??
  143. Crank Pulley
  144. NEED help >how to install GM3 bar map sensor
  145. will a mk4 torque converter fit my 1jz/a340e swapped sc300?
  146. purchasing a 97' sc300 five speed manual, motor swap help
  147. 1jz auto
  148. Head Game Whats The Difference VVTi Head VS. Non VVTi Head
  149. Car missing and stalling
  150. JDM 1jzgte california legal
  151. washed my engine bay, but the problem is not what you think, help please
  152. Mounting a MKIV Stock Intercooler
  153. W58 and 1jz
  154. Diff centre replacement
  155. Megasquirt II v3.0 Q's & A's
  156. Trans swap question
  157. 98 2jzge vvti into an 94 sc3
  158. 1jz/2jz with emanage blue install direction
  159. Speedometer Issue
  160. So has anyone tried installing injen's intake on 96+ SCs?
  161. where to find 1jz distributor?
  162. Best way to drain P/S fluid?
  163. Electrical Wiring Issues w/ Pics
  164. Some GTE swap questions
  165. Stock exhaust piping size
  166. OBD II 1jzgte?
  167. 98 sc400 vvt-i possible drive shaft problem, not sure though..
  168. 98 sc400 vvt-i custom exhaust pipe while retaining stock mufflers..
  169. JDM Oil Return Line - At wits end please help
  170. quick question
  171. trans slip intermittent
  172. Single turbo questions.
  173. almost there...na-t need some help/advice befor i start the car
  174. Help...Starting problems...
  175. Newly purchased SC400
  176. Quick A/F readings from my AEM UEGO (video)
  177. Keeping my 1JZ-GTE.. possibilities?
  178. 2jzgte into a 2000 SC300...doable?
  179. OMG! I broke my PI Dragon converter!
  180. heater problem
  181. Going Single Turbo.. Need some help!
  182. After market radiator
  183. Junkyard Electrics Fans PICS
  184. Wiring Up the Alt.
  185. 1jz swap very odd problem
  186. Replacing Main Cat with Cutout - But I have a question
  187. 1jzgte 1st start up advise
  188. Greddy sld on JDM GTE swap issue
  189. Smoke on Start up
  190. Map Ecu 2 VS AEM FIC
  191. BFI or SRT/ecu Intake
  192. pre 91 4runner distributer guys chime in.
  193. Got exhaust on the car
  194. 1uzfe NA 420rwhp @ 9300rpm
  195. 1jzgte-vvti turbo manifold
  196. takes forever to warm up
  197. 92 SC300 ecu, fuel pump problems
  198. 92 SC300 Sub-O2 Code 27
  199. New to sc300 !! Need help please ! Turbo etc.
  200. 1JZ-GTE or 2JZ-GTE? ..
  201. new sc owner. the mods start.
  202. 1999 SC400 vvti Custom Exhaust
  203. Sway bar in the way of lower radiator tube
  204. SC300 5MT 5th gear whine noise
  205. Conversion Gasket set???
  206. Stock 1JZ going Single.. Turbonetics?
  207. Heater problem
  208. Strange gas needle activity.
  209. 1jz transmission slipping help
  210. Fuel pump control unit re-build
  211. Anyone have a 1JZGTE ECU recapped?
  212. Sc400 overheating,
  213. 2jzgte/96 sc300 swap
  214. Dilemma over which turbo.
  215. How important is this heat shield?
  216. A340E tranny pinouts
  217. maf unplugged
  218. Spark plugs whats good??
  219. oil restrictor hole size
  220. Exhaust question
  221. Rebuild trans?
  222. '94 SC400 Hydro Pump Leak
  223. SC300 how to check and add tranny fluid?
  224. Best SC to modify for high performance
  225. E3 Spark Plugs
  226. Bottom alternator flange nut stripped - size?
  227. VSS/Pink wire from cluster question-all with inst cluster knowledge
  228. What is my drivetrain worth. (Built Soarer R154, ACT Stage 4, DS, NA Rear End w/lsd)
  229. 1JZ Not Starting
  230. Car won't start, fuel pump staying on
  231. Help - Issues with - Memory Seat - Heated Seats - Button
  232. just got my sc300 on the dyno :-/
  233. took my sc to get dyno'd
  234. what are some perfomance mods for my 94 sc400
  235. bad wheel bearing causing poor mpg?
  236. Timing Belt
  237. Took my Sc down the 1320!
  238. Alternator
  239. low budget dual full pump
  240. low budget dual full pump
  241. low budget dual full pump
  242. my sc300 turbo project
  243. cat and resonator delete?
  244. Exhaust smells like fish?
  245. 95, SC300, no fuel no start issues.
  246. Should I get the Timing Belt parts at the dealer?
  247. how much hp with this set up
  248. !NEED HELP! misfiring??
  249. sc400 gauge cluster help 1jz
  250. EGR valve on 92 SC 400?
